This thread is privately moderated by batfire, who may elect to delete unwanted replies.
Old Aug 22, 2012, 07:38 PM
batfire is offline
Find More Posts by batfire
Connecticut Quad Hacker
batfire's Avatar
Joined Dec 2009
TROUBLESHOOTING INFO LIBRARY, Future designs & USA Distrib.of UAVs parts
Quick Note: Don't forget I have much more information on troubleshooting in my blogs.
KK2 BOARD SETUPS VIDEOS
Calibrate ESC's using the KK2 Board
Calibrate ESC's using the KK2 Board (0 min 50 sec)
(0 min 50 sec)
(0 min 50 sec)
KK2: QUICK START TUNING GUIDE
Hobbyking's KK2: QUICK START TUNING GUIDE (4 min 9 sec)
DJI WK-M & NAZA-M GPS VIDEOS
DJI WK-M and Spektrum DX8 - How to set up Fail-Safe and RTH with a switch
DJI WK-M and Spektrum DX8 - How to set up Fail-Safe and RTH with a switch (2 min 44 sec)
DJI Naza-M GPS Mounting, Setup & Calibration
DJI Naza-M GPS Mounting, Setup & Calibration (4 min 15 sec)
(4 min 15 sec)
TBS Discovery build EP23 TBS DJI Naza Compass calibration - 20121020 (2 min 26 sec)
http://www.dji-innovations.com/produ...aign=wookong_m
Setting Fail Safe on Naza
HOW TO SET FAIL SAFE FOR DJI NAZA+GPS RTH AUTO LAND (5 min 48 sec)
Naza FC fix with GPS Magnetic Declination Compensation
Naza Flight Controller Fix with GPS - Magnetic Declination Compensation (5 min 2 sec)
(5 min 2 sec)
Step by step instructions for NAZA FC install by Ali Shanmao
Part 1
DJI Naza Installation and setup New Guide -- Part 1 (8 min 6 sec)
Part 2
http://www.youtube.com/watch?feature...oxcdsZW_Y&NR=1
Part 3
DJI Naza Installation and setup New Guide -- Part 3 (12 min 31 sec)
MULTICOPTER TUNING AND OTHER VIDEOS AND LINKS
Multicopter PI-tuning: How to recognize different settings.
Multicopter PI-tuning: How to recognize different settings. (7 min 52 sec)
Magnetic Field Calculators
http://www.ngdc.noaa.gov/geomag-web/#declination
UAV NEWS SOURCES
Source News on UAVs ----- http://www.spacewar.com/uav.html
sUAS News ----- http://www.suasnews.com/
UAV CALCULATORS
xcopterCalc - Calculator for MultiCopter ----- http://www.ecalc.ch/xcoptercalc_e.htm?ecalc
Lipo Battery Calculator
http://multicopter.forestblue.nl/lip...alculator.html
WALKERA DEVENTION DEVO TRANSMITTERS HACKS AND FIXES
FOR YOU DEVO 6/6S/8/8S/10/12 OWNERS
CUSTOMIZED LIBRARIES
http://rc.fdr.hu/devo.php#cust_lib
SUPPORT HACKS FOR DEVO 6/6S/8/8S/10
Deviation is experimental software.
http://deviationtx.com/
HERE IS A THREAD DEVOTED TO DEVO TX HACKING
http://www.rcgroups.com/forums/showthread.php?t=1611471
THIS IS THE RCGROUP DEVOTED DEVO 10 THREAD
http://www.rcgroups.com/forums/showt...606210&page=28
Hobby-Lobby esc video for troubleshooting and setting endpoints on esc's
eRC Speed Controller Trouble Shooting: How To (6 min 30 sec)
batfire is offline Find More Posts by batfire
Old Sep 07, 2012, 08:16 PM
batfire is offline
batfire's Avatar
Joined Dec 2009
New design turbo ace spider and other design ideas
OK, this is a new design from the existing Turbo Ace parts bin. I will be building a strictly FPV machine for fast low flying. All parts will be on center line of hub. The only thing slung below will be the 450 skids and battery if unable to incorporate into shelf above skids.
This is a chute design I am working on for multicopter use. It incorporates a 60" chute. More to follow on this project soon.
The next pictures are of Hexacopter designs I will be building starting in mid-October of 2012.
UPDATE: This one is in construction and testing now. See my Hexacopter Blog.
The next picture is a design I am toying with that will use a quadcopter frame and foam construction to complete a UFO design. Should be fun.
Next Picture is a quad plane design I will be building using 2 flying wing kits I have.
Next My modified flying wing design for FPV use.
Next My Modified Blade 400 less the GoPro FPV setup.
This is my Winter Project. My "Peregrine" design.
New entry as a completed design for this years competition 2013. Hover Duration
Old Sep 07, 2012, 08:24 PM
batfire is offline
batfire's Avatar
Joined Dec 2009
New Design Airship for FPV and Observation at near earth altitudes
EXTENDED ON STATION NEAR EARTH BLIMP (EOSNEB)
This is a new design using a unique approach to build a slender blimp platform for near-earth exploration. I will be using individual bags for helium which will be allowed to interchange gas between them with valve network controller array. This will allow high altitude flight as well as low altitude use and conserve helium instead of venting overboard at high altitude. It will comprise of a CF frame in an exo-frame structure. The gondola below will incorporate 4 motors, fully articulating, and escs along with a full flight control system including gps, magnometers and OSD system. The cameras will consist of 10x visual zoom, IR cam and regular digital camera for single shots. There will also be room onboard for various atmospheric collection packages and experiments.
Construction is scheduled for early 2014 and testing stages will follow afterwards. Objectives are to test slender designed platform with capability to loiter in near-space altitudes from 20-25km for durations of 30-60 days. The reason for this altitude will be to test feasibility for a blimp design to be used to explore the Martian planet for extended periods.
The propulsion systems will comprise of electric propeller propulsion system which will charge from solar cells located on top and sides of blimp. There will also be an exotic power source onboard for charging batteries which will not be covered in the construction and testing notes due to patent possibilities hence the time holdup before construction starts.
The blimp design will have a very low frontal drag ratio in the 4.5-4.9 area allowing best overall volume of blimp lifting structure but minimizing the frontal drag component. The exoskeleton structure will allow the least weight while keeping lifting cost minable.
This blog will be updated from time to time as we complete and test different segments of the onboard and ground station instrumentation, flight control system and software programming for mission.
Discussion Near Earth object warning realtimerecon Life, The Universe, and Politics 8 Jun 14, 2012 01:03 PM
Discussion KX 171 Vechicle Hook Up HELP Plse!! HeadShot FPV Talk 5 Jul 31, 2009 01:40 PM
Discussion Asteriod near miss on earth jumpinjo Life, The Universe, and Politics 10 Mar 06, 2009 09:17 AM
Rare Earth Magnets near Brushless Motors/Controllers Megowcoupe Power Systems 3 Aug 06, 2001 10:55 AM
