Old Oct 13, 2012, 06:59 PM
UNABLE2SURF is offline
Find More Posts by UNABLE2SURF
Jet's are cool!
UNABLE2SURF's Avatar
United States, KS, Wichita
Joined Nov 2011
Hey ming !
Are you gonna add in the desrciption on the website that this fan it comes with a crooked nut and makes small amount of thrust at a very high amperage?
UNABLE2SURF is offline Find More Posts by UNABLE2SURF
Old Oct 13, 2012, 08:15 PM
davecrash is offline
Find More Posts by davecrash
Fly now crash later
davecrash's Avatar
Canada, ON, Newmarket
Joined Nov 2006
LOL @ 2surf
davecrash is offline Find More Posts by davecrash
Old Oct 13, 2012, 08:29 PM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
That is probably due to using the wrong motor/cell count combination.
scatsob is offline Find More Posts by scatsob
Old Oct 13, 2012, 08:55 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
scat
I was using a very stout 6s motor ARC 3675-1 1680kv on 6s .........here's the problem as I see it............32k rpm 2.3-2.5kg thrust........so it doesnt matter what the amps/watts were/are.........so now it looks like this fan needs to be spun to 40k rpm to get some real thrust out of it, can it hold up to that?......what will the amp load be?............is there even a 36mm motor that can do it?....this is where we are at with this one.........hopefully I'm wrong it is still early
jcdfrd is offline Find More Posts by jcdfrd
Old Oct 13, 2012, 08:59 PM
PAPE is online now
Find More Posts by PAPE
Joined Jun 2012
Originally Posted by jcdfrd View Post
scat
I was thinking of dishing the alloy shroud just for that very reason. The thing is the rotor will has to be sanden down to fit most other shrouds. That way a larger outrunner with good torque can be used.
PAPE is online now Find More Posts by PAPE
Old Oct 14, 2012, 03:13 AM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Originally Posted by PAPE View Post
any updates?
Has any one flown the the fan?
I have, capt soap was there as witness...but again, it was with the haoye shroud
erh7771 is online now Find More Posts by erh7771
Old Oct 14, 2012, 03:15 AM
Joined Nov 2005
Put it in a haoye shroud, they cost of the fan is 20usd...used the upper lip of the CS metal shroud for easiest adaptation...
Worth a try
Old Oct 14, 2012, 04:33 PM
PAPE is online now
Joined Jun 2012
And when in the air what were your thoughts. Were you like "oh that sounds nice and has a good punch". Or were you like " well it sound the same as the 12 blade one and has no power at all, I am puting this fan in the trash".
Old Oct 14, 2012, 10:33 PM
capt soap is offline
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
I did see 777 fly his f100 with the cs-20 at the time. It flew with alot of zip. the Sound was different than the cs 12..... I had to have one. When my finances recover I will get another. Lee
capt soap is offline Find More Posts by capt soap
Old Oct 23, 2012, 06:25 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
so I got my new scale for my sled and reran a test. I threw the 18 blade together and mounted it up, charged my 6s 40c 4000 batt and here's what i got after 10sec run
100amps (cc data log and dc amp clamp agreed)
20vdc
32k rpm
2k watts
2.5+kg thrust
so looks a lot better, obviously a problem with my scale was causing an issue. I guess I need to rerun some tests
Old Oct 23, 2012, 06:29 PM
Joined Nov 2005
I confirmed today the numbers I posted up thread...
~ 6lbs of thrust around 2000 watts...
I've written x-flight about the lander stators, prolly needs another shroud....
I've not tested with the 9blade design yet
Old Oct 23, 2012, 08:22 PM
Jet's are cool!
Joined Nov 2011
so i got my new scale for my sled and reran a test. I threw the 18 blade together and mounted it up, charged my 6s 40c 4000 batt and here's what i got after 10sec run
20vdc
32k rpm
2k watts
2.5+kg thrust
so looks a lot better, obviously a problem with my scale was causing an issue. I guess i need to rerun some tests
that was with the arc 1680 kv ? Thinking about ordering a HET 650-68 1500kv so just keeping the thoughts in my head straight. Believe me that's really hard LOL!!!!
Old Oct 23, 2012, 11:17 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
yes the arc 3675-1 1680kv
Old Oct 24, 2012, 08:09 AM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
20vdc
32k rpm
2k watts
2.5+kg thrust
Still not as much thrust as the 12 blade version.
4stripes is offline Find More Posts by 4stripes
Old Oct 24, 2012, 10:51 AM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
what sort of thrust is typical on 6s with the 12blade?
For Sale (2) New 90MM ChangeSun 5 Bladed EDF Units $40 Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 3 Aug 06, 2012 11:37 AM
For Sale New ChangeSun 12 Bladed 90mm Fan Unit $40 Bucks Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 9 Jun 07, 2012 05:52 PM
Sold ARC 36/65/1 and ChangeSun 90mm fan fh64_lucky Aircraft - Electric - Jets (FS/W) 1 Oct 30, 2010 05:07 PM
Video ChangeSun 90mm-5 Fan Proedf-Jack Electric Plane Talk 0 May 27, 2010 01:00 PM
