Old Nov 17, 2012, 03:59 PM
wingster is online now
Find More Posts by wingster
Massachussets
Joined Nov 2005
Finnspeed
Which Dualsky RTR motor are you using?
wingster is online now Find More Posts by wingster
Old Nov 17, 2012, 04:38 PM
Finnspeed is offline
Find More Posts by Finnspeed
F3A Team Finland
Finnspeed's Avatar
Järvenpää, Finland
Joined Nov 2005
This is the one: Dualsky XM2212RTR-25
http://www.verticalhobby.com/kauppa/...42-p-2443.html
I thought I had mentioned it in this thread already but I had only posted the info in the F3P equipment thread above.
Finnspeed is offline Find More Posts by Finnspeed
Old Nov 19, 2012, 09:34 AM
bells33 is offline
Find More Posts by bells33
United States, NJ, Englishtown
Joined Nov 2010
Looking forward to hear about your maiden flight. Waiting for my kit to come and I happen to have that very same motor in my arsenal!! I love when I can use stuff I already have!! lol
Anyone know where to get that cool carbon prop they are using in the videos??
bells33 is offline Find More Posts by bells33
Old Nov 24, 2012, 05:48 PM
F3A Team Finland
Finnspeed's Avatar
Järvenpää, Finland
Joined Nov 2005
I got my Spies maidened and trimmed fairly well last night. It is not perfect yet but it is quite obvious that this is a very good plane.
The small Dualsky RTR with Glavak SG 09 x 2.0 slim pull the plane really well. Efficiency is no match for Kimmo Kaukoranta's coaxial system that gives the same flight time with 120 mAh battery as this system with 180 mAh but it is still OK and better than the Emax GT 2203 that I have in my RT Sirius Eleven.
At the moment the AUW is about 102 g with 12.6 g 180 mAh battery. I have not yet fitted the larger SFG fins since the Finnish sports and advanced sequences do not contain demanding knife edge moves and at least horizontal rolls are very nice even without them.
Old Nov 25, 2012, 07:35 AM
bells33 is offline
Joined Nov 2010
Thanks for the update Finn... Can I ask what type of glue you used for build.
Before I get my Glavak prop, can you recommend a prop choice? (something I can get easily in US)
Old Nov 25, 2012, 02:08 PM
F3A Team Finland
Finnspeed's Avatar
Järvenpää, Finland
Joined Nov 2005
If you have this same motor, the GWS 7 x 3.5 is the correct basic choice. It will work and pull just fine. The larger diameter Glavak will offer much better braking on the down lines though.
I used the 15 min Beli-Zell glue. It is polyurethane glue that foams a bit when drying and forms flexible and very light seam.
Old Nov 25, 2012, 10:55 PM
bells33 is offline
Joined Nov 2010
Thanks again Finn... I will be ordering a Glavak prop for sure!
Someone gave me a tube of "FOAM TAC" glue.... but don't know if its the right choice for this project. He said it will weight less than CA...
....I might just stick with good ole' CA!!
Old Nov 26, 2012, 03:08 AM
bossee is offline
Find More Posts by bossee
Bo Edström, Sweden
Joined Jan 2009
Hi,
On my last plane, RT Sirius Eleven, I used not a single drop of CA, only Beli-Zell (green tube) 10 min (working time) and UHU Por glues. Worked great. There is also a Beli-Zell red tube that has longer working time and is white in color (the green tube is more like towards transparent color in the glue joint). There is also a kicker for it that shortens cure time by 4 times.
It is amazing how little Beli-Zell glue that is needed since it expand a little, You can not apply a lot of it since they You will get a ugly joint.
http://www.adhesionstechnics.com/index.php?id=20&L=3
/Bo
bossee is offline Find More Posts by bossee
Old Nov 26, 2012, 05:04 PM
bells33 is offline
Joined Nov 2010
I'm using your pics as a guide for my build. Did you go ahead and put mylar on your side force generators?
