Old Mar 02, 2013, 12:17 AM
Robot_Rick is offline
Find More Posts by Robot_Rick
Joined Feb 2013
So this is my first dynam bird and when I plug in my battery and power it up the motor beeps at e continuously. Manual says its a voltage issue but both batteries that I tried did the same thing (14.8v 2200mah 30c electrifly's). Got any quick troubleshooting tips? I'm not running a bec, controls are on a separate circuit.
Robot_Rick is offline Find More Posts by Robot_Rick
Old Mar 02, 2013, 03:00 AM
Joined Feb 2013
Ah figured it out. Going to maiden her tomorrow hopefully!
Old Mar 02, 2013, 12:09 PM
viper1216 is offline
Find More Posts by viper1216
United States, RI, West Warwick
Joined Mar 2009
Best of luck on the maiden.
viper1216 is offline Find More Posts by viper1216
Old Mar 05, 2013, 10:25 AM
RCAV8T0R is offline
Find More Posts by RCAV8T0R
Feeding the RC Addiction
RCAV8T0R's Avatar
United States, CA, San Diego
Joined Apr 2011
Elevator Rework...
...paid off after all......
Got a chance to fly the D-3D four times last weekend & I'm happy to say she's flying even better now. Flew her in some pretty strong winds too, the kind that used to keep me (mentally) grounded. Anyway, I mustered up the nerve to take her up & it was well worth it. Almost all up trim is gone to keep her flying neutral. Before the heat treatment it seemed like it took about 5 or 6 degrees of up elevator to counter this badly warped control surface......
Still the same responsive aerobatic ship that fits well for my style of flying & she doesn't complain when it comes time to land. Can't wait to rack up more stick time on her now that she's even more dialed in...
RCAV8T0R is offline Find More Posts by RCAV8T0R
Old Mar 05, 2013, 03:04 PM
jl449 is offline
Find More Posts by jl449
Salinas, CA
Joined Dec 2007
I flew 4 packs yesterday afternoon with some good wind blowing. I would say the Devil sure can handle the wind! Typically yesterday's wind would have grounded me but not with the Devil.
jl449 is offline Find More Posts by jl449
Old Mar 05, 2013, 08:28 PM
dkrhardy is offline
Find More Posts by dkrhardy
United States, FL, The Villages
Joined Oct 2010
I flew 6 batteries yesterday. This plane just loves to fly!
Don
dkrhardy is offline Find More Posts by dkrhardy
Old Mar 05, 2013, 11:47 PM
crawlspace is offline
Find More Posts by crawlspace
crawlspace's Avatar
Pacific Northwest
Joined Jan 2009
If it's already been posted I apologize but putting a properly balanced APC 13X6.5 on instead of those terrible black props it comes with is the best thing you can do for any of the Dynam planes that come with them. Great power and flies well even with the elevator cupped, it just needs some up trim but flies very neutral when trimmed for level flight. Great flying foam plane.
crawlspace is offline Find More Posts by crawlspace
Old Mar 06, 2013, 07:57 AM
dkrhardy is offline
Joined Oct 2010
I have a PILE of props, so I will give an APC a shot. I was so surprised that the black props were almost perfect balanced that I never gave a thought to changing.
I am sure the plane flies fine with the cupped elevator, with trim, but what about inverted? Then the trim works against you. With a straight elevator, and almost no trim, I fly it upside or downside perfectly flat. It is worth a bit of fixing, IMHO. But if you don't spend much time inverted, it is a fine flying plane ... just trim it!
Don
Old Mar 06, 2013, 03:12 PM
dkrhardy is offline
Joined Oct 2010
Way too windy to fly, so I spent some time balancing a new APC 13x6.5 for tomorrows flying. I tend to bounce all around when it comes to props and I never considered changing out the Dynam prop on this plane. It balanced well and seemed just fine as far as performance goes. But, I have now started down the changing props road again! Shoot, may even try this 14x7 I have. It is a low Kv motor, after all!
Don
Old Mar 06, 2013, 03:34 PM
krexken is online now
Find More Posts by krexken
smoke is my wattmeter
Longview, Tx
Joined May 2008
The 14x7 is what I use on my Peaks and it works great. Just a little more responsive overall. I bought a handful of those black props from HP because they were cheap and none of them balanced at all! The hubs were way off. Must've been a bad batch.
krexken is online now Find More Posts by krexken
Old Mar 06, 2013, 09:43 PM
crawlspace's Avatar
Pacific Northwest
Joined Jan 2009
Same for me on the black props, I have three of the Dynam planes that came with them and the hubs on all of them were way out of balance. This isn't too uncommon but since the hub isn't solid it makes it really hard to balance. As long as the ESC can handle the extra current I'll have to give the 14x7 a try.
