United States, NY, Shelter Island
Joined May 2011
Flight footage. |
Joined May 2011
on Board GoPro footage |
Im curious about the T config and would like to hear more about the flight characteristics. Pushing the arms back like that throws out the geometry, the pitch axis would become more sensitive, pitch gain would surely have to be adjusted. Also the flight controller location would be pushed forward of CG which would affect handling and balance. Im sure it would still fly just how well is the question.
![]() I also got the KK2 and I'll be running 28-26 (1200) on 4S (8x4.5), should have plenty of power. |
I have a T-Copter that I scratch built 2 years ago, and getting the CG right, required mounting the battery way back on the tail boom. It's just the nature of a T-Copter. But I really like T-Copters because they are easier to see which way they are pointing in the air, and the props aren't in the video. My current Y6 copter is hard to judge orientation compared to a T-copter. Also, the GoPro is mounted on a boom extended forward from the central body plates, and I see no props in my GoPro video. Doug |
Japan, Tokyo
Joined Jun 2011
Joined May 2011
My tri cleared china! Probably another week to NY. I'm thinking a real clean install with escs in the body and wires in the arms. LEDs, 4S with 8x4.5 gemfans, green and orange, got a 26g digital servo from hobbypartz, solar brand, quad power distribution board, F30A flashed with SimonK fw, NTM2826 1000kV motors, kk2 board on nylon offsets, gopro hd, 5.8ghz fat shark 600mw with rhcp antenna, separate Bec for video trans, am I missing anything else?
United States, CA, San Mateo
Joined Mar 2010
Assembly issues
Hi all
Got my Talon Tricopter yesterday and started assembly last nite. There are some issues. First the exploded view assy drawing shows a Stepped Screw used to hold the Tail Section Plate to the Tube Mount. On the diagram its pointing in the wrong direction compared with the photos on the HK site. The diagram also lacks the required locknut. So look at the product pictures on the HK site. But the real issue is as you tighten the locknut the assy locks together. You must not fully tighten and allow the screw and locknut to turn as well as the bearings. So the locknut is really important!! Not the best mechanism IMO -- that screw (bolt) is acting as a bearing which is not the best. It could have been better engineered (something for V 2.0 ?). Anyway it is workable with some slop. A nylon washer between the locknut and the Tail Section Pivot would help. The arms (Carbon Fibre Tube) are slightly over 14 mm OD (same as Talon Quads) and are very difficult to fit in the 14 mm holes of the Pivot Plat Mounts (Blocks). You must reduce the OD to fit the blocks. I used the mounts (blocks) like a pencil sharpener to reduce the arm OD to fit the holes. You could reduce the arm OD with sand paper (Emery paper) too. The arms must slide in fully into the mount so that the Spring reaches the pivot step screw. I had to file the slot in the arm to make the Fixture Pin move freely to the end of the slot. Well that's as far as I've got with the assembly. So far I think the thing could have been better engineered for the money. But I look forward to flying it! Hope this helps others. Cheers Rob |
| Thread Tools | |
| New Product Turnigy Talon Carbon Fiber Quadcopter Frame | CrashingDutchman | Multirotor Talk | 484 | Apr 08, 2013 04:08 PM |
| Discussion Talon V2 or F450 Frame? | solars | Multirotor Talk | 27 | Apr 07, 2013 01:56 AM |
| Sold Turnigy Talon V2 Frame $30 / shipped **PRICE REDUCED | pefozzy | Aircraft - Electric - Multirotor (FS/W) | 5 | Sep 15, 2012 04:21 PM |
| For Sale Turnigy Talon Quad Frame V1 | penz83 | Aircraft - Electric - Multirotor (FS/W) | 2 | Jun 03, 2012 05:17 PM |
| Sold universal quad frame and tricopter frame | dr rc | Aircraft - Electric - Multirotor (FS/W) | 4 | Mar 07, 2012 07:26 PM |
