Old Oct 09, 2012, 09:50 PM
WitnessOnly is offline
Find More Posts by WitnessOnly
Cleared for take off...
WitnessOnly's Avatar
Australia, VIC, Melbourne
Joined Jan 2010
With shrink on board
Seems spirits are still high though H I'm sure I'll be in a similar situation soon enough lol
WitnessOnly is offline Find More Posts by WitnessOnly
Old Oct 10, 2012, 06:29 AM
shelterock is offline
Find More Posts by shelterock
Fly, crash, rebuild.
United States, NY, Shelter Island
Joined May 2011
Ah yeah! Can't be an RC pilot if you can't deal with the destruction that comes with it. It made a great crunch when it hit the ground from 30 ft up. I wodded it up good. Surprised that the sections in the pivot mechanism didn't break on the main boards.
New arms long, medium, and a 306 servo on the way.
Only consolation is that it will rain for the rest of the week.
H
shelterock is offline Find More Posts by shelterock
Old Oct 10, 2012, 07:52 AM
tmproff is offline
Find More Posts by tmproff
Inverted Electric Flyer
tmproff's Avatar
United States, TX, Humble
Joined Jan 2004
Well I finally got my talon in the air last night. I have had a few quads and a few hex, but this is my first tri. I can't believe how well it flies and how stable it is. I wrapped LED's around the arms, and it's super bright at night....I went with the digital 306 and am very happy with that choice....
I did run into 1 problem with the KK2 board. When I first tried to get the tri off the ground it started spinning. I read that you had to reverse the yaw settings under MISC, but I missed the part where you had to change the channel in the upper left of the menu. After I figured that out, the default settings were amazingly stable.
tmproff is offline Find More Posts by tmproff
Old Oct 10, 2012, 12:20 PM
Joined May 2011
Well Done, It is a very satisfying to get in the air. What's your setup, motors, battery, props, esc etc...
H
Old Oct 11, 2012, 12:40 AM
thwaitm is online now
Find More Posts by thwaitm
Team WarpSquad
United Kingdom, England, Royal Leamington Spa
Joined Jun 2011
I got mine going as well.
I running KK2 with HK F30A simonk on 2200mAh Nanotechs
2 forward motors are NTM 28-26A 1200KV with 8045 Gemfans and
tail is 306 driven with a SunnySky 2212 980KV and 9045 Gemfan
I have had a couple of runs at tuning the KK2 and already it flies very well. I had to up the Yaw P to get the type of rudder response I wanted but all I need now is some time to get out and fly it and all the other things I have!
I have some drift rearwards on hard punch outs because the 980KV motor with 9045 isn't generating the lift of the two 8045 1200KV motors at the front. Haven't really tried it in autolevel yet though. That needed quite a bit of trim to stop a left drift - I'm suspecting that the motor power is a little different as everything looks pretty well levelled.
thwaitm is online now Find More Posts by thwaitm
Old Oct 11, 2012, 07:59 AM
eirikso is offline
Find More Posts by eirikso
Joined Dec 2011
Emptied five packs with my Talon Tri in the sunset yesterday.
Fornebu Tricopter Flights (1 min 49 sec)
Now it is rock solid on the Baseflight MultiWii.
My experience so far:
Yes, the motor mounts bend in any type of crash. So far I've just bent them back. A hard crash and the front arms are also a weak spot due to the slit in the arms that is needed because of the folding mechanism.
And I have killed one tail servo already. So order plenty of them...
But I absolutely love it. Takes a couple of seconds to unfold and fold back again. Fits nicely in a not too big suitcase and flies very, very well.
