Old Aug 31, 2012, 02:21 AM
tchalfant is offline
Find More Posts by tchalfant
tchalfant's Avatar
United States, NV, Las Vegas
Joined Aug 2011
Adam,
I am interested! I guess I need the what, how, and schematics.
This would be a really fun thing to work out!
Thank You!
Peace,
tom
p.s. sorry for the slowness on posting and moving forward - school started and I am really busy!
tchalfant is offline Find More Posts by tchalfant
Old Aug 31, 2012, 06:10 PM
thunderguts is offline
Find More Posts by thunderguts
Joined Nov 2010
Originally Posted by redboat219 View Post
New name for RPMTech...
Why did they change names?
thunderguts is offline Find More Posts by thunderguts
Old Aug 31, 2012, 08:23 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
probably because he moved to a new state, perhaps that name is taken where he moved to.
derk is offline Find More Posts by derk
Old Sep 01, 2012, 12:15 AM
tchalfant's Avatar
Joined Aug 2011
I'll take a guess, but it is just that, a guess. It reflects more of his focus...scale castings and not so much the technical part although he is very good at that. Rick....chime in anytime!
Old Sep 08, 2012, 05:13 AM
tchalfant's Avatar
Joined Aug 2011
Kudos to Adam for the code! You are a genius! Hope to chat again.
Quick update been putting long hours in at work, hopefully this weekend will include build time. I did scrub all the parts, Rick recommends brake cleaner, don't have any so I will go with good old fashion soap, water, and toothbrush.
Name: Aluminaut research submarine 06.jpg
Description:
Picked up some paint and ordered 3 esc
Still hoping to find a mini 75MHz RX.
Old Sep 09, 2012, 01:15 AM
tchalfant's Avatar
Joined Aug 2011
So scrubbed the parts and used 0000 steel wool to make sure oils and schmutz is off the parts.
Small parts need to be identified. I think I have two down.
Name: Aluminaut research submarine 07.jpg
Description:
The clear tube was washed with soap and water, then scrubbed with the steel wool.
before
Name: Aluminaut research submarine 08.jpg
Description:
After - nice even abrasion to give a hold to the paint.
Name: Aluminaut research submarine 09.jpg
Description:
I wrapped the tube with 240 grit sandpaper. Then ran the ballast/keel and deck over it to shape the part to the tube. The ballast/keel will be attached to the tube, the deck will be connected to the aft piece.
Name: Aluminaut research submarine 10.jpg
Description:
Then it is time to put the arms together.
Name: Aluminaut research submarine 11a.jpg
Description:
The parts are laid out and trimmed.
Brass wire is pushed through the holes pinning them together.
Name: Aluminaut research submarine 11b.jpg
Description:
That is such a nice detail!
Old Sep 09, 2012, 04:50 PM
War Fish is offline
Find More Posts by War Fish
War Fish's Avatar
USA, TX, Cypress
Joined Aug 2005
Tom, have you read "The Sun Beneath the Sea" by Piccard? It is his story about the Gulf Stream trip. Pretty interesting.
War Fish is offline Find More Posts by War Fish
Old Sep 09, 2012, 09:24 PM
tchalfant's Avatar
Joined Aug 2011
No, I haven't yet. The Aluminaut represents childhood memories from the 60s. I was so into sea bases and sea labs, Jacques Cousteau and anything that dealt with water, subs, and scuba diving.
Old Sep 10, 2012, 02:47 AM
craig_c is offline
Find More Posts by craig_c
Spreckels Lake, GGP, SF, CA
craig_c's Avatar
USA, CA, San Francisco
Joined Apr 2007
A "World Without Sun." What a movie!
craig_c is offline Find More Posts by craig_c
Latest blog entry: Ah, To be young again...
Old Sep 10, 2012, 08:35 AM
tchalfant's Avatar
Joined Aug 2011
Exactly!
Old Sep 10, 2012, 06:00 PM
War Fish is offline
War Fish's Avatar
USA, TX, Cypress
Joined Aug 2005
Same here. Piccard's book really tapped into that for me.
Old Sep 11, 2012, 12:17 AM
tchalfant's Avatar
Joined Aug 2011
World Without Sun by Jacques Cousteau (1 hr 32 min 22 sec)
sigh - got my underwater fix....
Old Sep 11, 2012, 06:54 PM
War Fish is offline
War Fish's Avatar
USA, TX, Cypress
Joined Aug 2005
Loved the soucoupe! "Octopoos, octopoos -- you're cheeldren are di-ying..."
Old Sep 12, 2012, 02:39 AM
tchalfant's Avatar
Joined Aug 2011
I do not know where my head was, but in the excitement I painted the little arms before I could pickle them. That may not have been such a big deal until you start nicking it up or apply heat (more on that later).
I cut two strips of brass about 4mm x 15mm and approximately .5mm thickness. About 2mm in from each end, along the center line, I drilled a small hole to match the brass rod supplied in the kit, sandwiched the arms in and soldered the wires to the holes.
Name: Aluminaut research submarine 12a.jpg
Description:
Unfortunately while trying to pin the brass wire, I split a side of two holes, bent several pins, and generally mucked things up. Next time I would do things different. I would put a blob of solder at the end of the wire. Pull it through the parts and drop a bit of solder on the other end. Then I could lightly tap the solder down to tighten the hinge, You can see the shiny dot on the hinge, it worked well here. Live and learn.
Name: Aluminaut research submarine 12b.jpg
Description:
And that is where the heat comes in, I made some of the paint bubble and come off while putting the blob on.
I ran the wires for the aft motors. Drilled a hole for the wires to run into the WTC. I will seal this with Marine epoxy later.
Name: Aluminaut research submarine 13.jpg
Description:
Ran the wires through the hole and (not shown) widened the channel where the wires from the motor run. I widened to give the wires room to lay flat.
Name: Aluminaut research submarine 13a.jpg
Description:
Old Sep 14, 2012, 01:29 AM
tchalfant's Avatar
Joined Aug 2011
A little build break - as I try to identify parts.
The original photo of small parts:
Description:
and here is where I think they go.
Description:
I am not sure where #4 goes. I have looked at Rick's build photos, but do not see it. To use #4 as deck to saddle tank brackets is courting trouble.
A shot of part #1 in real life,
Description:
And front piece that holds camera (?)
Name: camera bracket - noted.jpg
Description:
Here is an old Texaco ad
Name: AD Texaco.jpg
Description:
And a photo to use to detail the model's sail.
Name: Sail submarine 3.jpg
Description:
Build Log HMS Diamond Type 45 1/96 Scale type45 Scale Boats 84 Mar 22, 2013 06:12 PM
Discussion Type 212 scale 1:96 MFR Submarines 19 Dec 28, 2012 12:54 PM
For Sale Deans Marine HMS Skirmisher 1/96 scale hampboats Boats (FS/W) 6 Jun 08, 2012 03:02 PM
Discussion 1/96 Aluminaut SilentHunter Submarines 7 May 31, 2011 07:13 PM
1/96 scale Russian Typhoon model for sale. Nemo Submarines 1 Aug 21, 2005 03:35 PM
