Old Sep 14, 2012, 02:56 PM
tchalfant is offline
Find More Posts by tchalfant
tchalfant's Avatar
United States, NV, Las Vegas
Joined Aug 2011
Progress on the build (so far)
Name: Aluminaut research submarine 14.jpg
Description:
Got some basic painting done and began fitting parts together. Shoot forgot to take a picture of the ends, I will do that tonight.
tchalfant is offline Find More Posts by tchalfant
Old Sep 15, 2012, 01:36 PM
derk is online now
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
looking really good man! keep it up
derk is online now Find More Posts by derk
Old Sep 16, 2012, 03:41 AM
tchalfant's Avatar
Joined Aug 2011
Thank you Derk!
Let me take a step back, I jumped a little forward on the last post I did here.
I used Marine epoxy to attach the o-ring bulkhead to the bow end piece.
Name: Aluminaut research submarine 15.jpg
Description:
To do this with the o-ring installed, push the bulkhead into the body tube leaving about 2mm or so out then I carefully added a very thin solid bead of epoxy around the edge of the bow end piece that will mate with the bulk head and then a slightly thicker solid bead on the face of the bulkhead that will mate with the end piece. This bead is more on the inner part of the face. My thinking was I did not want this gushing out and spilling onto the tube and o-ring I would rather see it gush inward. By being sparing on the epoxy, when the two pieces were placed together, I could see a slight wetness along the edge. I placed the tube on a table and adjusted how it aligned by touch and eye. Left it to cure. To fully cure,the epoxy takes 24 hours, about 50 minutes to set. Then repeat for the other end. So far this was the most difficult part. Mess these up and your in for some work - so take extra care here, if you are going to build one.
Next I drilled a hole for the deck's motor wires to come in.
Name: Aluminaut research submarine 16.jpg
Description:
Since this deck will be attached to the aft end piece, I am going to put a couple of pins in to strengthen the joint. Something we did a lot of in the resin garage kit days. You can see the marks I made on either side of the hole for the wires.
Name: Aluminaut research submarine 17.jpg
Description:
This will get sealed with more marine epoxy. For those not familiar with subs do not use the 5 minute epoxy or even the 15 minute epoxy, these will get soft when exposed to full water and time. Look for the slower longer cures or like I am using a marine epoxy that is waterproof.
Earlier I mentioned about making the channels wider for the port and starboard motor wires, here is a picture of that.
Name: Aluminaut research submarine 18.jpg
Description:
The channel will be filled with some metal glaze body filler and the holes into the WTC will be filled with epoxy. That is the plan so far - I will let you know how that goes.
I could not help but put some parts together and noticed the tube was slightly longer than the parts.
Name: Aluminaut research submarine 19.jpg
Description:
Name: Aluminaut research submarine 20.jpg
Description:
I saw this in the dry fitting before painting, but thought it might have been my imagination and the fact that I was trying to hold things together by hand. Not a big deal,
Name: Aluminaut research submarine 21.jpg
Description:
I have two choices, fill with body filler the gap or trim the tube down. I will ponder on this because either choice has issues.
Still this thing is real cool. I am not sure how long the internal parts will take to come in from China, but I can't wait to see this work.
Name: Aluminaut research submarine 22.jpg
Description:
Old Sep 16, 2012, 12:47 PM
bgnome is offline
Find More Posts by bgnome
made of fire and pop rocks
bgnome's Avatar
Richmond Virginia
Joined Oct 2009
Heh.. I'm currently sitting about 2 miles away from the real thing!
the model looks nice!
bgnome is offline Find More Posts by bgnome
Old Sep 16, 2012, 01:59 PM
tchalfant's Avatar
Joined Aug 2011
Thank you... I would love to have the opportunity to visit some day. If you have a suggestion, please let me know! Any pictures you can share would help too!
Old Sep 16, 2012, 05:05 PM
bgnome is offline
bgnome's Avatar
Richmond Virginia
Joined Oct 2009
They have her parked behind the Science Museum of VIrginia, here in Richmond. Reynolds Metals, who built and owned her was Headquartered here ( once again.. right down the street from me..)
once the vessel was retired, they donated her to the museum as a static display. You can crawl around on her and stuff
Cant go inside it unfortunately.
I'll try to get some photos sometime.
Old Sep 18, 2012, 02:40 AM
tchalfant's Avatar
Joined Aug 2011
The deck railing was created out of brass. and if you look closely, you will see the pin from the deck to the bow. This is an alignment pin to keep the deck locked in. The pin is glued to the deck portion.
