Old Dec 26, 2012, 01:06 PM
UNABLE2SURF is offline
Find More Posts by UNABLE2SURF
Jet's are cool!
UNABLE2SURF's Avatar
United States, KS, Wichita
Joined Nov 2011
I had a crooked nut
X-flight responded to my email but I never received a nut as replacement! Last I checked X-flight wasnt selling these anymore?
UNABLE2SURF is offline Find More Posts by UNABLE2SURF
Old Dec 29, 2012, 12:22 AM
viperviper is offline
Find More Posts by viperviper
Antarctica
Joined Apr 2012
That's bad....
viperviper is offline Find More Posts by viperviper
Old Dec 29, 2012, 12:30 AM
v8truckin is online now
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
That's why mine stayed a Xmas ornament
v8truckin is online now Find More Posts by v8truckin
Old Dec 29, 2012, 04:28 AM
PAPE is offline
Find More Posts by PAPE
Joined Jun 2012
I did receive a new nut and spinner as I was told I would by xflight
PAPE is offline Find More Posts by PAPE
Old Dec 29, 2012, 07:29 AM
D_FAST is offline
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
Actually going to be running this one.
After balancing, we did a full run up on 6s getting somewhere around 4-5 lb thrust.
Total power system weight is 2.5lb inlcuding esc/fan/wires/lipo/reciever/servos/bec
into a 1.3 lb air frame. should be a bullet, very efficient and sound awesome at the same time.
D_FAST is offline Find More Posts by D_FAST
Old Dec 29, 2012, 03:04 PM
capt soap is offline
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
Looks good.Thanks for the update. put it in a airframe for us.
capt soap is offline Find More Posts by capt soap
Old Dec 29, 2012, 05:31 PM
Antarctica
Joined Apr 2012
Which motor did u use?
Old Dec 29, 2012, 10:43 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Originally Posted by viperviper View Post
Anyone has fitted this fan into the airframe and flew it?
Mine still in box...... paperweight....
Originally Posted by capt soap View Post
777 has.
Ya but never posted a video or anything showing, so no evidence.
Old Dec 29, 2012, 11:08 PM
B_rad71 is offline
Find More Posts by B_rad71
B_rad71's Avatar
United States, CO, Hayden
Joined Oct 2011
HK warhead 1850kv. pullin about 90amps. open
B_rad71 is offline Find More Posts by B_rad71
Old Dec 29, 2012, 11:14 PM
Antarctica
Joined Apr 2012
4-5lbs is kind of low in thrust for 90mm bird... which motor are u using? Pls advise. tks!
Old Dec 29, 2012, 11:23 PM
B_rad71 is offline
B_rad71's Avatar
Joined Oct 2011
HK warhead 1850kv. on a turnigy 85-100amp esc test on 3300mah 40c 6 cell. As for the thrust if its in a 4 lb plane then 4.5 to 5 lbs is more than enough.... Right?? moter, Esc And Batts Stay at good temp. good for 3 to 4 min run on that mah batt.
Old Dec 29, 2012, 11:28 PM
B_rad71 is offline
B_rad71's Avatar
Joined Oct 2011
HK warhead 1850kv. on a turnigy 85-100amp esc test on 3300mah 40c 6 cell. As for the thrust if its in a 4 lb plane then 4.5 to 5 lbs is more than enough.... Right?? moter, Esc And Batts Stay at good temp. good for 3 to 4min on that mah batt.(bench test)
Old Dec 29, 2012, 11:30 PM
Antarctica
Joined Apr 2012
Originally Posted by B_rad71 View Post
HK warhead 1850kv. on a turnigy 85-100amp esc test on 3300mah 40c. As for the thrust if its in a 4 lb plane then 4.5 to 5 lbs is more than enough.... Right?? moter, Esc And Batts Stay at good temp. good for 3 to 4 on that mah batt.
not sure, AUW for ARC 90mm F-18 foamy= 5.5-6lbs. L-59 composite = 6-8lbs.. both 90mm
Old Dec 29, 2012, 11:35 PM
B_rad71 is offline
B_rad71's Avatar
Joined Oct 2011
its goin in a foam scatch build, air frame will weigh around a 1.5 to 2 lbs. all electronics including batt is 2.5 lbs.
Old Dec 29, 2012, 11:37 PM
Antarctica
Joined Apr 2012
cool.. that's way enough thrust then.
For Sale (2) New 90MM ChangeSun 5 Bladed EDF Units $40 Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 3 Aug 06, 2012 11:37 AM
For Sale New ChangeSun 12 Bladed 90mm Fan Unit $40 Bucks Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 9 Jun 07, 2012 05:52 PM
Sold ARC 36/65/1 and ChangeSun 90mm fan fh64_lucky Aircraft - Electric - Jets (FS/W) 1 Oct 30, 2010 05:07 PM
Video ChangeSun 90mm-5 Fan Proedf-Jack Electric Plane Talk 0 May 27, 2010 01:00 PM
