A couple of comments on guns...
BP guns are dangerous.... the length to diameter ratio needs to be kept very low (about 5:1 max) to keep internal pressure from blowing these thin brass barrel guns apart. Another recent learning....ignition toward the muzzle end of the charge rather than at the breech end seems to give a bit longer "burn" and more smoke per weight of powder. Ingnition at the back of the charge tends to blow some of the unburned charge out, perhaps due to the short barrel and the absence of mass (projectile) in front of the charge. The effect from a 3.5mm ID gun will not likely be too dramatic. Over time, the Syren carronades increased to 5/16" (8mm) ID to get a good smoke volume and "puff diameter". Wind and distance greatly reduve the smoke puff effect. Since the gun muzzle isn't a hugely visible feature, especially at a distance, the balance between scale dimension and functional dimension for muzzle ID needs to be considered. Suggestions - make the barrel L shorter vs diameter, and consider making the 6pdr barrel a bit larger OD (larger than scale) to allow larger brass liner barrel ID. Also might consider turning the whole muzzle section from brass pipe nipples - fairly cheap, readily available and fairly easily turned on a small lathe. Also, maybe make just one or two test barrels to confirm performance before having the lot made. Just tossing this in since you mention that you are zeroing in on final design. If you do use brass tubing, K&S round brass tubing (.014" wall) has diameters in 1/32" increments. Link to K&S: http://www.modeltool.com/kands/kands1.html |
Dan
FANTASTIC! Your Tiger II looks beautiful. Thanks for sharing that. The only forums my builds are on are 1:6th scale forums. Tiger build is about 1/2 way down the Tiger 1 page on Armortek's site. The Panther is under the Panther index page. It might be a few pages back as it's an older thread. http://www.armortek.co.uk/Forum3b/viewforum.php?f=6 Panther, Tiger 1, Panzer IV and Opel Blitz projects are on this site. Less of an RC site, more of a 1:6th hobby site. Some amazing static stuff here too! http://www.sixtharmygroup.com/forums/ I have a1:6th Tiger II waiting to be built. It will be Tiger # 132 from Kampfgruppe Peiper, Ardennes. This was commanded by the same man that commanded my Tiger 1 # 223 from Normandy. : ) Armortek used to offer a 12 gauge blank firer for their kits. I have one waiting ti go in the King Tiger. : ) The smoker units I finally settled on were built by a friend in the UK and provide a nice belch of smoke at start up and rev. The are wired into the Benedini sound cards I use. Excellent sound cards BTW. kindest regards Tim |
| Thread Tools | |
| Discussion Square Rigger kit-18 Gun Brig-of-war of 1797 | Ray C | Scale Sailboats | 2975 | May 14, 2013 10:01 AM |
| Sold Deans Marine HMS Skirmisher "Scout"-class Light Cruiser | ted99 | Boats (FS/W) | 6 | Jul 01, 2012 05:51 PM |
| Build Log 1842 Brig-of-war US Somers | meatbomber | Scale Sailboats | 207 | Nov 09, 2011 01:52 AM |
| Discussion 10 Gun Brig Cherokee Class Brig Sloop | Gerald K | Scale Sailboats | 20 | Jul 01, 2011 01:11 PM |
| Question hms cruiser class 1797 | dogdog | Scale Boats | 1 | Apr 05, 2007 08:11 AM |
