Old Aug 22, 2012, 01:42 PM
v-willy is offline
Find More Posts by v-willy
Joined Jan 2006
Wc 2012 buzau
Hallo,
Do anybody know if there are tents, table, chairs and elektricity available at the contest site.
Willy
team Belgium
v-willy is offline Find More Posts by v-willy
Old Aug 22, 2012, 02:13 PM
Gerben is offline
Find More Posts by Gerben
Joined Dec 2004
And which way the course will be?
Gerben
Dutch F5B team
Gerben is offline Find More Posts by Gerben
Old Aug 22, 2012, 04:27 PM
George Shering is offline
Find More Posts by George Shering
Scotland
Joined May 2005
We were told that there will be tables with sunshade/umbrellas over them.
George Shering is offline Find More Posts by George Shering
Old Aug 23, 2012, 06:44 AM
Mark Haigh is offline
Find More Posts by Mark Haigh
Mark Haigh's Avatar
Barnsley, Great Britain (UK)
Joined Dec 2000
Gerben
Dutch F5B team
I asked Marius the question but had no response.
Mark.
Mark Haigh is offline Find More Posts by Mark Haigh
Old Aug 23, 2012, 03:47 PM
v-willy is offline
Joined Jan 2006
I asked also before several times but no answer.
As the condition stay 36 there is need for shadow anyway.
Willy
Old Aug 27, 2012, 08:57 AM
Gerben is offline
Joined Dec 2004
was told the direction of the course will be decided when the course is built up, not in advance.
Another question: what plugs should e supplied for limiter testing?
I'm running Plettenberg plugs, so I think I should bring an adapter. From what I heard it was 6mm LMT style plugs. What plug is on positive and negative?
Also the brown wire from the shunt, is this 2mm gold and if so which plug is on the tester?
Only 2 weeks to go...so much to do!
Gerben
Old Aug 28, 2012, 03:22 AM
Mark Haigh's Avatar
Joined Dec 2000
Gerben
Gerben,
If the tester is the one used in Muncie (the Swiss one), the brown wire doesnt matter - the tester is connected with a croc-clip. If I remember correctly the tester uses 6mm SM plugs/sockets - ie. the shunt is as supplied from SM. In the FAI rules the orientation isnt specified, but I thought in Muncie the organisers published what they were (although I cant find anything!). The FAI rules say the competitor should provide adaptors to match the organisers equipment, so maybe the best solution is to make up some m-m and f-f adaptors to change your setup to match any combination.
Mark.
Mark.
Old Aug 28, 2012, 04:13 AM
David H is offline
Find More Posts by David H
Joined Aug 2004
In Muncie they could handle both Male 6mm on Positive or Negative. They had 2 set of connectors.
David H is offline Find More Posts by David H
Old Aug 28, 2012, 05:32 AM
Gerben is offline
Joined Dec 2004
Ok, thanks, I'll fire up the soldering iron
Gerben
Old Aug 28, 2012, 05:54 AM
Scotland
Joined May 2005
d) The limiter in each model should be provided with cables and 6 mm connectors, so that it can easily be checked in series with the checking system. In cases where the limiter device has other types of connectors, the competitor must provide adapters to match the 6 mm connectors used by the organiser.
e) JR/Futaba connectors should be provided on the limiter, or adapters, so that the receiver output and ESC input connections can be made to the test unit.
This is the section, 5.5.1. It only specifies 6mm connectors for power and JR/Futaba for signal. As Mark says they provided the adaptors.
Old Aug 28, 2012, 02:50 PM
v-willy is offline
Joined Jan 2006
It will be a new testing device i have heard. It will work quicker.
Willy
Wanted Wanted!!! Wanted!!! Wanted!!! Futaba 9ZAP WC II. onopko max Aircraft - General - Radio Equipment (FS/W) 14 Jan 19, 2013 03:56 AM
Discussion F3J WC USA Reports jimsoars Multi Task F3X 203 Sep 06, 2012 07:17 AM
Discussion Hong Kong Pilots for 2013 WC ThomasLee Hand Launch 0 Aug 09, 2012 07:37 PM
Discussion i think i got it =wc= day 3d wc_wickedclown Electric Heli Talk 2 Jun 13, 2012 09:26 PM
Discussion F3J WC South Africa 2012 GNieuwoudt Multi Task F3X 5 Jan 13, 2012 07:12 AM
