Old Jan 30, 2013, 07:57 PM
crazygary is offline
Find More Posts by crazygary
crazygary
United States, CA, Clovis
Joined Aug 2011
Thanks, Tom!! Will definitely keeo you posted as I progress!
Really like your choice of "goodies" for this build!! Makes it so much more appealing to those a bit too squimish to undertake such "frivolity"!! LOL
crazygary is offline Find More Posts by crazygary
Old Jan 31, 2013, 01:00 AM
tchalfant is offline
Find More Posts by tchalfant
tchalfant's Avatar
United States, NV, Las Vegas
Joined Aug 2011
I cannot take credit for the goodies, I learned about my Sombra Labs RX from forum.sub-driver.com - And my servo tester was inspired by the one that David Merriman used (although the one we own is much nicer looking - don't tell David he is a sensitive type LOL) and David showed the value in having a tester in one of his Cabal reports (or posting - getting old - not sure). I was pointed to a piston ballast system by Rick (the person I got the Aluminaut from) and just hacked around with different ideas.
Then there are those here and other sites that inspire me. As an example, ken_nj and his Marlin WIP. There are things he is doing that is inspiring me to try new things, some I will file away for later use. Good stuff.
tchalfant is offline Find More Posts by tchalfant
Old Jan 31, 2013, 06:32 AM
HeavyCruser9 is offline
Find More Posts by HeavyCruser9
HeavyCruser9's Avatar
Adelaide,Australia
Joined Dec 2009
Cool build !! Hasegawa just released (Nov last year) a 1/72 Research sub !! Would love to see some one build a working one!!
Cheers Bruce
HeavyCruser9 is offline Find More Posts by HeavyCruser9
Old Feb 03, 2013, 03:18 AM
tchalfant's Avatar
Joined Aug 2011
Bruce, I looked up that research sub, 5.4" long.....your killing me. I think it can be done. Must resist.........
You will see in this post that these ESCs are so small that I am able to pack them in the aft end of the sub - this really gives me room to put the ballast in and the rx.
I tested the little ESCs again because I did not check if they reversed or not. That would be a big mistake. Well it does go forward and backwards. The prop tracked straight - the pour shaft (which is still attached) waved wildly.
Name: Aluminaut research submarine 82.jpg
Description:
Made a means to bring in water - I could have taken an easy route and just used a straight pipe, but I opted to make it curve in.
Name: Aluminaut research submarine 83.jpg
Description:
Sealed the tube in with RTV silicon rubber. I will also use marine epoxy inside. Once the sealer dries, the tube will trimmed flush.
Name: Aluminaut research submarine 86.jpg
Description:
I coated the ESCs in liquid electricians tape because these were going to be stacked on top of each other. Once the liquid tape dried, the ESCs were bound together and given another coat of liquid tape to seal them as one nice package. And that package fits all the way in the aft end of the sub!
Name: Aluminaut research submarine 87.jpg
Description:
Old Feb 03, 2013, 07:00 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
very cool, i might have to get some of those esc's and other items from bidproduct.
i started another overambitious project over in the micro boats section.... but its going to be super simple so should be a straightforward build
derk is offline Find More Posts by derk
Old Feb 05, 2013, 01:23 AM
tchalfant's Avatar
Joined Aug 2011
Excellent Derk!
Filled around the brass tube with marine epoxy.
Name: Aluminaut research submarine 88.jpg
Description:
Pushed the ESCs back into the aft portion of the hull.
Name: Aluminaut research submarine 89.jpg
Description:
Took the Lepton 6 Servo out of it's box.
Name: Aluminaut research submarine 90.jpg
Description:
and coated it with liquid tape.
Name: Aluminaut research submarine 91.jpg
Description:
Carved out a notch on each side for the main board of RX to fit in. (Note: I painted the wire colors on the side for reference)
Name: Aluminaut research submarine 93.jpg
Description:
Nice fit.
Name: Aluminaut research submarine 95.jpg
Description:
Old Feb 06, 2013, 12:25 AM
tchalfant's Avatar
Joined Aug 2011
The ballast fits nicer than I thought. Man life is good!
Name: Aluminaut research submarine 96.jpg
Description:
Until you realize there is no way with this setup I can connect the servos.....
Name: Aluminaut research submarine 97.jpg
Description:
what to do......
Old Feb 06, 2013, 03:45 AM
derk is offline
derk's Avatar
Joined Dec 2003
you could make a wiring harness so everything shares power and just the signal sockets and 2 power connections go to the receiver. if you really needed to, you could shorten the receiver pins and use shorter sockets on the wires too, but then its limited for use later on.
