Old Sep 25, 2012, 11:06 PM
Thomas Nelson is offline
Find More Posts by Thomas Nelson
Thomas Nelson's Avatar
Calgary, Alberta, Canada
Joined Sep 2002
How does $10.00 shipped sound? I have this one from DealExtreme and it is perfectly adequate for this kind of application.
tn
Thomas Nelson is offline Find More Posts by Thomas Nelson
Old Sep 25, 2012, 11:08 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
hey v8 did yours have top and bottom washers seperate from the adapter? because there is no way you could do the whole assembly on a static balancer with the one I got
jcdfrd is offline Find More Posts by jcdfrd
Old Sep 25, 2012, 11:12 PM
v8truckin is offline
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Mr. Nelson,
Thank you for that link I just ordered one! Can't beat that price.
v8truckin is offline Find More Posts by v8truckin
Old Sep 25, 2012, 11:15 PM
Joined Sep 2002
I know! Crazy cheap, and yet functional!
v8truckin's Avatar
United States, CA
Joined Dec 2010
Hmmm... Can't remember if it did. I'll check it out tmrw and let you know person that was going to take it from me flaked so imma hold onto it and mess with it off and on.
Old Sep 25, 2012, 11:39 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
When I looked for a scale I came across this in the Composites Fabrication forum. I think most all these scales are the same, but check it out, it worked for me.
http://www.rcgroups.com/forums/showp...1&postcount=27
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Sep 26, 2012, 12:13 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Deleted
Old Sep 26, 2012, 01:47 PM
Joined Sep 2002
Mean to also say you should also consider getting their 5 gram calibration weight. Gives a bit of confidence in the thing.
tn
Originally Posted by v8truckin View Post
Mr. Nelson,
Old Sep 26, 2012, 01:52 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
I usually just use a nickel and qrt to calibrate.
Old Sep 26, 2012, 03:16 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
its really only critical that all blades weighed are exactly the same weight
Old Sep 26, 2012, 05:39 PM
Joined Sep 2002
Agreed.
Problem is these cheapies can drift a bit over time and temp. A fixed weight (any weight, really) that you can come back to will verify that your qualitative measurements are valid. For example I've seen a 0.02 gram variance over the course of 15 minutes.
Make sure you aren't breathing on it as you use it!
Old Sep 26, 2012, 06:29 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Another assembly is being sent out to me now so will be able to run it up in my 5 stator alloy housing soon as it arrives. Looking forward to running the 18 blade configuration!
Extreme_RC is offline Find More Posts by Extreme_RC
Old Sep 26, 2012, 07:02 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
jc,
there is a bottom and top washer that keep the blades together the shaft adapter is seperate.
Old Sep 26, 2012, 07:58 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
not on mine, I thought maybe it was just tight fit but no its one piece, at least the one I received
ok well when you get our scale then just get all blades equal weights and try again.
well I am throwing together a thrust test stand to play with this fan so should have some numbers pretty soon..... I hope
Old Sep 26, 2012, 08:10 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
It may be a tight fit. Okay hard to explain...circular portion that houses the grub screws and the circular portion above that ate one piece. The next circular aluminumportion that is flush with the blades is the washer. I had to put it in an aluminum vice just wider than the circular portion above the grubs screws, not the washer that is flush with the blades. I slowly tapped it with a rubber mallet and it slid out.
For Sale (2) New 90MM ChangeSun 5 Bladed EDF Units $40 Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 3 Aug 06, 2012 11:37 AM
For Sale New ChangeSun 12 Bladed 90mm Fan Unit $40 Bucks Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 9 Jun 07, 2012 05:52 PM
Sold ARC 36/65/1 and ChangeSun 90mm fan fh64_lucky Aircraft - Electric - Jets (FS/W) 1 Oct 30, 2010 05:07 PM
Video ChangeSun 90mm-5 Fan Proedf-Jack Electric Plane Talk 0 May 27, 2010 01:00 PM
