Old Jan 28, 2013, 06:26 PM
dkrhardy is offline
Find More Posts by dkrhardy
United States, FL, The Villages
Joined Oct 2010
Walter - I 1st talked about that when I un-boxed the plane. The elevator, both sides, drooped. I was sure that is why all maidens mentioned up trim being needed. The ailerons did too, but to a lesser degree. I straightened the elevator and semi-straightened the ailerons, but they were symetrical so I left them with a bit of droop. It seemed to add a bit of washout, and that ain't too bad for flying.
RCAV8T0R - thanks! I had bought a foam "3D" plane from HK, foam - large-all inclusive, and found it to be lacking in OH SO MANY ways. Everything was weak and I was forever chasing those gremlins, so I gave it away before it was trashed. So, I feared this was the same, very inexpensive plane with everything there. I did the mods, ala Peaks firewall, beefed the gear area, and I have all new MG servos waiting. BUT, I'm pleased, not saying that because I parted with some bucks, but because it flies nice. If I feel it is letting me down, I WILL tell you!
I did not metion earlier .... the stall (up high) is very gentle and straight ahead. No surprises! Going again tomorrow morning before the wind picks up. It is great being retired and being able to do what and where I (we) want.
Don
Ps I maidened THIS plane before I maidened my new 3DHS Yak55!! And I'm gonna fly it again tomorrow.
dkrhardy is offline Find More Posts by dkrhardy
Old Jan 29, 2013, 02:11 PM
dkrhardy is offline
Joined Oct 2010
Flew it again today. I moved the 2200 4s back about 3/8" back and took out the up trim. It was tail heavy! I had to really push on the stick to get it to descend and landing was "fun" but successful. Moved the battery back ... pronto. Next flight was as the wind picked up. It flew fine, but really wanted to balloon in the gusts. More "fun" landing than the previous flight, but on the ground with no bounce. It was nearly a stall it onto the ground 3 pointer, but from only 3 inches off of the ground. So all was well and no way hard enough to damage anything other than my pride. I am pretty good at landing and my pride does not like to take a hit!
I am liking this plane and with the shiny (GloCoat) finish, people think it is an expensive plane ....NOT! I did not put the stickers on it, so no one knows what it is until I tell them.
Don
Old Jan 29, 2013, 03:29 PM
RCAV8T0R is online now
Find More Posts by RCAV8T0R
Feeding the RC Addiction
RCAV8T0R's Avatar
United States, CA, San Diego
Joined Apr 2011
Stop It...
Don
...you're making me jealous...
dkrhardy,
You are definitely having too much fun with your lil' Devil so stop it already... Just kiddin'...
These Dynam birds are pretty darn tough & can take some unexpected or deliberate.........abuse... Now it's time to put her through her paces & see what she can really do...
RCAV8T0R is online now Find More Posts by RCAV8T0R
Old Jan 29, 2013, 10:09 PM
dkrhardy is offline
Joined Oct 2010
I was looking at the Peaks thread ..... those guys have got some strange ideas about how planes fly and how to trim. OMG!
Old Jan 29, 2013, 10:12 PM
pullup! is offline
Find More Posts by pullup!
HellBentPuppet
pullup!'s Avatar
Co.
Joined Jan 2005
Don
Congrats on your maiden and following flights! Please box up some warmer temps and send them my way
Can't wait to get Devil2 up and running. It is a good bang for the buck, and sharp looking to boot!
pullup! is offline Find More Posts by pullup!
Old Jan 30, 2013, 12:03 PM
TripleW is offline
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
I tried Medium timing on another Devil this morning, And it didn't work.
I had to go with low timing. Got rid of the stuttering off idle. Odd.
I am pretty darn sure i went with Med. on the first one.
Anyways then I tried low timing on a Peaks/Pitts and it worked as well.
* Enter program mode - Plug in with throttle all the way up.
* When you get to One Long Beep then one short Beep. Go to idle.
* Then you will here one Beep for Low Timing. Then go to Full Throttle.
* Exit program mode. With in two seconds after low timing Beep go back to idle.
