This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Old Aug 21, 2012, 03:25 AM
Jack Crossfire is offline
Find More Posts by Jack Crossfire
Jack Crossfire's Avatar
Calif*
Joined Sep 2006
analog BJT magic
Aren't you glad you didn't need to solder that board, but when an LF353 would either cost $20 or take 5 days to order, the easier option is some more epic analog BJT magic.
This one took a while to figure out. The object of the game was to make a comparator out of the fewest transistors. The trick was using the output of 1 side to drive the other side & using an NPN where a PNP would be used in an H bridge.
There was probably a magic search term which would have found the same thing on the goog.
So the next great hope is broadcasting pings from the ground to the aircraft. Initial tests with a single h-bridge driven transducer were promising. The trick is driving 3 transducers with a reasonable circuit, getting the aircraft to know which transducer is pinged & when, getting a ping rate high enough.
Jack Crossfire is offline Find More Posts by Jack Crossfire
Sold SSV4 Analog Servo Stretcher (from ReadyMadeRC) turbodriven FPV Equipment (FS/W) 6 Jun 27, 2012 07:29 AM
Discussion Analog Sensor kpsxtyone Eagle Tree Systems 1 Jun 18, 2012 11:36 PM
For Sale Receivers and analog servos Papasoar Aircraft - General - Radio Equipment (FS/W) 3 Jun 17, 2012 06:09 PM
Sold HDMI to Analog Converter Modded with BEC and ready to go $60 shipped Adidas4275 FPV Equipment (FS/W) 1 Jun 12, 2012 06:00 PM
