Old Mar 26, 2013, 06:31 AM
Greg W is offline
Find More Posts by Greg W
AKA Mr Pita
United States, NY, Rochester
Joined Apr 2007
Hi Tom Great job. you can reverse your servos and limit your travels with the transmitter. Also float your foam in a cup of water and add wieght to the foam until it becomes nuetrally bouyant. This amount of wieght is the same as what you need to remove. Greg
Greg W is offline Find More Posts by Greg W
Old Mar 26, 2013, 11:32 AM
tchalfant is offline
Find More Posts by tchalfant
tchalfant's Avatar
United States, NV, Las Vegas
Joined Aug 2011
Greg! Thank you for the suggestion. I went the math route. I was told to figure out volume then convert that to weight.
LxWxH=Volume
0.875 x 0.4375 x 0.4375 = 0.1675 cu. inch
cu inch of water weighs 16.387grams
http://www.fourmilab.ch/hackdiet/www...1_4_2_0_7.html
16.37 x .1675 = 2.742 grams
I need to remove 2.74 grams of weight from the keel.
Removed the keel, benefit of using an RTV silicon.
It weighed 20 Grams. So if I took out 3.5 grams I can add weight if needed, but I will also be adding a light bar at some point.
Name: Aluminaut research submarine 139.jpg
Description:
Hollowed out the front were the foam was and worked my way back.
Name: Aluminaut research submarine 140.jpg
Description:
Cut open the sides were some scribing was for flood holes (the front is scooped out as an exit path too)
Name: Aluminaut research submarine 141.jpg
Description:
Weighed the bar and hit 3.5 grams removed on the nose!
Feeling like I can conquer the world, I went ahead and began adjusting the servo directions and limiting the throw.
Then...................
tchalfant is offline Find More Posts by tchalfant
Old Mar 26, 2013, 08:39 PM
tchalfant's Avatar
Joined Aug 2011
.....my world began to go up in smoke. Look carefully at the picture.
Name: Aluminaut research submarine 142.jpg
Description:
Yes, billowy, curling, wisps of electrical meltdown AGAIN!!!!!
I went to bed and today after work (I had cooled down significantly, trust me, this sub was almost in pieces) I went to investigate. This time it was the port motor. Here is what it looked like.
Name: Aluminaut research submarine 143.jpg
Description:
Interesting, it is the same location on the board that died previously. So, until I can conclusively rule out these are bad ESCs, DO NOT BUY THEM! I will contact the company I bought them from and see if there is any suggestions on their part.
Name: Aluminaut research submarine 144.jpg
Description:
So, after a brief email from David Merriman, I am going to put this to rest for a bit and work on the Skipjack and a ballast system I have been itching to play with.
The other thing that has happened is I received a sub as a gift from a friend, Mike Dory. Will post more about that later. I am taking David's suggestion and going to a movie (minus the drugs - from hip surgery) and going to relax.
This thread is not over, just on hiatus.
Peace,
Tom
I wonder if I should try a servo board.....stop.....must.....relax!
Old Jun 05, 2013, 11:45 AM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
So have you picked this guy up again?
derk is offline Find More Posts by derk
Old Jun 05, 2013, 03:35 PM
Aeroengineer1 is offline
Find More Posts by Aeroengineer1
Mesa Falcon Fld, Arizona, United States
Joined Sep 2004
I think that he is waiting for some slow poke to finish testing his new micro ESCs. Oh wait, I am that slowpoke. I am hoping to get the new code on them this week, and do the final testing. Once done, they should hopefully be smaller and not burn out like his last ones. They will even come with a low voltage detection.
Adam
Aeroengineer1 is offline Find More Posts by Aeroengineer1
Old Jun 05, 2013, 06:40 PM
derk is offline
derk's Avatar
Joined Dec 2003
would these mystery esc's be available in a small number for another aspiring submariner?
Old Jun 05, 2013, 08:00 PM
Joined Sep 2004
Derk,
See my reply here. I do not want to take away from Tom's thread.
Adam
Old Jun 05, 2013, 08:10 PM
tchalfant's Avatar
Joined Aug 2011
Take away from my thread, heck, my thread has been dead. You gave it a pulse! And a future. Put me down for one (at least for now).
Old Jun 05, 2013, 08:27 PM
Joined Sep 2004
Tom,
You will get a special discount on that one. It will be the lead device. It may be slightly used from my initial testing.
Old Jun 05, 2013, 11:47 PM
tchalfant's Avatar
Joined Aug 2011
Thanks for that, but I also want to support your effort, so put me down for 1 more.
Old Jun 06, 2013, 09:44 PM
thunderguts is offline
Find More Posts by thunderguts
Joined Nov 2010
All this free advertising for Aeroengineers stuff! WOW!
Hope he's added the real cost of it into his 'product'!
thunderguts is offline Find More Posts by thunderguts
Old Jun 06, 2013, 09:57 PM
Joined Sep 2004
Thunderguts,
The little speed controller is something that I am currently building for my own projects at home. Tom and I have been going forth about the possibility of them as replacements in his boat. This has been slowed by my real job and the arrival of my son. If there is not enough interest to have more than I am currently planning for Tom and my projects, I do not have hurt feelings as I have a controller for my project that I am working, and Tom gets his little boat in the water.
Adam
Old Jun 06, 2013, 10:03 PM
George Jure is offline
Find More Posts by George Jure
George Jure
Hamilton, Ontario
Joined Aug 2005
Hi Aeroengineer1
I would also be interested in your speed control offering. Please let me know if you go ahead with production.
George
George Jure is offline Find More Posts by George Jure
Old Jun 07, 2013, 02:28 PM
crazygary is offline
Find More Posts by crazygary
crazygary
United States, CA, Clovis
Joined Aug 2011
I'm also on board with your speed control endeavor, Aeroengineer1!
Please add me to your list of "supporters"!!
Crazygary
crazygary is offline Find More Posts by crazygary
Old Jun 07, 2013, 06:00 PM
Joined Sep 2004
George and Crazygary,
Thanks for your support, look to see updates in the other thread.
Adam
Build Log HMS Diamond Type 45 1/96 Scale type45 Scale Boats 84 Mar 22, 2013 06:12 PM
Discussion Type 212 scale 1:96 MFR Submarines 19 Dec 28, 2012 12:54 PM
For Sale Deans Marine HMS Skirmisher 1/96 scale hampboats Boats (FS/W) 6 Jun 08, 2012 03:02 PM
Discussion 1/96 Aluminaut SilentHunter Submarines 7 May 31, 2011 07:13 PM
1/96 scale Russian Typhoon model for sale. Nemo Submarines 1 Aug 21, 2005 03:35 PM