Old Mar 07, 2013, 10:16 PM
poiyt is offline
Find More Posts by poiyt
United States, GA, Newnan
Joined Aug 2010
Questions before Buying the D3D
Fellas, I need a bipe.
I had a Peaks a long while back, and it was ok; but didn't set my metaphorical hair on fire...and I had to mod the heck out of it to get it to 3D right. Anyway, I sold it.
But I need a 40" foam bipe, and this looks like a contenda. I'm 3D heli & airplane (ala Crack Yak Lite, etc), so that's my interest.
Now as to this Dynam:
a) will she hover; if so, how are the torque rolls & punchouts? she got enough power?
b) I prefer neutral to tail-heavy CG (for maximum snap & pop, etc)...when inverted (where I am 80% of the time) I like only very slight down elevator for level flt...so does the batt compartment have enough room to move the batt aft to achieve neutral CG?
c) are the control surfaces (mainly, elevator) ample enough to get 45-deg deflection? Has anybody added 3D long-throw servo horns?
d) how are the stock servos...ie are they fast enough, and do they center well?
NP has these in stock, so I'm thinking I'd better jump...on the other ahand, I'm looking for a plank I can bang the sticks with and really toss around...
Thx fellas, appreciate the input!
Jeff
poiyt is offline Find More Posts by poiyt
Old Mar 08, 2013, 05:12 PM
poiyt is offline
Joined Aug 2010
Anybody??
Old Mar 08, 2013, 05:40 PM
dkrhardy is offline
Joined Oct 2010
poiyt - I'm thinking that if you are into serious 3D and you've been flying Crack Yak flat foamies, you won't like this. It is not like any Tech One plane. I really don't think you can toss this plane like you want to. MHO, or my $.02.
crawlspace - I balanced up a new 13x6.5 APC and gave it a couple of batteries. Hmmmmm I don't think I liked it. To me, it felt sluggish. What is up with that? Half inch more pitch should have given it more speed, not much, but should not be sluggish. OK, will this ESC handle a 14x7? I am not a watt guru, I am easily confused. So if one of you smart folks have any info on that, post it please. Thanks in advance!
Don
Old Mar 08, 2013, 05:58 PM
RCAV8T0R is offline
RCAV8T0R's Avatar
Joined Apr 2011
Devil's Got a Hold on Me..
...for sure & I don't like being with out my "Bipenista"......
Jeff
Anybody??
poiyt,
This ship is very capable in the right hands. I'm not any kind of 3D expert but I do know she is one flickable & agile ship that can handle anything you throw at her. The stock set up is fine and you can get a lot of tail surface throws (haven't measured). The ailerons may look relatively small for this ship, but let me tell ya...she can spin lightning fast on mid-rates, plus she's got four of 'em......
She'll flat spin, blender & waterfall no problem. Knife Edges have some coupling going on but mainly due to a warped elevator, which is a fairly common defect but can be mixed out just like on the Peaks 42. She flies great inverted but the stock battery bay needs work to move the pack back to get a more neutral balance. Much too nose heavy for me in stock form......
The power system is pretty well tested in this size Dynam bird. Plus, the airframe is based on the Ultimate Bipe so she's more suited to aerobatics than even the very agile Peaks 42 is... Stock servos seem to be working well; howerver, the stock tail control linkages have too much slop, at least mine did so I replaced them. Ailerons work fine even with the short & thin rods, though these are easily replaced, too... I've had pretty darn good results flying this Lil' Devil. She'll fly on 1/3 power & then take off, not necessarily "rocket off," at full power no problem......
She'll turn on a dime & give you change as the saying goes. She's got the typical low-budget ARF issues, like the Peaks did but probably the two best reasons to have her in the fleet are 1. she can handle strong winds for her relatively small size & 2. you can't beat the price of admission for this Dynam Rx-R bird... Stand by as I'm sure others will chime in about how their D-3D flies so well too, now that the weekend's here...
Poll Dynam 3D/Aerobatic Planes - Which would you select? Diesel6401 3D Foamies 3 Jun 29, 2012 02:11 PM
Help! Blue Devil Destroyer Catevari Racing Boats - Electric 1 Jun 15, 2012 08:35 PM
Discussion ALZRC Devil 450 PRO!! 3GY gyro ver 2.0.3 pitchp Mini Helis 7 Jun 10, 2012 10:30 PM
Alert Last of the Devil's Brigade Twizter68 Life, The Universe, and Politics 2 Apr 13, 2012 11:33 AM
Devils advocate...Micro 3D Helis????? Flyin Brick Micro Helis 6 Nov 04, 2005 08:36 PM
