This thread is privately moderated by askman, who may elect to delete unwanted replies.
Old Aug 23, 2012, 07:14 PM
Destroyer of G-10
askman's Avatar
Joined Jul 2004
How to modify a BLS950 servo for external potentiometer
instead of continuing my AV/AP beginner series, (which I will continue after this brief interlude) I bring you a How to article on modifying the BLS 950 servo for external potentiometer. Now, almost all higher end servo shares common trait, so you can use this article for them with appropriate changes for design percuilarity.
WARNING: The SOME OF THE BOTTOM PLATE OF THE BLS950 SERVO IS GLUED TO THE PCB ON AND IF IT DOES NOT POP OFF EASILY DO NOT PLY IT OFF. YOU CAN DAMAGE THE SERVO IF YOU USE FORCE TO TAKE THE BOTTOM OFF.
now, if you want to turn this into 360 continous servo instead of external pot, you don't have to cut the potentiometer wire. you need to remove the mechanical limit pin and the plastic pot turner off the bottom of the main gear. center the potentiometer and reassemble. that is all you need to do.
askman is offline Find More Posts by askman
Discussion How do I modify the trainer switch for Head tracking on Futaba TX? Kahnx Video Piloting (FPV/RPV) 6 Aug 03, 2012 12:59 AM
Discussion 130X modified into an external electronic speed controller glybytony Electric Heli Talk 1 Jul 20, 2012 02:34 AM
Discussion How can I modify a brushless esc to be controlled with a potentiometer? Steve Klyce Power Systems 5 Apr 15, 2008 06:19 PM
Discussion Modifying a TX channel for potentiometer control luckyflyer DIY Electronics 3 Aug 10, 2007 06:58 AM
How to modify a servo for 180 Degree? crux12 Aerial Photography 4 Jun 14, 2005 06:22 AM
