Old Sep 12, 2012, 02:58 PM
fturpaud is offline
Find More Posts by fturpaud
Joined Feb 2009
Hello,
I have received two prototypes, one in depron milled and the other covered by mylar.
For the milled and depron kit, the quality is i would say as the Donatas Design standard is.....very good!!
For the mylar version, I am very impressed by the result, first and most important point is the rigidity of the airframe!
Second point is the weight, at the same stage of assembly my personnal planes (with 6mm) are 6gr lighter, which is pretty close!
Furthermore, there is still some area to milled, nose of the fuselage, Airbrake, gears...2-3g at least!
I let you informed about the assembly as soon as i start it...
Cheers
Fab
fturpaud is offline Find More Posts by fturpaud
Old Sep 15, 2012, 04:43 AM
3Don is offline
Find More Posts by 3Don
3Don's Avatar
Joined Nov 2004
Originally Posted by fturpaud View Post
Hello,
Cheers
Fab
Good to see you here Fabien! Weight difference you see is mostly because of thickness of mylar and not such wide opening like you have. We use 0.012mm mylar film, thiner one will not hold printing. As you can see film is WAY stronger than super thin mylar we use until now. So for mass production and regular customers this is much better option. My friend Ignas is assembling milled version of Spies. I move with mylar version build. Here couple pictures:
3Don is offline Find More Posts by 3Don
Old Oct 06, 2012, 11:25 AM
3Don is offline
3Don's Avatar
Joined Nov 2004
Finally this weekend I tested Spies covered with mylar, and Ignas tested depron version. Both flight reports are very positive. Great rolls, fuselage almost do not move during trasition from KE and upright flights. Rolling circles and loops are perfect.
Mylar covered plane is 112 g, with Glacak coaxial motor (25,5g)
Ignas milled depron Spies is just 107 g with EP 2202/1550.
I use 180 mah batteries, Ignas use standart equipment and 120mah. So going crazy with all lightest equipment, it should be easy to get depron version close to 100g, and sure mylar version under 100g. In any case I am very happy with the way 112g plane fly. Certainly one of the best F3P planes i ever tested.
Old Oct 06, 2012, 02:15 PM
Finnspeed is offline
Find More Posts by Finnspeed
F3A Team Finland
Finnspeed's Avatar
Järvenpää, Finland
Joined Nov 2005
Looks good! Is there a video coming up soon?
I just noticed the milled versions are in stock @ Autopartner.se. Do you have any dates for the mylar covered one? Also, I'd like to know the wing span, length and wing area.
How about your plane, did you use the standard carbon parts in the kit, which servos and did you lighten the servo wiring or receiver?
Too many questions, I know...
Finnspeed is offline Find More Posts by Finnspeed
Old Oct 07, 2012, 09:58 AM
3Don is offline
3Don's Avatar
Joined Nov 2004
Here is bit more info about Spies: http://www.pauzuolis-rc.com/fabien-turpaud-spies
Some answers to your questions:
No dates on mylar version yet, i still testing it, so far it looks good, but i want to be sure it is strong enought for regular customers.
Spies wingspan; 80cm
Fuselage lenght; 90cm
I used carbon tubes all around. Also i made shorter servo wirres, i do this on all my models, if you do not pay attention to small details you end up with 10g heavier plane...
Old Oct 08, 2012, 11:08 AM
mpx4000 is offline
Find More Posts by mpx4000
F3A Flyer
Kentucky
Joined Feb 2005
The plane looks and flies great especially with the contra. Will this model be available in the US?
mpx4000 is offline Find More Posts by mpx4000
Old Oct 09, 2012, 06:22 AM
3Don is offline
3Don's Avatar
Joined Nov 2004
I am preparing video, hopefully it will be ready tonight. Yes it will be available in USA, i will let you know details.
For more urgent questions you can reach me at: donatasdesign@gmail.com
Old Oct 10, 2012, 01:04 AM
3Don is offline
3Don's Avatar
Joined Nov 2004
Ignas Spies, 4th flight :
Donatas Design: Spies by Fabien Turpaud (3 min 56 sec)
Old Oct 10, 2012, 09:08 AM
3Don is offline
3Don's Avatar
Joined Nov 2004
Here you go as promised Spies presentation video with S.Glavak coaxial system:
Donatas Design F3P plane SPIES (5 min 18 sec)
Old Oct 10, 2012, 02:31 PM
F3A Team Finland
Finnspeed's Avatar
Järvenpää, Finland
Joined Nov 2005
Cool! Very informative too. I'm about to hit the "order" button...
Old Oct 10, 2012, 05:29 PM
Not Free is offline
Find More Posts by Not Free
Foamies for life! #f3p
Not Free's Avatar
United States, CA, SF
Joined Sep 2011
Not Free is offline Find More Posts by Not Free
Old Oct 10, 2012, 05:30 PM
Not Free is offline
Not Free's Avatar
Joined Sep 2011
WOW That is AMAZING!!
Not Free until He died for Me
Old Oct 11, 2012, 01:17 AM
3Don is offline
3Don's Avatar
Joined Nov 2004
Thank you for kind comments, I want this video to be useful for all F3P pilots, so i put bit information about setup, much more info will be posted in manual. I also gonna start detailed Spies building thread here.
Old Oct 13, 2012, 02:41 PM
Nadav Sharabi is offline
Find More Posts by Nadav Sharabi
Joined Aug 2012
Donatas, it looks amazing and the depron parts with the mylar are extraordinary building..
great video too...
keep bring us new developments for F3P...
Nadav Sharabi is offline Find More Posts by Nadav Sharabi
Old Oct 13, 2012, 02:45 PM
Free is offline
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
Joined Jan 2012
Hey Donatas,
The vids are GREAT!
Please keep up the innovations!
Free
Free is offline Find More Posts by Free
Discussion Donatas Design and Sultimate XL plans for sale ! 3Don Indoor Pattern/F3P 34 Jun 13, 2014 07:22 AM
Discussion Donatas Design: Arrow V5 3Don Indoor Pattern/F3P 189 Oct 02, 2013 12:31 PM
Discussion Donatas Design and Sultimate XL plans for sale ! 3Don 3D Foamies 15 Jan 03, 2012 07:41 AM
Discussion SYMMETRIC, new Donatas Pauzuolis F3P design. 3Don Indoor Pattern/F3P 135 Nov 16, 2011 02:29 PM
Mini-Review Futurion (Donatas Pauzuolis design) jackack Indoor Pattern/F3P 1 Jan 14, 2008 08:47 AM
