Old Aug 22, 2012, 12:54 PM
KJELL is offline
Find More Posts by KJELL
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
NEW Kjell-Wiggle-Drive
Prototype of the new Kjell-Wiggle-Drive with simple wing motion without active wing twist.
New Kjell Wiggle Drive0 (1 min 16 sec)
KJELL is offline Find More Posts by KJELL
Old Aug 24, 2012, 02:38 AM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
The new K-W-D can be made very silent, compared with the Crank Drive.
Old Aug 24, 2012, 10:56 AM
seagull10 is offline
Find More Posts by seagull10
Joined May 2011
New
seagull10 is offline Find More Posts by seagull10
Old Aug 27, 2012, 10:27 AM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
Originally Posted by seagull10 View Post
New application for your old marine drive. I like it. Just can't understand why it is more silent than the crank drive? Here it is ,even with adjustable flapping amplitude:
Before trying to reduce mechanical noise, it is important to know where the noise is produced.
The crank drive makes two different kind of noise.
The gears are installed in the open air without good lubrication.
The backlash in the con-rod makes a knocking noise when changing direction.
The K-W-D , can be made less noisy by enclosing the gears in a lubricating box.
There is no backlash in the Wiggle-Drive rotating power transmissions. .
Old Aug 28, 2012, 06:25 AM
vlatko is offline
Find More Posts by vlatko
vlatko's Avatar
Croatia, Osijek-Baranja County, Osijek
Joined Feb 2006
Hey Kjell,
are there any kind of plans so others can build your wiggle drive?
Also, is there a video of the orni flying with the wiggle drive?
Thanx
vlatko is offline Find More Posts by vlatko
Old Aug 28, 2012, 01:51 PM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
Anyone can build an orni with wiggle-drive.
W Bird1 (1 min 15 sec)
Old Aug 28, 2012, 06:02 PM
vlatko is offline
vlatko's Avatar
Joined Feb 2006
Thank you Mr. Dahlberg. Nice video!
Old Aug 28, 2012, 07:29 PM
Joined May 2011
Kjell , I don't want to argue with you but every gears' transmission can be enclosed in a box and well lubricated, doesn't mater what kind of rotary to reciprocating motion mechanism is powered by this transmission. The question is how much weight will be added.
As about backlash probably in your mechanism it will be more because you have more consequently connected parts and this summarize backlash from all joints.I don't think that this will be a problem even in your mechanism if the bearings used are in good condition .
Old Aug 29, 2012, 01:42 AM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
Kazu-kaku, in the Kestrel 17 has resolved to reduce the gear noise by enclosing it inside his foam body. The knocking noise from the backlash in the con-rod is still there. The Wiggle-Drive don’t produce any knocking noise.
Old Sep 14, 2012, 09:31 AM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
The 3D Printed parts for the K-W-D has now arived.
Old Sep 14, 2012, 10:29 AM
Joined May 2011
Bravo Kjell they are very light.
What the relative weight of this material is?
How much the printing of this parts cost you?
Do you provide 3D CAD models or printing guys created it?
How they determine the price ,by the volume of the printed object or in some other way?
Thanks for sharing
Old Sep 14, 2012, 11:26 AM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
I provide 3D CAD drawings and they convert these drawings in printable format for their 3D printer.
The parts have been made by http://www.shapeways.com/
Old Sep 14, 2012, 11:38 AM
Joined May 2011
Thanks Kjell
Old Sep 14, 2012, 01:58 PM
vlatko is offline
vlatko's Avatar
Joined Feb 2006
The price for 3D printing is usually calculated by the amount of the used material.
Old Sep 15, 2012, 07:38 AM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
Reducing the weight is important. I like the material made by the 3D printing. It opens up a new way to make ornithopter parts.
Discussion Variable Wiggle Drive. Snetzka Ornithopters 216 Apr 16, 2016 11:57 AM
Discussion Kjell-Wiggle-Drive KJELL Ornithopters 12 Apr 10, 2015 12:44 AM
Discussion wiggle drive propulsion SudorracMechEng Dock Talk 12 Aug 17, 2012 05:08 PM
Discussion wiggle drive propulsion application SudorracMechEng Scale Boats 7 May 15, 2012 12:18 PM
Discussion wiggle drive propulsion SudorracMechEng Power Systems 1 May 07, 2012 06:58 AM
