Old Oct 03, 2012, 02:09 AM
tchalfant is online now
Find More Posts by tchalfant
tchalfant's Avatar
United States, NV, Las Vegas
Joined Aug 2011
Originally Posted by profesorul View Post
HI,
CONGRATULATIONS.Man You have Skills and most of all PATIENCE!.Well done!.
I look forward to see him in the water.
What kind of motor are?;what are from?;how will resist in water?.
Thank you. is this Marius?
The motors are the coreless motors like the ones used in micro R/C helicopters.
I got these with the kit from Scale Model Castings, but you can find them just use Google.com and search on coreless motor.
How will it resist water? That is the best question......there are very tiny o-rings, super tiny, and that gets pushed down on the shaft between the propellor and motor. Liberal amount of silicon grease and we will see how it lasts.
@War Fish
Thank you Paul. You will be at the regatta in Texas this weekend right? Take lots of pictures!
tchalfant is online now Find More Posts by tchalfant
Old Oct 03, 2012, 04:31 AM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
the pager motors have the rear sealed and tight shaft tolerances, so water doesnt really hurt them. i ran my sub to around 4 feet depth and for several minutes at a time and those motors are fine without any extra sealing needed. if Rick added o-rings, i'd use them anyways for extra protection.
derk is offline Find More Posts by derk
Old Oct 03, 2012, 02:20 PM
tchalfant's Avatar
Joined Aug 2011
I mentioned earlier about when the arms were being built that I messed up the holes while pinning them. So in my brilliant way of thinking, I tried epoxy, that did not hold, so I thought (it gets more scary than this!) if I put a drop of solder on the broken hole, that would fix it..... I know that the casting white metal is a low temperature metal and somewhere I thought I could be under the the 500 degree F that I would be safe, well not so. I melted the piece. Later I will post pictures. I have a couple of ideas how to fix it, one is make a mold with the potters clay and cast a new arm (there was enough white metal on the sprue that I could do this) or two, get some square brass rod and fabricate it. I have a little time.
Old Oct 03, 2012, 02:57 PM
bgnome is offline
Find More Posts by bgnome
made of fire and pop rocks
bgnome's Avatar
Richmond Virginia
Joined Oct 2009
Any requests for close up pics of the real thing? I can probably get over to the museum on either Sunday or Monday.
bgnome is offline Find More Posts by bgnome
Old Oct 03, 2012, 06:01 PM
War Fish is offline
Find More Posts by War Fish
War Fish's Avatar
USA, TX, Cypress
Joined Aug 2005
Tom,
Yes, will be on patrol this weekend at Sun N Fun 2012. Anyone in the Houston area this Saturday is welcome to come out and see the subs at Hermann Park.
War Fish is offline Find More Posts by War Fish
Old Oct 03, 2012, 07:02 PM
tchalfant's Avatar
Joined Aug 2011
Bgnome, thank you! That is a very nice offer. If you are going, I do not see many pictures of the basket (too late for me, but others will thank you), more shots of the under carriage particularly near the front. Close up of the arms. I did my railing even, but one side does not match the other (that is another area I have seen a lot of changes) - the railings are stowed, all of the underwater shots that I have seen show the decks minus railings. Like the Gato, some people put railings on because that is how most of the pictures have them, but there are those that do not put them on because while on patrol they were stowed. I put railings on because I can! Sorry for the digress there, I know the light bar! Good shots detailing the corners, hinges, and how close or far from the bow cage protecting the cameras, that would help!!
Bgnome, if you don't make it that is O.K. No pressure alright?
Old Oct 06, 2012, 12:15 AM
tchalfant's Avatar
Joined Aug 2011
I attached the basket. I used silicon, but that held so-so. I used CA to assist in it holding on. That helped a lot, but even with those I have had to re-attach it twice. I may need to pin it on each side - like a brooch.
With that said here it is:
Name: Aluminaut research submarine 36.jpg
Description:
Name: Aluminaut research submarine 37.jpg
Description:
Name: Aluminaut research submarine 38.jpg
Description:
Old Oct 07, 2012, 06:26 AM
tchalfant's Avatar
Joined Aug 2011
I have arms!
I decided to use some square brass and make the replacement for the melted arm. I could have made a mold, cast the new arm, and life goes (several hours later) on or cut a piece of square brass, drill a couple of holes and your off and running much quicker.
Name: Aluminaut research submarine 39.jpg
Description:
I also trimmed back the two plates closer to the arms. It was easy to do, I just used my flush cutting diagonal pliers. then rounded the edges.
Name: Aluminaut research submarine 40.jpg
Description:
Now I will paint and create the beam detail.
Old Oct 08, 2012, 12:29 AM
tchalfant's Avatar
Joined Aug 2011
It was bothering me that I forgot to pickle the metal and the thought of another layer of paint made me shudder. So, I stripped most of the paint off and dipped it in ferric chloride acid to etch the surface. This gives a better bond to the primer and paint.
