Old Aug 22, 2012, 06:23 PM
AtGame7 is offline
Find More Posts by AtGame7
United States, PA, Ellwood City
Joined Aug 2011
Very nice. I owe you a video of the one of these http://www.rcgroups.com/forums/showthread.php?t=1685988 that I built.
First plane I have ever built and sure enough it flies great! Thank so much. I will get that video next time we get to the field (AKA when it's not so damn windy).
I want to build this one as well. Can you dumb it down for me and post what kind of electronics you are using and the CG?
AtGame7 is offline Find More Posts by AtGame7
Old Aug 22, 2012, 07:37 PM
balsa or carbon is offline
Find More Posts by balsa or carbon
Hot glue held together by foam
balsa or carbon's Avatar
United States, OR, Portland
Joined Aug 2010
I'm glad your SUPER EASY flies well ! Looking forward to the video !
The CG on the jet is 13" straight back from the tip of the nose , I used this http://www.hobbypartz.com/98p-mars-b...30a-combo.html motor combo from Hobbypartz , 300 watts , 3440kv , 6x4 prop - takes it straight up until you can't see it anymore . I'm guessing about 80mph ! And it ROLLS LIKE A DRILL BIT !! Be sure to put some expo on the aileron channel - it's pretty touchy - and something ( like bright colors on the bottom ) for orientation .
When the time comes for you to build the jet , let me know if you need anything in addition to the instructions above .
balsa or carbon is offline Find More Posts by balsa or carbon
Old Aug 22, 2012, 10:23 PM
goodhumormarc is offline
Find More Posts by goodhumormarc
figuring it out...sort of!
goodhumormarc's Avatar
USA, OR, Happy Valley
Joined Jul 2010
whats your all up weight? Looks good! I want another fast one this might be it!
goodhumormarc is offline Find More Posts by goodhumormarc
Old Aug 22, 2012, 10:37 PM
irun4fundotca is online now
Find More Posts by irun4fundotca
Flying Wood For Fun
irun4fundotca's Avatar
Canada, ON, Harrowsmith
Joined Jan 2012
i wonder how big i would have to scale it up to handle my .46 glow equiv motor and 70amp esc and 3s 5000mah battery lol
i guess i do have a smaller 70mm edf motor i could use
irun4fundotca is online now Find More Posts by irun4fundotca
Old Aug 23, 2012, 02:36 PM
Joined Aug 2010
405 grams with a 1000mah
Old Aug 23, 2012, 04:53 PM
TCJ4 is offline
Find More Posts by TCJ4
United States, NY, Fairport
Joined Jul 2011
What makes the plane gain altitude with no elevator just aelerons?
TCJ4 is offline Find More Posts by TCJ4
Old Aug 23, 2012, 05:07 PM
Flying Wood For Fun
Joined Jan 2012
Delta mixing im guessing
Old Aug 23, 2012, 06:39 PM
Joined Jul 2010
This delta setup is used with two seperate servos. If you don't have a programmable TX you need an inline mixer. The tail works together as an elevator and seperate as ailerons. Delta is the setup you'll use on a computerized TX.
Old Aug 23, 2012, 06:41 PM
Joined Aug 2010
It uses elevons , which is elevator and ailerons combined and mixed by the transmitter . They can both go up or down together ( elevator ) , or one can go up while the other goes down ( aileron ) . You can see it in this video
Home made mechanical elevon mixer (0 min 26 sec)
Old Aug 23, 2012, 06:43 PM
AtGame7 is offline
Joined Aug 2011
Is there a close up of how you mounted the motor (remember, I'm new at this)?
Battery size?
Old Aug 23, 2012, 07:02 PM
Joined Aug 2010
Battery size?
I use a 1000mah 3s and the motor is attached to a motor mount which is hot-glued to the plane
Old Aug 23, 2012, 07:06 PM
AtGame7 is offline
Joined Aug 2011
Thank you thank you!
Old Aug 23, 2012, 07:25 PM
TCJ4 is offline
Joined Jul 2011
Wow thats slick. Thanks for the info on the mixing. I am also new at builds so much to learn.
Old Aug 23, 2012, 08:27 PM
Joined Aug 2010
Are you building one ?
Cool Simple DTD ( Dollar Tree Delta ) balsa or carbon Foamies (Scratchbuilt) 86 May 16, 2016 10:23 PM
Cool Simple Dollar Tree foamboard RC ( skirtless ) hovercraft balsa or carbon RC Hovercraft 24 Dec 30, 2012 06:01 PM
Discussion dollar tree foam jets! woohoo Foamies (Scratchbuilt) 1 Apr 26, 2012 04:55 AM
Discussion My $1.00 Dollar-tree jet upperking Foamies (Scratchbuilt) 4 Mar 01, 2011 03:05 PM
Discussion Building a jet pusher with Dollar Tree Foam? hoverflyhehe Pusher Prop Jet Models 26 Feb 25, 2010 08:43 AM