Old Feb 06, 2013, 10:52 AM
tchalfant's Avatar
Joined Aug 2011
derk, I like your thinking! there are three thoughts going through my mind, one a harness like you described, I can flip the piston which interestingly offers an offset arrangement, or I could trim the pins (or replace the pins and make a vertical pin arrangement). Decisions.....
Old Feb 07, 2013, 02:45 AM
tchalfant's Avatar
Joined Aug 2011
derk, your idea won out. Originally, I thought of running wires, but did not think of using a common power and ground, just run the signal wires separate. That was a stroke of brilliance on your part. Thank you very much! My wiring went from 12 wires down to 6. As you can see wires begin to take up a lot of room. Thinner gauge would help, but the need to run fewer a big space saver. Still need a battery in there.
Name: Aluminaut research submarine 100.jpg
Description:
Name: Aluminaut research submarine 101.jpg
Description:
You can see that there could be as much as maybe 8mm in room if I trimmed the water inlet tube and the syringe nipple. The risk is the vinyl tube that connects the two will get dislodged by the piston ejecting water. So, it is there if I need to get drastic.
Name: Aluminaut research submarine 98.jpg
Description:
No matter all that needs to be done to free up space there are some things that have to be installed. One of those things are some support for the components and a means to tie them down.
Name: Aluminaut research submarine 99.jpg
Description:
Old Feb 07, 2013, 02:55 AM
tchalfant's Avatar
Joined Aug 2011
Originally Posted by tsenecal View Post
i highly recommend sombralabs for the receiver, if it will fit.
i have owned a 4 channel pico GWS, and now have 2 lepton6, 6 sl8, and 2 shadow7s (sl8 predecessor).
the GWS 4 channel receiver is smaller than the lepton6, but is a single conversion radio. in my SWM blueback, it was a very glitchy setup. an added bonus with the sombralabs is the programability of failsafes for all channels using their shadow programmer.
for a complete run-down on what is available from sombralabs:
http://sombralabs.com/products.php
tsenecal, I am sorry, I missed your post. Thank you for the information! We have a common friend in Denver and he speaks very highly of you. Hopefully, I will get a chance to meet you at one of the regattas up in Denver.
I recently found out that Sombra Labs will stop making 72/75 Mhz RX.
So, to all wanting to get one, better stock up now. I believe Mike Caswell (sub-driver.com) has some http://www.sub-driver.com/electronic...receivers.html
If you know of other sources please post!
Old Feb 11, 2013, 12:31 AM
tchalfant's Avatar
Joined Aug 2011
Been a busy weekend, but not on subs.
Secured the RX to the framework and tested the fit - it fit!
Name: Aluminaut research submarine 102.jpg
Description:
Began working on the wire harness and found out heat and the plastic holder do not mix. So, I learned to be a little more careful. I painted white on it to mark the channels the wires go to.
Name: Aluminaut research submarine 103.jpg
Description:
I got this Polk transmitter for my son. Trying to understand it.
Name: Aluminaut research submarine 104.jpg
Description:
Anyone know how to mix the throttle (Channel 3) with the rudder (Channel 1)? Reading the manual is hurting my brain!
Old Feb 12, 2013, 12:58 PM
tchalfant's Avatar
Joined Aug 2011
Tried to shorten the servo connector to the reciever to see if that would help.
Name: Aluminaut research submarine 105a.jpg
Description:
And it did not. Missed it by that much.
Name: Aluminaut research submarine 106.jpg
Description:
So went for a direct solder to the female pin.
Name: Aluminaut research submarine 107.jpg
Description:
Tht worked. I have a plan of action now!
Name: Aluminaut research submarine 108.jpg
Description:
Old Feb 13, 2013, 02:59 AM
derk is offline
derk's Avatar
Joined Dec 2003
on my mini sub, i skipped cutting the housing and went straight to soldered female pins and heat shrink
not much left to do on her now right? nearing maiden voyage?
Old Feb 13, 2013, 08:39 AM
tchalfant's Avatar
Joined Aug 2011
derk,
It is a learning curve for me. The only thing preventing me from finishing is getting the bench time. I am hoping this weekend, but the days are already getting filled up!
Peace,
Tom
Build Log HMS Diamond Type 45 1/96 Scale type45 Scale Boats 84 Mar 22, 2013 06:12 PM
Discussion Type 212 scale 1:96 MFR Submarines 19 Dec 28, 2012 12:54 PM
For Sale Deans Marine HMS Skirmisher 1/96 scale hampboats Boats (FS/W) 6 Jun 08, 2012 03:02 PM
Discussion 1/96 Aluminaut SilentHunter Submarines 7 May 31, 2011 07:13 PM
1/96 scale Russian Typhoon model for sale. Nemo Submarines 1 Aug 21, 2005 03:35 PM
