Old Nov 17, 2012, 11:56 PM
pullup! is offline
Find More Posts by pullup!
HellBentPuppet
pullup!'s Avatar
Co.
Joined Jan 2005
Well I just checked my ESC, I don't have that mystery component on mine either. Is the servo lead long enough without it??
On the issue of tape, I used the green Frog Tape for gluing process with no paint loss.
pullup! is offline Find More Posts by pullup!
Old Nov 18, 2012, 12:16 PM
jl449 is offline
Find More Posts by jl449
Salinas, CA
Joined Dec 2007
Glued my snap in half fuselage with CA so no tape needed for this repair job. Took her out this morning!!
Accidently flew with a 3s 2200 40c battery on my first flight. Got mixed up with my 4s batts (early morning and didn't drink my coffee!). She flew pretty good... lack of power. At first I thought I had an issue with the motor or esc but I kept her in the air and flew pretty good just lacking climbing power. Put the 4s batt and oh yeah I got power!!!
jl449 is offline Find More Posts by jl449
Old Nov 18, 2012, 07:43 PM
crawlspace is offline
Find More Posts by crawlspace
crawlspace's Avatar
Pacific Northwest
Joined Jan 2009
Thanks for checking it out and weighing in. I got an updated one since my gear fit without mods so I wonder if they added it later for some reason. I'm leaning on taking it out since none of the planes I've seen or owned has had one. Still wish I knew what it was though.
I also noticed the motor will not arm until you move to full throttle then back to zero throttle. This is only required the first time you plug it in, afterward it arms at zero throttle on power up like normal.
crawlspace is offline Find More Posts by crawlspace
Old Nov 19, 2012, 06:35 PM
jokeane is offline
Find More Posts by jokeane
"Spark Chaser"
jokeane's Avatar
United States, WI, Middleton
Joined Jun 2004
I am just about finished building my Devil ... I too have the mystery circuit
It is on a little extension on the ESC servo connection. Small circuit board in black shrink wrap.
No idea what it is. Nothing in the manual about it. Sure would be nice to know what it is for. My guess is it is some sort of voltage regulator ... but who knows for sure.
FWIW, the landing gear on my Devil fit perfectly. So that issue appears to be addressed. Paint is not quite as nice as on my Peaks (Pitts). But not too horrible. Would be nice to have a couple of color schemes to choose from like Peaks.
I won't be using the Devil decals... it is after all an Ultimate. :-)
jokeane is offline Find More Posts by jokeane
Old Nov 21, 2012, 07:10 AM
crgonzalez08 is offline
Find More Posts by crgonzalez08
Carlos G.
crgonzalez08's Avatar
United States, UT, Centerville
Joined Aug 2008
Well guys, I got 1 of these plans for my birthday. No I haven't have anything but problems with these new plane. After I finished putting it together I funded out that the ESC wasn't powering up the Rx, sended that back to NP for a replacement. I installed a 60a esc I have and now I have power to the Rx, but now I know that the two servos in the tail are BAD..........so I guess I have to replace does too. Here is a link to a video I just made showing the problems with the plane
NITROPLANES DYNAM DEVIL3D REVIEW "BAD" (6 min 11 sec)
crgonzalez08 is offline Find More Posts by crgonzalez08
Old Nov 21, 2012, 09:06 AM
dskalski is offline
Find More Posts by dskalski
Turn up the G's !!!!
dskalski's Avatar
United States, VA, Virginia Beach
Joined Jul 2010
https://www.youtube.com/watch?v=asBg...e_gdata_player
Check the extention wire that is connected to the servos in the rear. Maybe it is plugged together backwards. Last time I did this the servo didn't work. But, I can't remeber if the servo moved like that when plugged into the receiver.
dskalski is offline Find More Posts by dskalski
Old Nov 21, 2012, 02:45 PM
Carlos G.
Joined Aug 2008
I took the servos out and try them straight from the Rx and they are busted, don't know what's wrong with them, one will just move slowly to one side and the other one it totally dead
Old Nov 21, 2012, 11:17 PM
mjdee14 is offline
Find More Posts by mjdee14
mjdee14's Avatar
Nashville TN, USA
Joined Jun 2004
I assume you have tried plugging another servo into the reciever and it works correctly?
What are the odds of BOTH servos being bad at the same time? I wouldn't think it was that until I hada servo work correctly in the reciever....some recievers I have had had the signal wire facing in one direction....while another brand faced in the opposite direction. Do the ailerons work OK?
mjdee14 is offline Find More Posts by mjdee14
Old Nov 22, 2012, 11:31 PM
Carlos G.
Joined Aug 2008
yeah, alerons where OK, just the two 18g servos where bad, they didn't work on any Rx i try'm with one just moves one way and the other is totally dead.
But I installed new servos on and test fly it today, it flys really good. Im running 4s2200mhA 40C batteries and the plane haves power but not as much as I thought it will have, Im not sure if is because we are at 4000 feet asl in Salt Lake City, UT.
Old Nov 23, 2012, 12:26 PM
mjdee14 is offline
mjdee14's Avatar
Nashville TN, USA
Joined Jun 2004
Glad you got it sorted out......but "Shame on Dynam" for using such crummy servos. with as cheap as decent servos are today....there is no reason ot have servos that either fail, don't work or have caused several crashes. Several of my buddies are flying the Dynam t28 and thsoe servos hold up fine....
Old Nov 24, 2012, 09:32 AM
Fearse is offline
Find More Posts by Fearse
Fearse's Avatar
Joined Jan 2012
Has anyone been able to find this model in kit form? I would rather put my own set up into this like I did with my peaks.
Fearse is offline Find More Posts by Fearse
Old Dec 03, 2012, 12:30 AM
jl449 is offline
Salinas, CA
Joined Dec 2007
Just ordered my 2nd Devil. Lost my first one due to a fire
I almost went with the Pitts but I decided to stick with the devil. I had a blast with the first one.
Now I'm looking to replace my Dx6 with either a 7 or an 8. Any suggestions?
Old Dec 03, 2012, 07:13 AM
w4yn is offline
Find More Posts by w4yn
United States, NC, Charlotte
Joined Jan 2007
I have 6 and 7 my friend has 8. Interface and programming is similar on 6 and 8 different on 7. I would verify that 6 and 8 are similar, but I know for sure 6 nand 7 are way different. Wish I had gone with 8 to keep programming similar.
Tim
w4yn is offline Find More Posts by w4yn
Old Dec 03, 2012, 08:03 AM
kman24 is online now
Find More Posts by kman24
Addicted To Flying Foam
kman24's Avatar
United States, NE, Bennington
Joined Jan 2010
I just got the DX8 this weekend for my b-day. Strongly recommend it
Kman
kman24 is online now Find More Posts by kman24
Old Dec 03, 2012, 12:46 PM
jl449 is offline
Salinas, CA
Joined Dec 2007
I'm getting an 8. who has the best prices on the net?
Poll Dynam 3D/Aerobatic Planes - Which would you select? Diesel6401 3D Foamies 3 Jun 29, 2012 02:11 PM
Help! Blue Devil Destroyer Catevari Racing Boats - Electric 1 Jun 15, 2012 08:35 PM
Discussion ALZRC Devil 450 PRO!! 3GY gyro ver 2.0.3 pitchp Mini Helis 7 Jun 10, 2012 10:30 PM
Alert Last of the Devil's Brigade Twizter68 Life, The Universe, and Politics 2 Apr 13, 2012 11:33 AM
Devils advocate...Micro 3D Helis????? Flyin Brick Micro Helis 6 Nov 04, 2005 08:36 PM