Any chance you can post some closeups of your servo setups? Did you go pull-pull on both elevator and rudder? And finally (for now ) can you show me where you put the flat carbon supports? I think I see on wing leading edges? and sides of fuse? Any in tail?
Thanks for all your help.
I didn't notice the flat carbon in Don's pic of the milled version.
Old Nov 27, 2012, 01:32 AM
F3A Team Finland
Finnspeed's Avatar
Järvenpää, Finland
Joined Nov 2005
As a matter of fact I had taken some closeups.
I use pull-pull system for both elevator and rudder. I set up the thread as a single piece loop that starts from the little screw on the servo arm, runs to the tail and through both ends of the tail surface horn and then back to the other side of the servo arm. The other end is locked to the same screw with a small droplet of CA. The idea behind this is that
1. You can tighten the thread by simply turning the screw. This does not change the trims since the screw pulls both ends of the thread equally.
2. After I have the thread in place and somewhat tightened, I can center the servo and the surface and lock it in place by applying a droplet of CA to the tail horn.
I can take a pic of the tail horn to show how that thread goes there.
I attached a pic that shows the carbon bracing of the plane. The leading edge has a continuous strip of the 3 x 0.3 mm flat carbon included in the kit but the fuse sides have strips of lighter 3 x 0.13 carbon to save weight. The tail bracing is 0.7 mm tube and the wings have 1.0 mm tube. You can use the 1 mm and 0.8 mm rods included in the kit as well, they will only add a tiny amount of weight.
Old Nov 27, 2012, 05:58 AM
3Don is offline
Find More Posts by 3Don
3Don's Avatar
Joined Nov 2004
That is very nice weight! And impressive clean building . Very soon I will start build custom mylar covered Spies. I hope to end up at 100g +-5g mark. I plan to use JR 290 on ailerons for maximum precision. 180mah battery and again Mr. Glavak Coaxial system.
I include some pictures of (manual) Spies building.
3Don is offline Find More Posts by 3Don
Old Nov 27, 2012, 06:10 AM
3Don is offline
3Don's Avatar
Joined Nov 2004
More pic's and unknown video from EIAC;
EIAC 2012 F3P-Unknown - Donatas Pauzuolis (0 min 0 sec)
Old Nov 27, 2012, 10:26 AM
Twisted Realm is online now
Find More Posts by Twisted Realm
Twisted Realm's Avatar
United States, FL
Joined Aug 2008
Looking good Donatas!
Twisted Realm is online now Find More Posts by Twisted Realm
Site Sponsor
Old Nov 27, 2012, 12:22 PM
bells33 is offline
Joined Nov 2010
FINN... your side force generators look different than mine. Mine are just milled. Did you cut yours out and put Mylar on them?
Old Nov 27, 2012, 02:10 PM
F3A Team Finland
Finnspeed's Avatar
Järvenpää, Finland
Joined Nov 2005
I made new ones and covered with 5 um mylar. To save some weight of course... And I wanted to try out the mylar method as well.
Thanks for your kind comments, Donatas. I'm beginning to learn how to build these. Now I just have to learn to fly...
Discussion Donatas Design and Sultimate XL plans for sale ! 3Don Indoor Pattern/F3P 34 Jun 13, 2014 07:22 AM
Discussion Donatas Design: Arrow V5 3Don Indoor Pattern/F3P 189 Oct 02, 2013 12:31 PM
Discussion Donatas Design and Sultimate XL plans for sale ! 3Don 3D Foamies 15 Jan 03, 2012 07:41 AM
Discussion SYMMETRIC, new Donatas Pauzuolis F3P design. 3Don Indoor Pattern/F3P 135 Nov 16, 2011 02:29 PM
Mini-Review Futurion (Donatas Pauzuolis design) jackack Indoor Pattern/F3P 1 Jan 14, 2008 08:47 AM