Name: Aluminaut research submarine 41.jpg
Description:
It is in the solution for only a few moments. You will see it slowly get darker. When you are done - no definitive answer on that one - I soak it in a water with sodium bicarbonate (baking powder). There will be a reaction of the acid still on the part and the water which has been made basic with the sodium bicarbonate. Swirl it around to make sure all the acid is neutralized. It will come out something like this.
Name: Aluminaut research submarine 42.jpg
Description:
Rinse in fresh water and let dry. Now it is ready for paint.
Also in the kit is some pierced brass, one narrow strip and two larger ones. These go on the undercarriage with the arms.
Name: Aluminaut research submarine 43.jpg
Description:
I used a piece of square brass that was the same size as the protrusion coming off the bow end of the keel (the protrusion is where the arms will attach). secured the pieces to the brass square. soldered the brass pieces together.
Will clean up and paint as well.
Old Oct 09, 2012, 09:18 PM
tchalfant's Avatar
Joined Aug 2011
Attaching the perforated cage and test fitting the arms, I noticed that the arms bracket was sticking out from the end. The first two thoughts that came in my head is considering narrowing the bracket or cutting the cage back. Then it came to me that I could cut two slices in the cage that would clip onto the bracket.
Name: Aluminaut research submarine 44.jpg
Description:
I also drilled a hole through the bracket and put a pin in to secure the arms.
Name: Aluminaut research submarine 45.jpg
Description:
Another view of the pin and cage.
Name: Aluminaut research submarine 46.jpg
Description:
I can not help but enjoy how this looks- exploring the deep.
Name: Aluminaut research submarine 47.jpg
Description:
More views.
Name: Aluminaut research submarine 48.jpg
Description:
Name: Aluminaut research submarine 49.jpg
Description:
I need to save up my pennies for the RX and to work on the ballast piston and the lenses for the viewing ports.
Old Oct 11, 2012, 11:01 PM
tchalfant's Avatar
Joined Aug 2011
Working on some more things to knock off and break.
The cage above the top of the cameras.
Name: Aluminaut research submarine 50.jpg
Description:
To the blurry left is the sonar (Sept. 13th posting) and on the right parts for the camera assembly. It was a whim to see if I could do this and it worked!
Name: Aluminaut research submarine 51.jpg
Description:
Here the parts are put together. I will clean up and paint.
Name: Aluminaut research submarine 52.jpg
Description:
When it is assembled, I will get more pictures.
Old Oct 13, 2012, 10:46 PM
tchalfant's Avatar
Joined Aug 2011
Added the sonar, top of camera cage, and the cameras.
Name: Aluminaut research submarine 53.jpg
Description:
Arms tucked in. I need to paint the pinchers silver.
Name: Aluminaut research submarine 54.jpg
Description:
Name: Aluminaut research submarine 55.jpg
Description:
I realized I have yet to work on the light bar! This will be fun!
Old Oct 16, 2012, 11:24 AM
tchalfant's Avatar
Joined Aug 2011
I need to re-do the top of the camera cage. I attached it to the dimple thinking that is what it was in the casting for, but my mistake. It actually gets attached to the edge of the deck as it begins the it's curve or another way to explain it is about 2mm above the dimple that I attached it to.
I see from another posting that you can get this sub for 20% off - that makes this kit $80 -I thought it was a fair price at $99 - now that is a deal!
Check it out http://www.scalemodelcastings.com/
Old Oct 16, 2012, 11:33 AM
Guard-Officer is online now
Find More Posts by Guard-Officer
Guard-Officer's Avatar
Canada, ON, Quinte West
Joined Feb 2009
I keep following this build wondering if I am adventurous enough to take on this little guy. It would look amazing to have on a cradle of my huge icebreaker and launch with one of the cranes. Then disappear below the waves!
You're really doing a great job on it tchalfant! I have decided I cannot solder well enough to take on making this functional!
I have a scale model castings kit I need to get started and do a product review for, so far all the castings look great, should be interesting to see it come together, I'll certainly keep an eye on your progress, this is a really neat looking unit!
Keep up the good work
Cheers
G-O
Guard-Officer is online now Find More Posts by Guard-Officer
Old Oct 16, 2012, 11:40 AM
profesorul is offline
Find More Posts by profesorul
profesorul's Avatar
BUCURESTI
Joined Feb 2009
HI,
@ tchalfhant,
THANKS a lot for the answer
profesorul is offline Find More Posts by profesorul
Build Log HMS Diamond Type 45 1/96 Scale type45 Scale Boats 84 Mar 22, 2013 06:12 PM
Discussion Type 212 scale 1:96 MFR Submarines 19 Dec 28, 2012 12:54 PM
For Sale Deans Marine HMS Skirmisher 1/96 scale hampboats Boats (FS/W) 6 Jun 08, 2012 03:02 PM
Discussion 1/96 Aluminaut SilentHunter Submarines 7 May 31, 2011 07:13 PM
1/96 scale Russian Typhoon model for sale. Nemo Submarines 1 Aug 21, 2005 03:35 PM
