Old Sep 15, 2012, 08:22 AM
therealthing691 is offline
Find More Posts by therealthing691
therealthing691's Avatar
australia
Joined Apr 2007
what medium is the actual material and can it be varied cheers Brian
therealthing691 is offline Find More Posts by therealthing691
Old Sep 15, 2012, 10:15 AM
KJELL is offline
Find More Posts by KJELL
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
The material is White strong little flexible plastic. You can cut, drill and making threads in it.
KJELL is offline Find More Posts by KJELL
Old Sep 19, 2012, 01:03 PM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
The first Kjell-Wiggle-Drive made of 3D printed plastic part, mounted on a PH gears is now ready for bench tests.
Old Sep 19, 2012, 02:31 PM
Snetzka is offline
Find More Posts by Snetzka
Snetzka's Avatar
Auckland.
Joined Jun 2010
Is that a Spanish Bird, Kjell...???
Good to see the progress continues, I see you have changed to a horizontal shaft set-up - good move (common / shared parts = less weight.)
I am waiting on Some 3D Printed parts - (from a local source) to curb my weight obsesion.
Keep up the good work..
Mike..
Snetzka is offline Find More Posts by Snetzka
Old Sep 19, 2012, 04:56 PM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
is the dove of peace
Old Sep 19, 2012, 06:39 PM
Aeronut41 is offline
Find More Posts by Aeronut41
RC Guy Having Fun!
Aeronut41's Avatar
Joined Apr 2010
Love it Best, Aero
Aeronut41 is offline Find More Posts by Aeronut41
Old Sep 20, 2012, 09:48 PM
seagull10 is offline
Find More Posts by seagull10
Joined May 2011
Kjell , Does your bird ( in the next video) flies with equal up / down flapping angles under / over the horizontal line .I mean with 0 degree average dihedral?
Thanks in advance
http://www.youtube.com/watch?v=Y50kZ...8bYmCBWk9FqU1A
seagull10 is offline Find More Posts by seagull10
Old Sep 21, 2012, 02:52 AM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
This is the flap angle I am using with my Wiggle-Drive.
Old Sep 21, 2012, 09:19 AM
Joined May 2011
Kjell ,thanks a lot .Now we know, there is for sure at least one( and maybe Willy Mueler's as well) ornithopter which flies with 0 degree average dihedral.I suspect it is more difficult to pilot it than machines with some average dihedral and as we know you ,you are much,much more designer than pilot but you cope great with piloting in the video .Just it is too short.
Thanks again
Otto
Old Sep 21, 2012, 10:42 AM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
Swift’s are using this wing movement in fast flight.
Old Sep 22, 2012, 12:13 AM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
My small W-Bird test.
The plastic printed Wiggle parts have now been tested. After 4 hours flying test in my rotating test bench, flapping at 4Hz. The result is good. There are no signs of wear in the plastic parts.
Old Sep 22, 2012, 01:34 AM
australia
Joined Apr 2007
Cool well done regards Brian
Old Sep 23, 2012, 09:32 AM
Joined May 2011
It's very compact.Going to give it a try I like it much more then wiggle heads drive.
Old Sep 23, 2012, 10:07 AM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
Let me know if you need any help.
Old Sep 23, 2012, 03:42 PM
Snetzka is offline
Snetzka's Avatar
Auckland.
Joined Jun 2010
Yes, Well done Kjell - looking really good....
Love the olive branch.. !
Regards, Mike..
Discussion Variable Wiggle Drive. Snetzka Ornithopters 216 Apr 16, 2016 11:57 AM
Discussion Kjell-Wiggle-Drive KJELL Ornithopters 12 Apr 10, 2015 12:44 AM
Discussion wiggle drive propulsion SudorracMechEng Dock Talk 12 Aug 17, 2012 05:08 PM
Discussion wiggle drive propulsion application SudorracMechEng Scale Boats 7 May 15, 2012 12:18 PM
Discussion wiggle drive propulsion SudorracMechEng Power Systems 1 May 07, 2012 06:58 AM
