Old Oct 09, 2012, 10:39 AM
tkouz is offline
Find More Posts by tkouz
Joined Aug 2004
Originally Posted by shelterock View Post
That's a software issue. Unless you can find a way to turn the servo in the other direction in the frame, hardware won't solve your problem.
Rabbit forum to see how you reverse a gyro is my guess.
H
I think it might be because the servo is analog and not digital, so it can be a response issue. The gyro is correct, and the blade rotations are all correct, if I use a digital servo, it might solve the issue I'm having. At first I thought it was not enough torque, so now I will look for a digital servo. Hopefully it should be ok.
tkouz is offline Find More Posts by tkouz
Old Oct 09, 2012, 10:49 AM
Bigmic is offline
Find More Posts by Bigmic
Bigmic's Avatar
Norway, Sogn og Fjordane, Askvoll
Joined Aug 2012
Hi guys,
sorry, but Im a noob here and I just ordred som parts from hk - that meens : 20A BlueSeries and NTM Prop Drive Series 28-26A 1200kv together with KK2.0 Multi-rotor LCD Flight Control Board for my Talon Tricopter.
Now my question: Is it a "must be" to flash the ESC with SimonK firmware or is it possible to program the esc`s with the R/C and: what are the differents in the flight? I ask, becaue i havent the hardware and no idea how to do this...
THX
Mic
Bigmic is offline Find More Posts by Bigmic
Old Oct 09, 2012, 10:53 AM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
THX
Mic
Its not required for flight BUT it makes a big difference in performance of your multirotor, kinda late but im selling some here
TheFernMan is offline Find More Posts by TheFernMan
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
You don't have to flash them, they just perform better if you do. However, DO NOT flash these. The 1200kv NTM motors are incompatible with flashed ESCs. You need to flash these with an alternate firmware.. Wii something, can't remember the name.
WiseDuck is offline Find More Posts by WiseDuck
Old Oct 09, 2012, 11:40 AM
TheFernMan's Avatar
Joined Jul 2012
the other firmware is called Wii-esc but simonk fixed the stall issue with his firmware 2012-09-30 here and here
Old Oct 09, 2012, 12:25 PM
Bigmic is offline
Bigmic's Avatar
Joined Aug 2012
Ok - Thank you guys
Old Oct 09, 2012, 02:19 PM
shelterock is offline
Find More Posts by shelterock
Fly, crash, rebuild.
United States, NY, Shelter Island
Joined May 2011
Originally Posted by R.T.K.F View Post
Hi Cew,
Just collecting info & parts while I wait for my talon frame to show up.
What Power Distribution Board are you guys using?
Cheers Brad.
Hi Brad,
I used the Hobbyking Quad Power distro and use 3 outpus for ESC and one for the KK2 voltage meter. I also plan to run my LEDs from there on 3S. I need to figure out what to do if I run 4S because that's too much for LEDs.
H
shelterock is offline Find More Posts by shelterock
Old Oct 09, 2012, 02:25 PM
Joined May 2011
Right, so, after all that soldering of leads and bullets to get everything in the 320mm arms, I proceeded to stuff it in the ground. I was chasing a Stintson Reliant in LOS. I have a flashing strobe LED on the tail for orientation. stupidly, I decided to fly with the longer arms, 320mm, before getting a lead extension for the LED., Lost orientation and crashed from 30 feet up. Not cool!! broke 2 props and 2 of the new arms. Motor mounts are ok.
So last night I got online to order new arms, and the Tricopter Parts section now offers 380mm arms with precut slots for the pivot mechanism. Sweet.
She flew great with the 320mm arms, rock steady. I'll edit some onboard video of my ContourHD camera zip tied on with no rubber isolation at all. Very good.
I'm warming up my soldering iron again!!
H
Old Oct 09, 2012, 02:26 PM
Joined May 2011
does anyone know if you can get 2mm or 2.3mm bullets past the pivot points in the front arms? I'm using 16 gauge wire to the motor - ESC connections and its a PITA to keep unsolder/soldering bullets to change the arms.
H
Old Oct 09, 2012, 05:39 PM
R.T.K.F is online now
Find More Posts by R.T.K.F
Return To Kit Form
R.T.K.F's Avatar
Australia, WA, Joondalup
Joined Oct 2010
Hi Brad,
H
Cheers H,
wouldve been nice if HK had put that in the part reqd list..
R.T.K.F is online now Find More Posts by R.T.K.F
Old Oct 09, 2012, 05:54 PM
Joined May 2011
Cheers H,
Nothing stops you from soldering 3 red and 3 black power leads together into an XT60 plug. That's what I did on my first tricopter. The XT60 plug has a u shaped channel that makes ot easy to solder large bundled wires.
I choose the power distro because the escs I have came off a hexa that burst into flames and wasn't confident that they were working properly. This allowed me to switches out gear easily.
H
Old Oct 09, 2012, 06:08 PM
WitnessOnly is offline
Find More Posts by WitnessOnly
Cleared for take off...
WitnessOnly's Avatar
Australia, VIC, Melbourne
Joined Jan 2010
H
H,
I was able to get 3.5mm through but 1 at a time was the only way, I used string to pull them through individually, 2 on one side of the locking arm and 1 on the other.
WitnessOnly is offline Find More Posts by WitnessOnly
Old Oct 09, 2012, 06:10 PM
Return To Kit Form
R.T.K.F's Avatar
Joined Oct 2010
Yeh H, I think I will probably go that way. Rob was kind enough to send an example to go off..
Is good to see another contourHD flying... haha
Old Oct 09, 2012, 06:28 PM
Joined May 2011
Originally Posted by WitnessOnly View Post
H,
Was that with or without shrink wrap? I guess I can practice all I want now that she's smashed up...
Ordered the 380mm arms too!
H
Old Oct 09, 2012, 08:43 PM
Joined May 2011
Well, my crash trashed my tail servo. I have another digital 26g from solar but its a clunker. She doesn't fit the plate without some serious grinding. I guess I have to order a 306!
H
Discussion Talon V2 or F450 Frame? solars Multirotor Talk 28 Nov 13, 2015 04:55 PM
New Product Turnigy Talon Carbon Fiber Quadcopter Frame CrashingDutchman Multirotor Talk 510 Jan 20, 2015 01:05 AM
Sold Turnigy Talon V2 Frame $30 / shipped **PRICE REDUCED pefozzy Aircraft - Electric - Multirotor (FS/W) 5 Sep 15, 2012 04:21 PM
For Sale Turnigy Talon Quad Frame V1 penz83 Aircraft - Electric - Multirotor (FS/W) 2 Jun 03, 2012 05:17 PM
Sold universal quad frame and tricopter frame dr rc Aircraft - Electric - Multirotor (FS/W) 4 Mar 07, 2012 07:26 PM
