Old Oct 02, 2012, 04:37 PM
Chuchuf is offline
Find More Posts by Chuchuf
Carboweave, Ask For It By Name
Chuchuf's Avatar
United States, GA, Atlanta
Joined Aug 2009
Originally Posted by AirX View Post
The reason may be the blades are too close together causing the flow rate thru the rotor to drop, the lower blade counts seem to confirm this.
Eric B.
That's what I'm thinking.....
Terry
Chuchuf is offline Find More Posts by Chuchuf
Old Oct 02, 2012, 07:01 PM
PAPE is online now
Find More Posts by PAPE
Joined Jun 2012
Won't air speed overcome this, and load the fan to the point the 18blades bite more air and produce more thrust?
PAPE is online now Find More Posts by PAPE
Old Oct 02, 2012, 08:47 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Hmmm, mine in air was like this on the bench the static thrust numbers weren't great after 1800 watts.
I couldn't tell any real difference in speed in the airframe it was in...
regards
erh7771 is online now Find More Posts by erh7771
Old Oct 03, 2012, 03:39 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
As it turns out so far the v2 cs fan is worse than the cs12 performancewise
pavcon is offline Find More Posts by pavcon
Old Oct 03, 2012, 06:27 AM
viperviper is offline
Find More Posts by viperviper
Antarctica
Joined Apr 2012
Eric B.
i guess the best way is to test it in flight.....
Will wait if anyone can testflight and let us know...looking forward!
viperviper is offline Find More Posts by viperviper
Old Oct 03, 2012, 08:04 AM
wingspan100 is offline
Find More Posts by wingspan100
Lookout For The!Radio Silence.
wingspan100's Avatar
United States, AZ, Scottsdale
Joined Nov 2007
What a great idea!
wingspan100 is offline Find More Posts by wingspan100
Old Oct 03, 2012, 02:37 PM
UNABLE2SURF is offline
Find More Posts by UNABLE2SURF
Jet's are cool!
UNABLE2SURF's Avatar
United States, KS, Wichita
Joined Nov 2011
just got mine!
I would like to preface this by saying that I am not that experienced in EDF's. I have 3 70mm jets Airfield f-16, Tomahawk Viper and a Dynam Me-262. All have CS 10's with different motors. I love the sound of the CS fans. I also have 2 jetfan 90's, only one of which is installed and flying. After taking this "SMARTFAN" out of the box, it initially looks very nice, but two things stick out very glaringly to me. I acknowledge these have already been brought up. The first thing is the rotor shroud gap....WOW. Measuring from the middle of one blade to 180 degrees the other side is 89.49mm. The I.D. of the shroud is 92.80-84mm. The second is how flexible the 18 blades are. To me they are way more flexible than the CS 10 and not even in the same universe as the Jetfan. I bought this before seeing JCFRD's test #s and I regret doing that. In my humble opinion I think the only way this fan will make decent power is with the 9 blades they are much stiffer but will probably not sound as good as the CS 12. This is just my humble opinion, I hope that I am proven wrong.!
UNABLE2SURF is offline Find More Posts by UNABLE2SURF
Old Oct 03, 2012, 02:41 PM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
The Eurofighter that V8 used is bifurcated and he has yet to fly it. The multi blades seemed to do well with bifurcated so it may be the same here or do better dynamically with a different exhaust, smaller or larger. Like it was said, try it and fly it to confirm where it may fit in.
Maxthrottle is offline Find More Posts by Maxthrottle
Old Oct 04, 2012, 05:31 AM
PAPE is online now
Joined Jun 2012
Can anyone how has flown the 18blade fan and the old cs12 fan, compare the sound of both fans in the air? Is the sound of the 18blade fan better than the cs12, or are they around the same?
Old Oct 04, 2012, 09:54 AM
v8truckin is offline
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
I'm still working on getting mine tuned and running smooth, it proving frustrating. I'll post a vid asap. But by my #s and JC's #s doesn't look to be good thrust wise vs the Cs12 so the only advantage it may have is sound.
v8truckin is offline Find More Posts by v8truckin
Old Oct 04, 2012, 10:17 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Can't upload to YouTube via my phone so here's a windows SkyDrive vid,sorry.
https://skydrive.live.com/redir?resi...FYV7WYd414u7AU
Early test
1700kv CS18 static sound test lil vibration
Old Oct 04, 2012, 04:04 PM
PAPE is online now
Joined Jun 2012
but dint you get the same thrust on the cs12 and the cs18 on the eurofighter around 2.5k on both fans with lower amps on the cs18?
Old Oct 04, 2012, 04:10 PM
PAPE is online now
Joined Jun 2012
Early test
thanks for the vid, you are geting a lot of resonance throug the airframe try mounting the fan isolated from the hard wood block with some ruber gormets. that way the frame wont amplify the resonance from the fan.
Old Oct 04, 2012, 05:03 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
close just a lil less thrust on the cs18 on less amps and watts.
Old Oct 04, 2012, 05:06 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
ya the resonance was prevalent. The fan was basically secured by the dbl sided tape and the motor hatch. So it wasn't totally balanced perfectly also. Didn't want to post vid because it wasn't that great but i was just trying to show it sounded different than the cs12 regardless of the resonance.
For Sale (2) New 90MM ChangeSun 5 Bladed EDF Units $40 Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 3 Aug 06, 2012 11:37 AM
For Sale New ChangeSun 12 Bladed 90mm Fan Unit $40 Bucks Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 9 Jun 07, 2012 05:52 PM
Sold ARC 36/65/1 and ChangeSun 90mm fan fh64_lucky Aircraft - Electric - Jets (FS/W) 1 Oct 30, 2010 05:07 PM
Video ChangeSun 90mm-5 Fan Proedf-Jack Electric Plane Talk 0 May 27, 2010 01:00 PM
