Old Dec 30, 2012, 12:37 AM
B_rad71 is online now
Find More Posts by B_rad71
B_rad71's Avatar
United States, CO, Hayden
Joined Oct 2011
Originally Posted by B_rad71 View Post
its goin in a foam scatch build, air frame will weigh around a 1.5 to 2 lbs. all electronics including batt is 2.5 lbs.
my flyfly f100 wieghs 9.3 but its on a 10 cell, retracts, drum brakes, epoxy, paint, ext..
B_rad71 is online now Find More Posts by B_rad71
Old Dec 30, 2012, 12:40 AM
viperviper is online now
Find More Posts by viperviper
Antarctica
Joined Apr 2012
Wow...
Put this 18 blader smartfan into your Flyfly.. it will stay on ground taxiing forever. lol.
viperviper is online now Find More Posts by viperviper
Old Dec 30, 2012, 12:44 AM
B_rad71's Avatar
Joined Oct 2011
Originally Posted by viperviper View Post
Wow...
thats what i had bought it for. changed my mind and went to a 12 blade rc lander from hk. 4000 watt. 10 . nice system.
Old Jan 20, 2013, 10:25 AM
D_FAST is online now
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
More info on this build can be found here.
Im B_rads bro, and designer/computer/3d guru of the build.
We had issues with the turnigy 90amp ESC and have sence went with Petes Signature series 115amp Opto on 6s
We are seeing 2300 watts @ 108 amps max. And the thrust Oh My!!!!
Current AUW with no paint 3lb 7oz
Yea @ 575w per pound it ll fly! or meet with terraferma fast
D_FAST is online now Find More Posts by D_FAST
Old Jan 20, 2013, 10:38 AM
Jacques.Eloff is offline
Find More Posts by Jacques.Eloff
Jacques.Eloff's Avatar
United Kingdom, England, Cobham
Joined Oct 2007
So, how much thrust, then? Would probably be even better with the CS 12 Blader, or a Midi.
Jacques
Jacques.Eloff is offline Find More Posts by Jacques.Eloff
Old Jan 20, 2013, 10:52 AM
D_FAST's Avatar
Denver CO
Joined Apr 2008
Havnt done thrust numbers with it installed. I can tell you this just a little over half throttle is 1 to 1!!!!! anything over half throttle sticks it to the ceiling!
Old Jan 22, 2013, 06:04 AM
Antarctica
Joined Apr 2012
hi ALL, Still waiting for someone to fit this 18 blader into Airframe and video! cheers!
Old Apr 04, 2013, 09:58 AM
D_FAST's Avatar
Denver CO
Joined Apr 2008
Looks like they got them back in stock. With a New CNC housing and different spinner
http://x-flight.com.hk/?sp=&p=6&cat2...w=&lang=en&ev=
Old Apr 04, 2013, 10:18 AM
DamonH is offline
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
Has anyone ever put this in an airframe. Most of the people seem to use them for paper weights.
DamonH is offline Find More Posts by DamonH
Old Apr 04, 2013, 11:05 AM
Angel RC Design is offline
Find More Posts by Angel RC Design
Angel RC Design's Avatar
United States, NJ, Weehawken
Joined Apr 2011
Did anyone try to use a lower kv, like1000kv,1200,.........I know jf90mm 0n 1200kv will do 4.9 to 5.3kg ,but that using 10s to 12.
Angel RC Design is offline Find More Posts by Angel RC Design
Old Apr 04, 2013, 03:38 PM
buckaroo is offline
Find More Posts by buckaroo
Banzai Institute
buckaroo's Avatar
United States, NY, West Seneca
Joined Oct 2005
That's the same housing they offer as a stand alone unit or coupled with the 12b. I checked with them and the housing itself weighs 270g. As far as I know I have seen no testing using that housing, even with the 12b. Assuming they got the stators wrong when they matched the 18b with the 12b housing than maybe the different stators on this new 18b will make a difference. The housing does claim room for a 42mm motor. Interestingly the add says "high thrust". That may or may not be the joke of the day.
Dean
buckaroo is offline Find More Posts by buckaroo
Old Apr 05, 2013, 06:57 AM
Antarctica
Joined Apr 2012
Still a dead weight at home.... buy at your own risk... not unless someone has install this motor combo into the airframe and prove that it can fly well...
Old Apr 05, 2013, 07:09 AM
Antarctica
Joined Apr 2012
YES!!! now it's my paper weight! WASTE of money.......
Old Apr 05, 2013, 08:11 AM
D_FAST's Avatar
Denver CO
Joined Apr 2008
http://www.rcgroups.com/forums/showp...3&postcount=39
Still waiting on a maiden.
AUW 3.5lbs loaded
95-100 amp on 6s
4.5lb thrust installed*static
I believe the 18 blade is more of a gimmick. Its not meant for high power outputs but instead for scale looks and sound.
Cant ever see this going beyond 6s
Now using other formulas/blade count options? you can get it there.
Trick is having a true spinner/collet
Old Apr 05, 2013, 08:17 AM
Antarctica
Joined Apr 2012
AUW 3.5lbs loaded
95-100 amp on 6s
Looks good. which motor?
For Sale (2) New 90MM ChangeSun 5 Bladed EDF Units $40 Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 3 Aug 06, 2012 12:37 PM
For Sale New ChangeSun 12 Bladed 90mm Fan Unit $40 Bucks Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 9 Jun 07, 2012 06:52 PM
Sold ARC 36/65/1 and ChangeSun 90mm fan fh64_lucky Aircraft - Electric - Jets (FS/W) 1 Oct 30, 2010 06:07 PM
Video ChangeSun 90mm-5 Fan Proedf-Jack Electric Plane Talk 0 May 27, 2010 02:00 PM
