Old Feb 27, 2013, 10:53 PM
DaveL322 is offline
Find More Posts by DaveL322
Team JR
DaveL322's Avatar
Medford, NJ
Joined Jan 2004
Brakes, SFGs. I often make initial flights without various aerodevices…and then add them incrementally so I can assess the effects on flight performance. Should an aerodevice not be needed….it is just added weight. I test flew the plane as shown this past weekend in the small demo space at the WRAM show. CG is in the middle of the recommended location, 142 mm from the wing leading edge. The demo area was quite turbulent, so I couldn’t really assess trim or CG. Power seems quite good and very easy to fly constant speed. Downline braking was good, even in the small space. I can’t wait to fly this plane in a good indoor space.
For those (in North America) interested in Spies kits (or the V6 Arrow), I generally have them with me at events, or can ship, and they are also available from Fancy Foam and Skip Miller.
Regards,
Dave
DaveL322 is offline Find More Posts by DaveL322
Old Mar 04, 2013, 03:08 PM
FASTALJR is offline
Find More Posts by FASTALJR
Fast and getting faster!
Albany County, New York, United States
Joined Jul 2003
I just put one together a week ago, and flew it for the first time this weekend!! I had brought over 5 planes with me to fly during the day, and spent the day flying the Spies , best flying F3P airframe I have flown yet!!! Smooth, crisp, and tracks near perfect. Now all I need is that fancy dual motor unit and I`ll be all set!
FASTALJR is offline Find More Posts by FASTALJR
Old Mar 04, 2013, 07:30 PM
r/cmark is offline
Find More Posts by r/cmark
200 mph club
r/cmark's Avatar
United States, AZ, Fort Mohave
Joined Mar 2005
Finally finished! AUW is 106 grams with a Turnigy nano-tech 300mah battery weighing 17 grams.
I will try the flight test (with video) tomorrow!
r/cmark is offline Find More Posts by r/cmark
Old Mar 05, 2013, 04:24 AM
Finnspeed is online now
Find More Posts by Finnspeed
F3A Team Finland
Finnspeed's Avatar
Järvenpää, Finland
Joined Nov 2005
106 g AUW is good with that battery. You can break the 100 g barrier by using a 180 mAh battery and a carbon prop. Every gram counts!
I have a Spies myself but it is the milled one. Maybe I should try the mylar version as well. Don is going to be present at the Finnish Open F3P in three weeks...
Finnspeed is online now Find More Posts by Finnspeed
Old Mar 05, 2013, 08:27 AM
aerolite is offline
Find More Posts by aerolite
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
what is the weight difference between the mylar and the milled? Just curious.
aerolite
aerolite is offline Find More Posts by aerolite
Old Mar 05, 2013, 10:58 AM
F3A Team Finland
Finnspeed's Avatar
Järvenpää, Finland
Joined Nov 2005
Donatas actually answered that question already in post #13. He weighed the airframe parts and got 7.2 grams difference. That was the first prototype production though so that might have changed a bit.
Old Mar 05, 2013, 11:24 AM
aerolite is offline
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
yep, I missed that! thanks for help with the answer.
Old Mar 05, 2013, 07:10 PM
r/cmark is offline
200 mph club
r/cmark's Avatar
Joined Mar 2005
Just before sunrise. Wind was about 2-3 mph. I am never going to be a championship level flyer but I have a lot of fun practicing! This is the old F3P-AP sequence. It is going to take a while to get used to flying a plane this light (106 grams). The old Osiris V2 was 130 grams that 24 grams makes a BIG difference!
Spies first flight old F3P-AP
Spies First Flight (2 min 30 sec)
I have flown the Spies up until now with out the SFG's on the tips of the ailerons and elevator. I installed them last night a flew today. The verdict is although they add some weight the performance on the 'side' is improved. I am going to keep them on!
Spies with SFG's (0 min 0 sec)
Old Mar 27, 2013, 07:53 PM
bill clark is offline
Find More Posts by bill clark
Half way there
bill clark's Avatar
USA, FL, Ocoee
Joined Sep 2008
you know you have a great wife when she buys you a cool, high tech airplane for your birthday . My Spies probably wont brake ground for a couple months because I will be installing a new control system I have been working on and the contra drive I am machining not to mention the hours spent in meticulous assembly
My only question so far is how do you pronounce "Spies"?
bill clark is offline Find More Posts by bill clark
Old Mar 27, 2013, 11:45 PM
r/cmark is offline
200 mph club
r/cmark's Avatar
Joined Mar 2005
Tried the 'new' Scorpion S-1804-1650KV motor today. It weights 1.5(~) grams less than the Hacker 10-15s. It did not have nearly the power of the Hacker 10-15s. It did not have enough power for the 106 gram Spies.
Old Mar 28, 2013, 07:03 PM
Half way there
bill clark's Avatar
USA, FL, Ocoee
Joined Sep 2008
anyone else having a problem getting to donatasdesign.com? I have been trying the last couple days
Old Mar 28, 2013, 10:51 PM
r/cmark is offline
200 mph club
r/cmark's Avatar
Joined Mar 2005
Just finished Spies number 2. Came out at 97.8 grams with a Turnigy nano-tech 120mAh 2S 25C Lipo Pack and the Scorpion S-1804-1650KV motor. That's as light I can build it (using the stock parts). We will see if the Scorpion can handle 97.8 grams!
Old Mar 29, 2013, 06:51 AM
F3A Team Finland
Finnspeed's Avatar
Järvenpää, Finland
Joined Nov 2005
That is an excellent weight for the kit Spies. I think that Scorpion should be able to handle it but I recommend getting a better and lighter prop than the 8" GWS.
Based on the kv of that motor, I'd start experimenting with the Glavak SG 9 x 2.8. It is more than 2 grams lighter than the GWS and has more optimal pitch for F3P. With the GWS, the motor might be well outside of the best efficiency.
Old Mar 29, 2013, 09:14 AM
Boogie3D is offline
Find More Posts by Boogie3D
United States, FL, Daytona Beach
Joined Sep 2005
I had a Spies with AUW of about 92g with the scorpion motor and 2s180mAh batteries. The best prop proposed by Glavaks was their 9x2,5 slim. The power was ok for the whole schedule, so you should be happy with it.
Boogie3D is offline Find More Posts by Boogie3D
Old Mar 29, 2013, 10:03 PM
r/cmark is offline
200 mph club
r/cmark's Avatar
Joined Mar 2005
You guys were right at less that 100 grams the Scorpion has enough power and no extra.
What Glavak prop is best for a Hacker A10-15S Motor?
Thought I would run some tests:
Hacker vs Scorpion
180mAh Nano Batt.
8x4.3 prop
Discussion Donatas Design and Sultimate XL plans for sale ! 3Don Indoor Pattern/F3P 34 Jun 13, 2014 08:22 AM
Discussion Donatas Design: Arrow V5 3Don Indoor Pattern/F3P 189 Oct 02, 2013 01:31 PM
Discussion Donatas Design and Sultimate XL plans for sale ! 3Don 3D Foamies 15 Jan 03, 2012 08:41 AM
Discussion SYMMETRIC, new Donatas Pauzuolis F3P design. 3Don Indoor Pattern/F3P 135 Nov 16, 2011 03:29 PM
Mini-Review Futurion (Donatas Pauzuolis design) jackack Indoor Pattern/F3P 1 Jan 14, 2008 09:47 AM