Name: Aluminaut research submarine 23.jpg
Description:
But I did not like the look of the rail it seemed a little too tall. Yep I measured it and it is 2mm too high. Out it comes.
Name: Aluminaut research submarine 23b.jpg
Description:
Here is version 2 of the railings ready to be painted.
Pins were placed in the aft end cap.
Name: Aluminaut research submarine 24.jpg
Description:
and another view.
Name: Aluminaut research submarine 25.jpg
Description:
there are corresponding holes on the deck
Name: Aluminaut research submarine 26.jpg
Description:
A little epoxy and wait
Name: Aluminaut research submarine 27.jpg
Description:
Old Sep 20, 2012, 11:02 PM
tchalfant's Avatar
Joined Aug 2011
To shorten the tube, I used 240 grit sandpaper in a flat surface and a little water.
Name: Aluminaut research submarine 28.jpg
Description:
Using marine silicon attached the keel and ballast tanks.
Name: Aluminaut research submarine 29.jpg
Description:
Name: Aluminaut research submarine 30.jpg
Description:
Just a thin layer of silicon to get it to stick. I will be interested in seeing how this sticks.
O.K. a little tape and we wait again....
Name: Aluminaut research submarine 31.jpg
Description:
Old Sep 21, 2012, 08:14 PM
tchalfant's Avatar
Joined Aug 2011
So, the remaining stuff to finish, railings, lenses (will make my own), front basket, create decals?? for sail, and touch up paint (maybe weather), I love the bleached out look on this one....
Description:
Then hopefully get to the innards and ballasting.
Any thoughts?
Old Sep 26, 2012, 07:23 PM
tchalfant's Avatar
Joined Aug 2011
Put the rails on. My first attempt at the cabling was to use a thinner gauge of brass wire. It looked bulky and out of place. So I found some wire from computer parts. It is thin (and I will probably break it a couple of times before it even gets wet!), but I think it is more scale looking. My uprights are a little thicker than I wanted.
Name: Aluminaut research submarine 32.jpg
Description:
Next it is time to make a basket.
Old Sep 26, 2012, 08:03 PM
ThorDesign is offline
Find More Posts by ThorDesign
Wichita, Kansas
Joined Jan 2004
Very nicely done, Tom!
ThorDesign is offline Find More Posts by ThorDesign
Old Sep 27, 2012, 12:00 AM
tchalfant's Avatar
Joined Aug 2011
Thanks Matt! Nowhere near the quality of your work, still fun none the less.
Old Oct 02, 2012, 03:33 AM
tchalfant's Avatar
Joined Aug 2011
Working on the basket.
Researching the basket, found out that there have been many changes during the Aluminaut's life. So, I settled more for the one on display (mostly).
Name: Aluminaut research submarine 33.jpg
Description:
If you look to the left on the arm of my bench, I have wrapped some painters tape with the sticky side out.
Name: Aluminaut research submarine 33b.jpg
Description:
I use this to hold parts while I am working and to keep the parts in place so they do not roll off. Another use I have found is to put a drop or two of CA then use a wire or toothpick to apply the CA from the drop to whatever. Cleanup is a breeze, slide it off and throw away. So shown is the beginning of the layup for the basket.
Name: Aluminaut research submarine 34.jpg
Description:
Slowly getting put together. Here it is with some mesh epoxied in.
Name: Aluminaut research submarine 35.jpg
Description:
Old Oct 02, 2012, 06:43 AM
profesorul is offline
Find More Posts by profesorul
profesorul's Avatar
BUCURESTI
Joined Feb 2009
HI,
CONGRATULATIONS.Man You have Skills and most of all PATIENCE!.Well done!.
I look forward to see him in the water.
What kind of motor are?;what are from?;how will resist in water?.
profesorul is offline Find More Posts by profesorul
Old Oct 02, 2012, 05:41 PM
War Fish is offline
Find More Posts by War Fish
War Fish's Avatar
USA, TX, Cypress
Joined Aug 2005
VERY nicely done, Tom!
War Fish is offline Find More Posts by War Fish
Build Log HMS Diamond Type 45 1/96 Scale type45 Scale Boats 84 Mar 22, 2013 06:12 PM
Discussion Type 212 scale 1:96 MFR Submarines 19 Dec 28, 2012 12:54 PM
For Sale Deans Marine HMS Skirmisher 1/96 scale hampboats Boats (FS/W) 6 Jun 08, 2012 03:02 PM
Discussion 1/96 Aluminaut SilentHunter Submarines 7 May 31, 2011 07:13 PM
1/96 scale Russian Typhoon model for sale. Nemo Submarines 1 Aug 21, 2005 03:35 PM
