Old Oct 07, 2012, 02:35 PM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
3300watts for 5 1/2 lbs of thrust ?
Not very good. The CS 12 blade does much better than that.
4stripes is offline Find More Posts by 4stripes
Old Oct 07, 2012, 02:45 PM
UNABLE2SURF is offline
Find More Posts by UNABLE2SURF
Jet's are cool!
UNABLE2SURF's Avatar
United States, KS, Wichita
Joined Nov 2011
My personal opinion
I should have bought an HET motor instead of this fan.
UNABLE2SURF is offline Find More Posts by UNABLE2SURF
v8truckin is offline
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Exactly why I don't think the sound vs thrust is that great and why I will continue to use the CS12.
v8truckin is offline Find More Posts by v8truckin
Old Oct 07, 2012, 02:52 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
I got 5.5lbs of thrust at around 1300 watts...I'll be confirming these numbers next week.
5.5lbs of thrust at 3300 watts...there's something off somewhere
erh7771 is online now Find More Posts by erh7771
Old Oct 07, 2012, 02:56 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
thought that said 5.5lbs for 2300w, ya something isnt right there. Although I didnt get those #'s @ 1300w, more like 2200-2300w (#s just off the top of my head).
1300W? Whats taking you so long to post your motor type, kv, and static #s? youve had this fan the longest?
Old Oct 07, 2012, 03:28 PM
Jet's are cool!
Joined Nov 2011
My thrust stand is made with one ball bearing drawer slide and a cheapo HK scale, those #'s probably not very good. My watt meter is a Gt power. It is plugged in between motor and battery with 4mm bullets. The only other thing I can say is when I tested my CS10 with the eflite bl32 2150kv my #'s were right along what others had got. I am not trying to mislead anyone thats just what I observed
Old Oct 07, 2012, 03:32 PM
4stripes is offline
4stripes's Avatar
Joined Jan 2009
4mm bullets are not good enough for +100amps. They will burn up.
Old Oct 07, 2012, 03:33 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
My #s were in the airframe so im thinking id have more thrust to watts ratio outta the plane and on a test stand. Yikes 4mm...no bueno. I only use 4mm on 4s and below.
Old Oct 07, 2012, 03:39 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
I think you guys need to put in a plane and fly it. Make your judgement on how it is going to be used, in the air. Since you guys have at least proved it won't blow up! The bench numbers are all over the place.
Just my opinion.
Kevin Cox is offline Find More Posts by Kevin Cox
Old Oct 07, 2012, 03:49 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Just my opinion.
Im affraid I fly it then crash it!
Old Oct 07, 2012, 04:03 PM
Kevin Cox's Avatar
Joined Jan 1997
LOL...fair enough
Old Oct 07, 2012, 06:30 PM
PAPE is offline
Find More Posts by PAPE
Joined Jun 2012
Well thanks for trying out the 1900KV on the 18blade set up, and if your test on other fans show numbers in line with other test, then all the low numbers are correct. The only thing that I think is missing is to test the fan unit with the rotor buried further into the shroud so the blade tips are not on the edge of the lip.
PAPE is offline Find More Posts by PAPE
Old Oct 07, 2012, 07:12 PM
Jet's are cool!
Joined Nov 2011
Yeah I know that, but you have to test first. I didnt know how many amps it would draw before the test. The bullets wont burn up during a 20 second test! They did not even get warm. I also run the same ones in my Dynam Me-262 and it pulls like 120 amps, had many successful flights. If I ever run this fan it will be around 85-90 amps any more just causes problems, now just to figure out what motor that will be. Anyone else want to test I am anxiously awaiting more results.
Old Oct 07, 2012, 08:51 PM
Jet's are cool!
Joined Nov 2011
No problem, I was hoping the #'s would have been better but thats what I got. Someone else might get something different, since everyone uses different methods. The only thing I could improve is the balance, but that is probably at most 10% difference.
Old Oct 07, 2012, 09:38 PM
PAPE is offline
Joined Jun 2012
Well after reading your post I went ahead and disassembled the spinner and saw the nut your talking about. mine is a bit of center but completely crooked . also the spinner whole is all lop sided. I am really starting to regret Buying this fan.
I'm going to take some pics with my good camera and post them give me a few minutes.
For Sale (2) New 90MM ChangeSun 5 Bladed EDF Units $40 Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 3 Aug 06, 2012 11:37 AM
For Sale New ChangeSun 12 Bladed 90mm Fan Unit $40 Bucks Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 9 Jun 07, 2012 05:52 PM
Sold ARC 36/65/1 and ChangeSun 90mm fan fh64_lucky Aircraft - Electric - Jets (FS/W) 1 Oct 30, 2010 05:07 PM
Video ChangeSun 90mm-5 Fan Proedf-Jack Electric Plane Talk 0 May 27, 2010 01:00 PM