T-Motors 2216-11
9x5x3 Props
306 Digital Tail Servo
HK30A SimonK ESC
FF Baseflight MultiWii
4S 2200 TGY Nano
eirikso is offline Find More Posts by eirikso
Old Oct 11, 2012, 09:40 AM
tmproff is offline
tmproff's Avatar
Joined Jan 2004
I'm using NTM 2826 - 1000kv
10X4 CF (gemfan knockoffs)
KK2 Flight Controller
3s 3300 nano's or 4s 2200's
RCtimer 30A ESC (flashed simonk)
Old Oct 11, 2012, 11:59 AM
Bigmic is offline
Find More Posts by Bigmic
Bigmic's Avatar
Norway, Sogn og Fjordane, Askvoll
Joined Aug 2012
https://vimeo.com/51208704
T-Motors 2216-11
9x5x3 Props
HK30A SimonK ESC
4S 2200 TGY Nano
Hei Eirik. Kjempebra video du har lagt - er det Oslofjord?
Bigmic is offline Find More Posts by Bigmic
Old Oct 11, 2012, 12:19 PM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
Buddy Code for Turnigy H.A.L. Motor Mount Set
Should fit 14mm tubes. The H.A.L. has 14mm tube, just like the Talon V2.
TheFernMan is offline Find More Posts by TheFernMan
Old Oct 11, 2012, 10:01 PM
Joined May 2011
I rebuilt and added the LEDs. I'm curious if others are packing in servos with crashes. Eirik mentioned his servo problems. My rcexplorer tri after dozens of crashes never broke a servo. I wonder if elevated tail/ landing gear prevent the props from hitting the ground in a crash and sparing the servo. I'm thinking of mounting the motor under the tail mount plate to balance out the load, or at least lowering the cg on the pivot point, closer to the bearings. This may reduce the twisting forces on impact.
I guess we all need to fly better and avoid crashes by hey, where's the fun in that.
H
Old Oct 12, 2012, 07:12 AM
eirikso is offline
Joined Dec 2011
Yes. Oslofjorden from Fronebu.
Old Oct 12, 2012, 09:46 AM
Joined May 2011
Here's a quick picture of my Tricopter Talon all lit up with 3 strands of 60 LEDs each for 180 leds. Running off the 3S balance plug.
Description:
Old Oct 12, 2012, 05:22 PM
TheFernMan's Avatar
Joined Jul 2012
sorry for the spam but i need to sell these to support my addiction :P
I'm selling again some FLASHED HobbyKing F-30As 30amps here in the classified section.. Its on Pre-Order right now, but I ship fast and in the US it takes like 2 or 3 days. They'll be ready for the week of Oct 22.
I participate and follow this thread
Old Oct 14, 2012, 12:22 PM
HAM2 is offline
Find More Posts by HAM2
Sweden
Hi,
I think this will be the right spare for the landing and engine part of the tri-copter:
http://www.hobbyking.com/hobbyking/s..._Gear_Set.html
Magnus
HAM2 is offline Find More Posts by HAM2
Old Oct 14, 2012, 01:47 PM
TheFernMan's Avatar
Joined Jul 2012
Originally Posted by HAM2 View Post
Hi,
Magnus
Yes it is but its more expensive. The one i link should be very similar. I bought a few and will test. I have two broke motor mounts to replace and the Talon V2 mounts you linked are more money.
Talon V2 mounts $8.83 Buy three of these and its $26.49
HAL mounts $ 2.85* with Buddy Code. Buy three of these and its $8.55
Big Difference i think
Discussion Talon V2 or F450 Frame? solars Multirotor Talk 28 Nov 13, 2015 04:55 PM
New Product Turnigy Talon Carbon Fiber Quadcopter Frame CrashingDutchman Multirotor Talk 510 Jan 20, 2015 01:05 AM
Sold Turnigy Talon V2 Frame $30 / shipped **PRICE REDUCED pefozzy Aircraft - Electric - Multirotor (FS/W) 5 Sep 15, 2012 04:21 PM
For Sale Turnigy Talon Quad Frame V1 penz83 Aircraft - Electric - Multirotor (FS/W) 2 Jun 03, 2012 05:17 PM
Sold universal quad frame and tricopter frame dr rc Aircraft - Electric - Multirotor (FS/W) 4 Mar 07, 2012 07:26 PM
