Old Dec 18, 2012, 05:36 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
I'm flying my single engine MiG on 4S... The motor and five blade fan can easily handle 4S as the motor is underrated kv wise...You just need to be sure to go with a 10-12 amp ESC and at least a 30C battery..
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Dec 28, 2012, 05:15 PM
Joined Mar 2007
Have any of you tried to to run separate ailerons and elevators???...Does this plane feel as though it has separate ailerons/elevators with the stock control rod configuration???..Just concerned as the stock configuration seems to be unconventional...
Kevin
Old Dec 30, 2012, 09:30 PM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Kevin
I think if the elevators were full flying, then I would be a little more inclined to split them up. try the stock setup, you might like it.
Joe 1320 is offline Find More Posts by Joe 1320
Old Dec 31, 2012, 03:49 PM
Joined Mar 2007
OK--Gotcha!!!...It just looks so weird!!!...Basically, this plane is being set up like a delta platform...Sure would be nice to use the "ailerons" on this model as flaps and cutout the ailerons in the wing and use micro servos to drive them...Maybe later down the road...
Kevin
Old Mar 25, 2013, 12:26 PM
junjian is offline
Find More Posts by junjian
Joined Feb 2013
I bought the same plane today but I don't seem to understand how the delta works.
When I push my stick towards me, how is the servo supposed to move? Both servo move backwards?
What if both my servo moves in opposite direction when it should be the same directions? Which setting should I change? Totally noob in delta.
junjian is offline Find More Posts by junjian
Old Mar 30, 2013, 10:25 PM
Whiskey Whiskey is offline
Find More Posts by Whiskey Whiskey
United States, CA, Fairfield
Joined Jul 2004
Try different combinations of reversing the ailerons and elevators within the transmitter, with delta mixing active of course.
Whiskey Whiskey is offline Find More Posts by Whiskey Whiskey
Old Apr 04, 2013, 09:23 PM
abjets is online now
Find More Posts by abjets
What Goes Up...Must Come Down
abjets's Avatar
United States, NC, Oak Island
Joined Jan 2013
Anyone have a photo of the side of their F-15?? Looking for a picture of your linkage setup. I am using some different hardware (nothing supplied with just the airframe) and just need some reference to make sure I am on the right path. Going with elevators off the furthest out hole on the servo horn and the ailerons on the next one in. Then both clevis's at the furthest out on the control surface horns.?.
I guess the bigger question is what are the control surface extents being used...is it the 5mm each side for both elevator and ailerons? Or 5mm on the elevators and 3mm on the ailerons?
Thanks!
abjets is online now Find More Posts by abjets
Old Dec 29, 2014, 12:02 AM
kevinkal is offline
Find More Posts by kevinkal
Old !Bold Pilot
kevinkal's Avatar
United States, CA, Gilroy
Joined Nov 2013
I received a Skyangel F-15 35mm Twin Airframe unexpectedly. I'd like to build it up. However, appears that 35mm EDFs and motors are a little scarce. What are the better power plant choices today that would fit this twin with little or no modification?
kevinkal is offline Find More Posts by kevinkal
Old Jan 01, 2015, 05:42 PM
straightup is offline
Find More Posts by straightup
Joined Sep 2004
You can source the motors from eBay but the fans are hard to find. I need to find some for my f15 as well. I think you could buy the 35mm from hk but they aren't as good as the stock units from what I've read.
straightup is offline Find More Posts by straightup
Old Jan 01, 2015, 09:14 PM
kevinkal is offline
Old !Bold Pilot
kevinkal's Avatar
Joined Nov 2013
Thanks for the information. All I seem to find are the blue AEO units.. which don't seem to have good reviews.
Old Jan 01, 2015, 09:36 PM
nom is online now
nom
Find More Posts by nom
nom
nom's Avatar
United States, ID, Boise
Joined Mar 2011
The motors are hard to find and if you find them they are a pretty penny. You might want to post in the classified.
nom is online now Find More Posts by nom
Old Jan 01, 2015, 10:23 PM
kevinkal is offline
Old !Bold Pilot
kevinkal's Avatar
Joined Nov 2013
Thans Nom. Ya, they are way too expensive. I would be nice to find a used pair.
Old Jan 02, 2015, 06:20 AM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
The fans are pretty good, it's the AEO motors that are amp hogs. They are fine in some applications, but not so good in others. I actually like the stock housing and motor with the AEO rotor but it's not the easiest to obtain by itself.
Old Jan 09, 2015, 03:39 PM
Joined Sep 2004
Joe - Did you make any airflow accommodation for the esc's or can the sit fully enclosed without a problem?
Thanks.
Old Jan 09, 2015, 10:32 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Nothing special... Just installed them as noted in the build and no issues.
Discussion Skyangel/HK Mig-15/29, F-86, T-45, F-15/16/18 and A-10 35mm EDF Jets now available! NitroCharged Micro EDF Jets and Power Systems 4531 Aug 22, 2016 03:47 PM
Data CG specs for the 35mm EDF jets by Jpower, Skyangel, Blitzrc, etc. and FAQs Joe 1320 Micro EDF Jets and Power Systems 5 Mar 30, 2016 01:54 PM
Rant Skyangel/Jpower Mig-15 35mm: AVOID MRGTX Micro EDF Jets and Power Systems 31 Feb 08, 2015 09:39 PM
Discussion Skyangel F-15 Twin 35mm Kit Custom Paint Job davecar Foamies (Kits) 3 Jun 19, 2012 07:21 AM
For Sale SKYANGEL F-15 Twin 35mm EDF RC Fighter Jet www.hobbyb.com Aircraft - Electric - Jets (FS/W) 14 Apr 07, 2012 01:16 PM
