Old Aug 24, 2012, 01:27 AM
DezertRangerN8 is offline
Find More Posts by DezertRangerN8
DezertRangerN8's Avatar
Joined Aug 2012
Idea
1/10 brushless motor in 1/16 erevo?
Anyone do it? I started to tonight but my motor was too long.
DezertRangerN8 is offline Find More Posts by DezertRangerN8
Old Aug 24, 2012, 08:22 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
You need a different motor mount to do it, the bolt holes on the 540 motor will be different than the stock 380 motor. You can either buy an aftermarket "big block" mount kit, or get the mount parts from the new brushed version that runs a 550 titan motor. I used the traxxas parts in mine. You'll need the blue mount plate that attaches to the gearbox, the plastic spur gear cover and the bare aluminum part that the motor bolts to.
wparsons is offline Find More Posts by wparsons
Old Aug 24, 2012, 09:21 PM
Joined Aug 2012
Sweet, I kind of altered mine to do it already. Just drilled some new holes. I have a grave digger 1/16 that uses the brush bigger motor. I see what you mean.
I might just order a new plate...might look a little cleaner...I'll post up some pics when I get it done.
It's going on a ken block talley car. Gonba be cool.
Old Aug 24, 2012, 11:00 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
You need the plate, aluminum motor mount and the spur gear cover, not just the plate. All the parts should be like $20 total though, not super expensive at all.
Old Aug 25, 2012, 11:38 PM
Joined Aug 2012
Yeah just ordered on line. 24 with shipping. This thing is going to be a blast when finished. Putting a castle 5700 motor and sidewinder esc now.
Old Aug 26, 2012, 08:41 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Good luck keeping all four wheels on the ground ever Mine would backflip easily under power, and I had it front flip a bunch of times under breaking.
Old Aug 26, 2012, 11:50 AM
Joined Aug 2012
It's going in my ken block 1/16 rally car. But if I'm able to pull it off, I'll put it in the 1/16 grave digger. It also helps A LOT to put in the center differential. Way easier to drive. It's actually hard to get it to wheelie now. I'm going to put a full size vxl-3s in there cause its my sons and sometimes he drives it through water and wet stuff...
Old Aug 26, 2012, 09:16 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
I found all mine did with the center diff was spin the front tires as the front unloaded. It would still accelerate a bit, but it would balloon the front tires up huge and not really move that fast comparatively.
Old Aug 27, 2012, 01:53 AM
Joined Aug 2012
Is this on your mobster truck or rally car?
I can understand that on the mobster truck. In the monster truck, I put foam in the tires helps big tine with handling. And I drive it in loose dirt mostly. I didn't think about the tires going crazy ballooning. 😳
Old Aug 27, 2012, 08:05 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Mine was the actual Mini E-Revo. The grave digger and rally cars aren't actually called e-revo's, even though the chassis is identical.
I'm really confused now, did you put a center diff in the grave digger? It's RWD only, so you definitely shouldn't do that. Now you're just unloading power to a non-existent front diff.
The rally should be fine, it sits too low to wheelie and will drive fine with either the locked center gear or a center diff.
Old Aug 28, 2012, 07:31 PM
Joined Aug 2012
On the monster truck... I added the 4wd. And put in a center diff. Drives good, ESP in loose dirt...
Can't wait till the motor mount comes.
I call them erevo cause they are the same chassis.
Old Aug 30, 2012, 08:12 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Same chassis, but confusing for anyone trying to help since traxxas actually sells a 1/16th scale e-revo, so people assume you're talking about that, not something based off that chassis.
Old Aug 31, 2012, 01:37 AM
Joined Aug 2012
Description: Name: ImageUploadedByTapatalk1346391345.724323.jpg
Description:
And of course I lost the pinion gear somewhere in my work truck. Gotta go get done tomorrow and then see how long it takes me to break this thing...
Old Aug 31, 2012, 02:27 AM
Joined Aug 2012
Description:
Have some wire shortening to do...
Old Aug 31, 2012, 04:32 PM
mansma is offline
Find More Posts by mansma
Joined May 2012
sweet
that is an awsome idea but get all meatel gears
mansma is offline Find More Posts by mansma
Sold traxxas erevo brushless edition, traxxas emaxx brushless, 1/10,1/16 traxxas summit boss777 Cars - Trucks and Parts (FS/W) 6 Jul 11, 2012 01:32 AM
Sold traxxas erevo brushless edition, traxxas emaxx brushless, 1/10,1/16 traxxas summit boss777 Cars - Cars and Parts (FS/W) 4 Jun 26, 2012 01:26 PM
For Sale Traxxas 1/16 Brushless Erevo (Summit Upgrades) bulldog0407 Cars - Trucks and Parts (FS/W) 3 Mar 24, 2012 10:35 PM
For Sale traxxas erevo brushless 2650kv upgraded @ brushless 1/16 erevo upgrads super nice boss777 Cars - Trucks and Parts (FS/W) 6 Sep 11, 2011 09:52 PM
For Sale traxxas erevo brushless 2650kv upgraded @ brushless 1/16 erevo upgrads super nice boss777 Cars - Cars and Parts (FS/W) 7 Aug 16, 2011 01:02 PM
