Old Jan 26, 2013, 06:48 PM
TBowman is offline
Find More Posts by TBowman
TBowman's Avatar
United States, CA, San Jose
Joined Aug 2012
Hi everyone in the 1:24th scale world.
I'm planning on making a set of signal flags for my ship in scale and was wondering if anyone else would be interested. I'll be doing the artwork myself and am looking into suitable materials and methods of printing them. Pennants as well and possibly ensigns.
Will post some more on it as this small side project progresses.
Tim
TBowman is offline Find More Posts by TBowman
Old Jan 26, 2013, 08:48 PM
yancovitch is offline
Find More Posts by yancovitch
Joined Oct 2006
beautiful deck work!!!....compared to this build, my ship is an, although fun to look at, amateurish effort at best...and that's a fact
yancovitch is offline Find More Posts by yancovitch
Old Jan 26, 2013, 09:10 PM
Pond Sailer is offline
Find More Posts by Pond Sailer
Pond Sailer's Avatar
United States, CA, Castro Valley
Joined Mar 2012
Tim, yes I am in on flags, not sure how many you are planning on, but I would take 6 sets.
Does that help? I could do more if I think about it a bit more.
Gary.
Pond Sailer is offline Find More Posts by Pond Sailer
Old Jan 27, 2013, 05:06 AM
meatbomber is offline
Find More Posts by meatbomber
Square-rigger
meatbomber's Avatar
Klatovy, Czech Republic
Joined Mar 2004
Ah no Vic, that deck is printed (except teh treenail fakes) so no reason to put your light under the bucket again
meatbomber is offline Find More Posts by meatbomber
Old Jan 27, 2013, 07:54 AM
Jpop Andrew is offline
Find More Posts by Jpop Andrew
Jpop Andrew's Avatar
United States, IN, Indianapolis
Joined Nov 2010
I was also thinking about doing some signal flags eventually so I'd be very interested. "Bowman expects every Scorpion to do their duty!"
Btw your stem turned out awesome.
Jpop Andrew is offline Find More Posts by Jpop Andrew
Old Jan 27, 2013, 10:41 AM
TBowman is offline
TBowman's Avatar
Joined Aug 2012
Hi Vic,
As Meatbomber said...nothing special here. Only added the nails to Philips kit-supplied, excellent deck. Thanks for the comment though. I can only dream of being able to build ships like yours.
Gary, We'll see if I can make the flags look acceptable and also cost effectively. I know there are some out there already available but hoping to make them look more real.
Thanks Andrew
Kind regards
Tim
Old Jan 27, 2013, 02:35 PM
Joined Oct 2006
awe shucks..darn it....another opportunity to belittle myself foiled again!
probably no use to you, but i got my flags made at:
info@customflagmaker.com
when i got them i discovered they came all the way from turkey .....
Old Jan 28, 2013, 02:56 PM
TBowman is offline
TBowman's Avatar
Joined Aug 2012
Thank you for the link Vic
I'm going to try and do them. I have a few ideas on how to make them so they look as "scale" as I can.
This is just the initial artwork I did to get the correct dimensions and scale for each size ensign, the pennants and the signal flags. Not all the ones I want to do but just the first quickies. Only one side is shown
also thought this was kind of neat. I read the history and service record for Scorpion again and then read about one of her commanders(pictured below). The stories read just like a Patrick O'brian novel. Amazing. Unfortunately, after he transferred to command a Frigate as Post Captain of (an older ship on which he had served as a Midshipman), he was killed by grapeshot while engaging a 40 gun French frigate. The French ship was captured in the action.
Tim
Old Jan 30, 2013, 12:25 AM
TBowman is offline
TBowman's Avatar
Joined Aug 2012
Davits
These won't be mounted until I decide on the two stern, enclosed structures but wanted to get the basic shape and dimensions.
Tim
Old Jan 30, 2013, 06:54 AM
DanL is offline
Find More Posts by DanL
DanL's Avatar
United States, MN, Brainerd
Tim,
Every part you design is a work of art.
As usual, I'll venture my 2 cents worth...
The davits take hits, and can, under some conditions, snag the boom sheet when it goes slack.
Syren davits are each attached with a single small, short screw (near the center hole in your drawing) In addition, there are two very short alignment pins where you show screw holes. No adhesive used. The short attachment screw allows removal of the davits if desired, easy replacement if they get damaged, and serves as a breakaway feature if they take a hit. The screw head is small and barely visible under the cleated line on the davit.
Suggest not filling the screw holes after mounting as the drawing indicates.
DanL is offline Find More Posts by DanL
Old Jan 30, 2013, 02:20 PM
TBowman is offline
TBowman's Avatar
Joined Aug 2012
Hi Dan
More wise words from your experience. Easy enough to make it so I can pull them off if needed and have the fasteners semi-concealed. Will make a few extras as well to add to my "spares" box.
Thank you
Tim
Old Jan 31, 2013, 04:36 PM
TBowman is offline
TBowman's Avatar
Joined Aug 2012
Scorpion has a rudder!
The clear extension/insert will be made further down the road in the build.
It's sitting slightly low. I'll take care of that with a spacer/washer at the bottom of the shaft.
Also assembled the bow sprit pieces just for fun and was amazed at how big it suddenly looked! Made me grin. : )
more soon
Tim
Old Feb 01, 2013, 05:35 PM
TBowman is offline
TBowman's Avatar
Joined Aug 2012
Some first tests of the 12X24 foot white ensign.
I have a half dozen different materials to try. I liked this one because of it's light weight and nice texture and coloring. Will try a few others too.As with any two-sided print, registration will be a slight challenge but think I can get it close enough to be acceptable.
quick stitch test. Will get proper color threading before I attemp a final one.
Here's an image of a real one.
Have been debating with myself on whether to add all the other stitching or not for the stripes and panels. The other option is to add it to the artwork. Will try some samples of both and see how it looks.
Tim
Old Feb 01, 2013, 07:35 PM
Joined Oct 2006
you didn't print that yourself?...two sides?...no bleeding?...i went to a special print shop that prints t-shirts etc...., and even they couldn't do it....the ink bled and no definition....what did you do???
if you keep on being so immaculate, you're going to cause others to quit the hobby ...you can name the boat "immaculate conception"
Old Feb 02, 2013, 12:37 AM
TBowman is offline
TBowman's Avatar
Joined Aug 2012
Hi Vic
Yes, printed them myself. Once I have some good thread, I'll sew a few of the flags. By the time I get to the last few, I should have the registration figured out. I should have mentioned that the real one shown above is actually a WWII one. So not the best example but good for coloring.
Here's an actual Trafalgar survivor. This recently auctioned off at 680,000.00(can't remember if it was in BP or dollars). It was still with the family of a Captain that was there on a frigate(I think)and kept it in a drawer his whole life then passed own generations.
A few signal flag tests and a red ensign.
more soon
Tim
Discussion Square Rigger kit-18 Gun Brig-of-war of 1797 Ray C Scale Sailboats 3007 Nov 27, 2015 10:14 AM
Sold Deans Marine HMS Skirmisher "Scout"-class Light Cruiser ted99 Boats (FS/W) 6 Jul 01, 2012 05:51 PM
Build Log 1842 Brig-of-war US Somers meatbomber Scale Sailboats 207 Nov 09, 2011 01:52 AM
Discussion 10 Gun Brig Cherokee Class Brig Sloop Gerald K Scale Sailboats 20 Jul 01, 2011 01:11 PM
Question hms cruiser class 1797 dogdog Scale Boats 1 Apr 05, 2007 08:11 AM
