Old Sep 13, 2012, 01:52 PM
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi Shoc,
First rule when testing a new (bigger) prop: make a short run, two minutes tops and bring the boat in to check the temperature of all components.
Unfortunately you found out the hard way how a brushless motor performs when the magnets have been overheated; it runs, but has no torque to speak of...
Regarding me mentioning running a 2200Kv outrunner on 3S in a 25" hull; that boat was virtually undrivable, even though it has a wider beam than the Snap. Even in the bigger ARPRO, this motor is giving the hull a hard time keeping the right side up...
Don't try it, you'll have serious torque issues.
There have been several possible replacements mentioned in this thread; keep the same motor Ø but go up in Kv, not overboard, beyond a certain amount of rpm, the stock propsize, either metal of plastic will only work as a blender.
The Leopard 2845 2960kv mentioned above is a nice drop-in replacement, giving you close to 30.000 rpm under load.
Be careful with those 'big' props on these small motors, the rotor inside is barely Ø 18-20 mm.
A longer can equals more torque, this (four-pole) motor can turn your CNC 440 prop much easier than the stock motor:
http://www.hobbyhot.com/LEOPARD-Boat...ess-Motor.html
The difference in torque and the drop in running temperature is something you'd have to experience for yourself, you'll never want to run a cheap two-pole motor again...
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Sep 13, 2012, 10:19 PM
Joined Aug 2012
Thanks Jan, yeah found out the hard way, glad I experienced this on a cheap motor now rather than later. I went ahead and ordered the following:
http://www.offshoreelectrics.com/pro...o-2860&cat=148 2730kv
http://www.offshoreelectrics.com/pro...ker-seaking-90
http://www.offshoreelectrics.com/pro...-2860XL-jacket
This should satisfy me for a while and I can pop these bad boys in another hull should I feel the need to later on. Thanks for your help, I will be careful on the prop, but if I read your last post right, Jan, you say this combo should handle a CNC 440 or an Octura 440 (but closer to a 38 after sharpening and balancing)? I think you are going to be correct, never going to run a cheap motor again but hey... it came with the boat, course then I look around online and see this and it makes me wince just a little.
http://www.ebay.com/itm/rc-boat-elec...#ht_500wt_1414
If I thought I could win this I would just buy this. Looks like he has made some improvements to it and I would get an extra motor out of the deal, but no way to win this me thinks. I will let you guys know how it all goes when the new motor gets here. I hope it will fit the motor mount I already have. Cheers guys!
Shoc RC is offline Find More Posts by Shoc RC
Old Sep 14, 2012, 03:06 AM
Sneek, Netherlands.
Joined May 2004
Hi Shoc,
The 5050kv motor on 3S would be 50.000 rpm under load, that's quite ludicrous and I can't imagine that set-up working well...
Regards, Jan.
Old Sep 17, 2012, 01:57 PM
JGuilty13's Avatar
United States, MI, Royal Oak
Joined Nov 2005
I ended up going with this motor (and leopard cooling jacket) - its the 2960kv version. http://www.offshoreelectrics.com/pro...o-2845&cat=148
Should have it in a couple days so Ill let you guys know how she runs as soon as I get it installed......but have to wait on my HK T120 esc though...
JGuilty13 is offline Find More Posts by JGuilty13
Old Sep 19, 2012, 12:40 AM
Joined Aug 2012
JG, you will need to get a new coupler from motor shaft to flex cable. The one that came stock with the boat doesn't fit on the new motor shaft. The leopards are 4mm our stock was 3mm. Got my new motor and found out right away.... another delay. Here is what I just bought, it should work.
http://www.offshoreelectrics.com/pro...oct-ocfhe4mm13
Old Sep 19, 2012, 08:58 AM
JGuilty13's Avatar
Joined Nov 2005
Shoc, thank you for the heads up! I would have been in the same boat as you (haha). I just ordered the new part.
What motor did you end up getting?
Old Sep 20, 2012, 02:50 PM
Joined Aug 2012
You bet!
