Old Nov 13, 2001, 03:07 AM
Franck is offline
Find More Posts by Franck
-plancks only-
Franck's Avatar
The Netherlands, UT, Benschop
Joined Oct 2001
Prop 2, 3 or why not 4 blade.... ?
Hi,
As my "Partenvia-Star" is almost nearing its completion i ran a new thought about prop choice. The plane is to be initially mounted with 480's and the standard 6.5*4 graupner props , but why should I not use a three bladed prop, or maybe a fourbladed ??
Can anyone give me a clue on this ?
Regards,
Franck
Franck is offline Find More Posts by Franck
Old Nov 13, 2001, 03:22 AM
opualuan is offline
Find More Posts by opualuan
high-speed freak
opualuan's Avatar
San Jose, CA
Joined Sep 2001
depends on what kind of batteried/esc you are using and what kind of performance you want. The easiest way it to try different combos in motocalc. If you use too many blades on too big/pitched a prop and your motor/esc/batteries can't keep up, one of those three could fry... also, I think pitch speed is reduced as you add blades...
opualuan is offline Find More Posts by opualuan
Old Nov 13, 2001, 04:50 AM
Bill Glover is online now
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
This gets raised from time to time, the general view is that 2-bladers are more efficient. I tested 2 and 3-blade props on my Twin Star (6" 2-bladers, 5.6" 3-bladers) ... both set to pull the same amps (Varios - variable pitch) ... and the 2-bladers definitely gave slightly better performance. The 3-bladers looked very cool though!
On full-size there are generally reasons for going 3 or 4 blade and reducing diameter ... like not needing such a long u/c, or being able to mount the motors closer to the fus./each other on a multi engine type. Noise may also be a factor, if you're turning a smaller diameter prop at the same rpm then blade tip speed is reduced.
But I'm sure there are many factors, and there may be situations (combination of prop rpm and airspeed maybe??) where 3 or 4 blade props can be as efficient as 2-bladers.
Bill Glover is online now Find More Posts by Bill Glover
Old Nov 13, 2001, 08:12 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
That's about it, 2-bladed props are slightly more efficient and a lot easier to get hold of.
Probably the only good reason for more than 2 blades on our planes is clearance. An equivalent prop with more blades will be smaller. Geared motors used on a twin may need more blades to keep them clear of the fuselage.
Steve
steve lewin is offline Find More Posts by steve lewin
Old Nov 13, 2001, 11:13 AM
ChrisP is offline
Find More Posts by ChrisP
Master
ChrisP's Avatar
Weilbach, Germany
Joined May 2001
Considering that the majority of contest rubber powered models (e.g. Wakefields) have single blade folders, it's surprising that 1 blade props are apparently non existant on the electric scene.
ChrisP is offline Find More Posts by ChrisP
Old Nov 13, 2001, 11:48 AM
All__talk is offline
Find More Posts by All__talk
Hairy E-Pilot
All__talk's Avatar
Ellensburg, Wa, USA
Joined Dec 2000
There was a discussion some time back on one bladed props, I donít know if the thread is still around. Theoretically they are the most efficient, in practice itís an issue of dynamic balance. I personally think itís very possible and have even sketched up a simple design, but havenít done any experimenting yet.
Gary
All__talk is offline Find More Posts by All__talk
Old Nov 14, 2001, 03:47 AM
Joined Nov 2000
Control-line speed models (IC) have used single-blade props for years and years. But plenty of very successful flyers use 2-blade props, so the net advantage can't be that clear cut. You don't see any models with 3 or 4 blade props though
Old Nov 15, 2001, 06:08 PM
joao is offline
Find More Posts by joao
Coimbra, Portugal
Joined Feb 2000
Hello,
MAYBE the extra efficiency of props with less blades comes from two factors:
1) the distance between blades is larger-> the wake generated by one blade has a less disturbing effect on the the "following" blade.
2) there are less blade (wing) tip vortices. Just like a monoplane is generally more efficient than a biplane because, among other reasons, it has two, instead of four, wing tip vortices.
The tip vortices are caused by the tendency of the higher pressure air in the lower surface of the wing to move to the lower pressure zone in the upper surface (winglets try to prevent that kind of "circulation").
The energy spent is putting the molecules in "funny" motion patterns (vortices) is energy wasted.
Regards,
Jo„o
joao is offline Find More Posts by joao
Old Nov 20, 2001, 07:15 AM
joao is offline
Coimbra, Portugal
Joined Feb 2000
Hi Franck,
I am using with great sucess 3 blade props on my TJ, togheter with Permax 480 motors from MPX (2,3 mm shaft, not retimed for pusher mode).
They are Varioprops with 5,8"x (...), at the moment 4". That pitch is in the middle of the supplied scale and itīs working so fine that it will remain in use in the near future. The Varioprops can be set for pusher action.
http://www.varioprop.de/
The idea was to otain, at a reasonable price, an increase in performance from the stock setup, still using a 8 cell Sub-C pack.
The TJ has limited clearances, the hand one of "personal" importance!
You can see in the photo that I added a small dorsal fin. The fuselage form is also slightly changed...
Conclusions:
-The FUN factor has increased a lot
-It is a lot quieter
-Comparing my TJ with the TJ of a clubmate flying on 8 Sub-C cells and the Graupner Comp. Set we think mine climbs better.
The same fellow has a Catalina Flying boat, similar to the HU-16 presented in the Vario site. He his using almost the same setup I use on the TJ. The differences are the use of 6" props and less pitch.
Regards,
Jo„o
Old Nov 20, 2001, 07:43 AM
Joined Nov 2000
I like Vario props a lot, they are not cheap ... but are quiet and efficient. I used a 3 blade 5.6" one on my Pico Jet for a while for the same reason - a little extra blade area, while keeping to a diameter that still clears the ground!
8 cells is the minimum for the Comp set (7.2V motors), it's propped to run on up to 10 cells so that's where it would perform best.
Old Nov 20, 2001, 08:38 AM
Clu is offline
Clu
Find More Posts by Clu
Clu
Glavin!
Clu's Avatar
Southern NJ
Joined Aug 2001
Anyone using / recommend a 3 blade for a Zagi?
I'm wondering if it would be quiter than the stock spoon prop.
Clu is offline Find More Posts by Clu
Old Nov 20, 2001, 08:46 AM
Joined Nov 2000
Anything that moves the prop blades back a little (away from the wing) will be quieter.
Sold GloBee IntelliTach 2, 3, or 4 blade tach Etonic Aircraft - General - Miscellaneous (FS/W) 1 Feb 01, 2006 08:49 PM
Depron 2,3,6mm. Where to find 4,5mm?? Butch777 Electric Plane Talk 6 Sep 09, 2005 04:37 PM
Tail starts to yaw after 2-3 mins. Why ? OzzieFlyer Micro Helis 5 Jun 05, 2004 03:22 PM
Question Still wondering why not 4.8v s400 EDF? mad mike Electric Ducted Fan Jet Talk 13 Dec 14, 2003 07:46 PM
MEGA AC 22/20/3 or 22/20/4?! Blue Bird Power Systems 4 Nov 19, 2002 08:43 AM
