Espritmodel.com Heli Air
Old Aug 23, 2012, 02:31 PM
DELTAS RULE
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
its a awesome idea for sure. but it looks like the jetfan blades were copied for thier low pitch blades. the high pitch blades look like a original design.
corsair nut is offline Find More Posts by corsair nut
Old Aug 23, 2012, 02:33 PM
Gorilla Glue Expert
PikeStaff's Avatar
United States, PA, Doylestown
Joined Sep 2010
Originally Posted by erh7771 View Post
It's 18 blades,
Spin 10 blades at 150k rpm max (for turbine) or spin 18 blades at 70k rpm (or close) and the white noise coming off the blades is loud and very realistic.
? - Hah? Can't wait to see amp draw on this. Also can't wait to see motor selections here.
PikeStaff is online now Find More Posts by PikeStaff
Old Aug 23, 2012, 02:38 PM
AirscapeRC.com
Air-Jon's Avatar
CA
Joined Oct 2006
Oh...I see what you mean Corsair nut. I just noticed the different pitch blades. I see the ones that looks JetFan style...and the other blades look Arson style. Just a coincidence right.
Air-Jon is offline Find More Posts by Air-Jon
Old Aug 23, 2012, 02:44 PM
AirscapeRC.com
Air-Jon's Avatar
CA
Joined Oct 2006
It will be a long month to wait to get one of these!
Old Aug 23, 2012, 02:49 PM
capt soap's Avatar
dallas tx
Joined Jun 2003
these are not a arson copy. ive seen them in a flying buddy's jet. he' had it a while. When i get out off the hospital, i can post some pic's. Lee
capt soap is offline Find More Posts by capt soap
Old Aug 23, 2012, 03:05 PM
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Lee,
Heres the Arson
http://www.rcgroups.com/forums/showthread.php?t=1715858
Hope u get better
v8truckin is online now Find More Posts by v8truckin
Old Aug 23, 2012, 03:22 PM
“Do it Right The First Time!”
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Here's some possible options, depending whats required.
http://fightercatracing.com/index.ph...chk=1&Itemid=1
I'v been eyeing up the 4092, listed Kv's are too high for what I need, but e-mailed them for special order on1250Kv. It would be a monster on 12s! Just have to wait and see.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Aug 23, 2012, 08:10 PM
Not enough hours in the day
Slaanesh's Avatar
Melbourne
Joined Feb 2009
Very nice... X-flight and RC-Castle getting these first? Hobbyking?
Slaanesh is offline Find More Posts by Slaanesh
Old Aug 23, 2012, 08:25 PM
AirscapeRC.com
Air-Jon's Avatar
CA
Joined Oct 2006
Will there be an 8mm shaft option?
Ming's Avatar
Hong Kong
Joined Jun 2002
Tooling was done few months ago, couple time of adjustment and fine trim on tooling. We also send few samples to tester for testing couple time ago, but we ask them don't to disclose until new product announcement. I think everyone have similar idea on their mind, right? but someone make it happen faster than other, that simple.
Ming Lou
Ming is offline Find More Posts by Ming
Site Sponsor
Old Aug 23, 2012, 08:59 PM
Atlanta, GA
Joined Feb 2009
It's 18 blades,
I have it in my Fly Fly F100...
Don't want to let numbers out yet...
I ran mine with rounded intake lip and the white noise is as loud as I've heard out of any fan even without an intake lip.
With a very balanced rotor the turbine high frequency like whistle can be heard at lower RPMs also so when you're taxing the sound is VERY VERY nice depending on motor of course and how well balanced the rotor is.
What motor is going to turn that 10 blade rotor at 150,000 RPM????? and how many watts to do it??? And for that matter, what motor is going to turn an 18 blade at 70,0000 RPM and at what watts??? And while I'm questioning it why won't this one explode like my 12 blade CS fan???
rfodor is offline Find More Posts by rfodor
Old Aug 23, 2012, 09:05 PM
Atlanta, GA
Joined Feb 2009
Originally Posted by Ming View Post
Dear All EDF Fellows
After almost 18 months of time, the new fan molding finally ready to go mass production. That is a long road from rough idea to product launch to the market, we forgot how many difficulties need to overcome in the past 18 months. We will accept pre-order very very soon!
Brand: Changesun
Product : CS Smart Fan
Inside diameter: 91mm
Rotor diameter: 89mm
Meterial: Fibre Reinforced Nylon Rotor
Motor: Depend on blade combination
Loading: Depend on blade combination
Number of battery cell: Depend on blade combination
Shaft adaptor: 5mm
Thrust: 2.45g
*Multi- blade combination selection*
*Two group of difference pitch of blade to use*
*This is the total solution of 90mm EDF*
*Optional to use aluminum duct*
*Patent Pending*
Ming Lou
Ming Lou, are you aware that Change Sun's reputation has been badly damaged by the exploding 12 blade 90mm fans at as little as 2KW, 30,000 RPM and you expect this 18 blade to turn 70,000 RPM? Why is this one able to turn over twice the RPM and why cant the blades for the 12 blade be made out of the same material???
Old Aug 23, 2012, 10:09 PM
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
I want an answer on this too...
pavcon is offline Find More Posts by pavcon
Old Aug 23, 2012, 10:12 PM
Joined Jan 2010
we definetely want an 8mm adaptor and some good insurance that the blades will hold on because most probably these fans are going in expensive planes.
If they cannot recognise the previous problem then they won't be able to fix it on this fan
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
those numbers cant be real I took that as a typo and another thought do we have esc's that have switching rates that will support that high of rpm.......has to be a mistake
jcdfrd is offline Find More Posts by jcdfrd
For Sale (2) New 90MM ChangeSun 5 Bladed EDF Units $40 Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 3 Aug 06, 2012 11:37 AM
For Sale New ChangeSun 12 Bladed 90mm Fan Unit $40 Bucks Shipped FlyBoyTha1 Aircraft - Electric - Jets (FS/W) 9 Jun 07, 2012 05:52 PM
Sold ARC 36/65/1 and ChangeSun 90mm fan fh64_lucky Aircraft - Electric - Jets (FS/W) 1 Oct 30, 2010 05:07 PM
Video ChangeSun 90mm-5 Fan Proedf-Jack Electric Plane Talk 0 May 27, 2010 01:00 PM