I got exactly what I listed above the Lep. 2860 / 2730kv, Seaking 90esc and the XL 2860 aluminum cooling jacket. Can't wait to get it in the water again. I have also looked into upgrading to a 4mm flex (ours is 3.3mm roughly) or moving up to the heavy hitter 3/16 (which is around 5mm). I will do this AFTER I get my boat running with what I have now so I can have more time in the water whilst I order the new stuff. I am just worried the current flex / stinger might not hold up, we shall see. Still in dry dock until the collet arrives. Let me know how your new motor performs and I will do the same. Ill post a vid.
Old Sep 21, 2012, 03:00 AM
Sneek, Netherlands.
Joined May 2004
Hi Shoc & Jordan,
In order to keep the motor from snapping your flexshaft, set the ESC to soft start (supersoft if available), much easier on the shaft and you won't know the difference running the boat.
Regards, Jan.
Old Sep 21, 2012, 03:30 PM
JGuilty13's Avatar
Joined Nov 2005
Thank you Jan, how exactly would I change the stock 50amp esc to a soft start?
Old Sep 22, 2012, 05:43 AM
Sneek, Netherlands.
Joined May 2004
Hi Jordan
That depends on the software installed in your ESC.
Check the manual for programmable settings.
Regards, Jan.
Old Sep 24, 2012, 10:24 AM
Joined Aug 2012
Originally Posted by pompebled View Post
Hi Jordan
Regards, Jan.
Hi everyone,
Well the complete overhaul is almost finished, lets just say I got a lot more proficient with my soldering skills, LOL. I also had to mod the platform of the servo to fit the big motor/shaft coupler and even still its really close, keep that in mind JG. Jan, you mentioned setting the ESC to a "softstart". The only thing it looks like I can do is adjust the timing and I have no idea what that is on one of these motors. The leopard did not come with much paperwork. So the ESC says I can adjust the timing as follows:
0°, 3.75°, 7.5°, 11.25°, 15°, 18.75°, 22.5° or 26.25°.
If there is no softstart, can I just be real easy on the throttle at the start? Thanks again in advance.
Old Sep 24, 2012, 02:52 PM
Sneek, Netherlands.
Joined May 2004
Hi Shoc,
No, timing and softstart are two different animals...
If I'm not mistaken, your motor is a Y wind and will rev higher with more (advanced) timing.
Keep in mind, higher timing setting mean higher ampdraw and more heat in all components, so start low and work your way up to find the best setting for your set-up.
With low, I don't mean 0° timing, but 7,5 or 11,25°.
Keep us updated on your progress and show us some pictures of the new set-up, please.
Regards, Jan.
Old Sep 24, 2012, 08:59 PM
JGuilty13's Avatar
Joined Nov 2005
Shoc, I never received a manual with my model, or at least I don't see it in my original box. How do you set the stock esc to those settings? Is it something you could scan and upload to this thread and post?
Old Sep 25, 2012, 02:58 AM
Sneek, Netherlands.
Joined May 2004
Hi Jordan,
Shoc has another ESC than stock:
I'm sure the stock ESC can be programmed to a certain extent, but I would have to know what brand it is.
Regards, Jan.
Old Sep 25, 2012, 01:44 PM
Joined Aug 2012
The stock esc did have a sheet of paper w/ programming...I do have it but I'm at work today until 7am tomorrow then I have class until 5 tomorrow, so wont be able to upload it here until then. It does have a setting adjustment for throttle I do remember that.
For Sale Exceed RC Mini 50MM 2.4Ghz MIG-15 High Performance Ducted Fan Jet w/ Brushless Motor/ Mikemynameis Aircraft - Electric - Jets (FS/W) 14 Mar 26, 2012 07:49 PM
Discussion dragon snap burnt out motor f1disaster Racing Boats - Electric 12 Apr 17, 2011 01:05 PM
For Sale 14.8V 2200mAh 15C "Exceed RC Fusion Power Series" High Performance Lithium Polymer B e_brown Aircraft - Electric - Batteries & Chargers (FS/W) 0 Apr 23, 2008 10:20 AM
Discussion Exceed RC Dragon Fly 20 - Smoked the Receiver elight50 Mini Helis 0 Aug 13, 2006 03:53 PM
Exceeding Prop Tip Speed = Snap OzMax Electric Sailplanes 6 Oct 21, 2001 10:08 PM