Walter
TripleW is offline Find More Posts by TripleW
Old Jan 30, 2013, 05:13 PM
dkrhardy is offline
Joined Oct 2010
My stutter went away by pulling the power trim down a bit. I presume that the timing thing may be the correct cure.
Tomorrow should be the maiden, wind permitting.
Don
If the default timing is med or high, then going to low timing to stop the stutter is not any better than what I did. At 50% power, I'm screaming along with the stock, balanced, prop. That is on default setting with trim to stop the stutter. I also have a APC prop, same size, that I need to try since some say they are better (stiffer) than the Dynam prop.
Don
Old Jan 30, 2013, 06:14 PM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
I'm not sure what the default timing is, Now. I know you can trim it to an idle setting, But we just didn't like it to stutter trying to get there.
Precision Aerobatics recommends VOX props over APC's.
Go to prop selection.
http://www.precisionaerobatics.com/p...ls.php?pid=418
VOX
http://www.precisionaerobatics.com/c...?cid=70&pcid=4
Old Jan 31, 2013, 10:47 AM
kman24 is online now
Find More Posts by kman24
Addicted To Flying Foam
kman24's Avatar
United States, NE, Bennington
Joined Jan 2010
Devil 3D Build Video
http://www.rcgroups.com/forums/showthread.php?t=1821596
kman24 is online now Find More Posts by kman24
Old Jan 31, 2013, 07:34 PM
pullup! is offline
HellBentPuppet
pullup!'s Avatar
Co.
Joined Jan 2005
Sneak peak at the new paint job progress........
Old Jan 31, 2013, 08:42 PM
dkrhardy is offline
Joined Oct 2010
OMG! That looks like the HK MX2. Same colors .... and that gremlin infested little bastig was a REAL PITA!
My Devil is a tame critter, I hope your "painted" plane does well.
Don
Old Jan 31, 2013, 09:54 PM
RCAV8T0R's Avatar
Joined Apr 2011
Gettin' There...
...with those custom colors......
pullup,
Comin' right along with your repaint. Does look like it would be a big pain in the neck to strip her first, though... On the plus side it'll be a lot nicer quality than stock... How about decals or stickers, any plans for those...
Old Feb 01, 2013, 11:11 AM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
pullup, That looks good!
What kind of paint are you using?
Old Feb 01, 2013, 01:32 PM
dkrhardy is offline
Joined Oct 2010
Flew it again today. I tried the 2650 batteries (I thought they were 2450, but no they are 2650) and found they work well at about 1/2" back from the 2200 balance point. I flew them for the same amount of time, 5 min, and they had the same voltages as the smaller batteries ... when finished. ??? Maybe I'm flying it a bit harder as I get more used to the plane. I like to finish up with 3.7 to 3.8 volts per cell since that is storage voltages. Just put them on the shelf until time to charge and fly.
Great flying now that I re-did the rates and expo. On low I have 60% and expo at 50. Very smooth until I bang the stick. That really livened up the roll rate yet keeps it docile for smooth turns in the pattern. Folks commented on how precise it flies.
Don
Old Feb 03, 2013, 01:56 PM
dkrhardy is offline
Joined Oct 2010
I did not mention that I did some verticle work as well as spins and it is a good tracker in a steep climb, not wonderful, but darned good. Spins nice since I added more aileron to it. Tomorrow is going to be a COLD morning, but as soon as the sun has had a few minutes of shine time, it will be OK for flying. Not supposed to be anything more than a breeze!
Don
Poll Dynam 3D/Aerobatic Planes - Which would you select? Diesel6401 3D Foamies 3 Jun 29, 2012 02:11 PM
Help! Blue Devil Destroyer Catevari Racing Boats - Electric 1 Jun 15, 2012 08:35 PM
Discussion ALZRC Devil 450 PRO!! 3GY gyro ver 2.0.3 pitchp Mini Helis 7 Jun 10, 2012 10:30 PM
Alert Last of the Devil's Brigade Twizter68 Life, The Universe, and Politics 2 Apr 13, 2012 11:33 AM
Devils advocate...Micro 3D Helis????? Flyin Brick Micro Helis 6 Nov 04, 2005 08:36 PM
