Old Aug 22, 2012, 01:15 AM
reblacklaf is offline
Find More Posts by reblacklaf
Common Sense Support Crew
Rensselaer, IN USA
Joined May 2006
New to programmable TX's Futaba 9C
I have a Futaba 9C TX. The rudder and ailerons only work in 1 direction. Going to the servo screen I only get movement to the left it doesn't come off neutral with the stick to the right. On servo 4 I get nothing in either direction. I set the profile to factory settings. I am using a Frsky 2.4 DFT module. I have tried the Spectrum DSM2 with the same result. Putting the original 72mhz module in gives the same result. If I turn test ON everything seems to cycle fine. Could I have made a setup error when trying to reset to factory defaults?
Randy
reblacklaf is offline Find More Posts by reblacklaf
Old Aug 22, 2012, 05:02 AM
AndyOne is offline
Find More Posts by AndyOne
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
Each model memory needs to be reset individually, did you reset one memory and then use another which hadn't been reset.
A.
AndyOne is offline Find More Posts by AndyOne
Old Aug 22, 2012, 08:41 AM
Rensselaer, IN USA
Joined May 2006
Tried that and everything is working fine now.
Randy
Sold Futaba 9c with FrSky Tx modual & FrSky 7ch Rx TBello Aircraft - General - Radio Equipment (FS/W) 2 Aug 05, 2012 11:34 PM
Sold )))NEW PRICE....now $225.00 shipped((( Futaba's new 8JH TX & RX NIB crosby Aircraft - General - Radio Equipment (FS/W) 7 Aug 03, 2012 10:13 AM
Wanted Futaba 9C ch 52 tx Module bvrcgeoff Aircraft - General - Radio Equipment (FS/W) 1 Jul 18, 2012 06:11 PM
Off Site Like new Futaba 8JH 2.4 GHz TX and RX S-FHSS/FHSS crosby Aircraft - General - Radio Equipment (FS/W) 4 Jul 07, 2012 03:53 PM
Multiplex Evo's vs Hitec Eclipse 7 or Optic 6 vs Futaba 9C /Super 9C or any other Tx' pjm21b Radios 1 Oct 14, 2004 10:08 PM
