Old Feb 09, 2013, 04:01 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
JR only lists the 368BB under the micro heading. I don't think there is another kind of 368.
JR Servos
http://www.jrradios.com/Products/Servos-Air.aspx
aeajr is offline Find More Posts by aeajr
Old Feb 09, 2013, 10:44 PM
coolgg is offline
Find More Posts by coolgg
United States, WA, Bellevue
Joined Oct 2010
JR Servos
They really need a better website. See this:
http://www.jrradios.com/Products/Def...odID=JRPSDS368
coolgg is offline Find More Posts by coolgg
Old Feb 10, 2013, 03:13 AM
coolgg is offline
Joined Oct 2010
Originally Posted by mertz View Post
I completed my build a week ago and I found the only way to get the flaps to operate without binding is to bend the control rods like so.Attachment 5289711
Finally got around to installing the wing servos. I tried starting with the ailerons first and ran into issues. I get full travel smoothly of the servo when the servo is trying to push out the push rod (up aileron). But in the opposite direction (down aileron, servo pulling pushrod inward) the servo is obviously getting stressed.
Btw, if I remove the clevis from the aileron control horn, the movement is smooth. When I snap it on the aileron horn and try to move the aileron down, I hear the servo buzz but the rod is not hitting the area around the slot in the wing where the rod comes out. What could be happening here?
Just to clarify - are you guys having issues with both ails and flaps or only flaps? Mertz, did you have to do any bending of control rods for the ailerons like the one you pictured for flaps?
Old Feb 10, 2013, 03:16 AM
coolgg is offline
Joined Oct 2010
Originally Posted by TeamHorizon View Post
Guys, in the coming weeks we plan to put together a construction video to help with some of the challenges you are facing. ....Pete
Pete, where can I access this video? Many of us would greatly appreciate if you could post the link here...
Old Feb 10, 2013, 03:34 AM
timography is offline
Find More Posts by timography
Electric Glider Nut
timography's Avatar
Australia, WA, Perth
Joined Feb 2012
the weather finally settled down enough to allow a maiden flight for the Mystique. All went well. Flight report to follow shortly. Oh, for those who are interested, the MVVS performed perfectly. :-)
timography is offline Find More Posts by timography
Old Feb 10, 2013, 03:39 AM
PAT-T is offline
Find More Posts by PAT-T
Airborne whenever I can.
PAT-T's Avatar
Canada, AB, Edson
Joined Dec 2006
Part of the problem is the hinging with the covering that give some resistance
for deployment of the flaps and ailerons, maybe not on all the kits. My ailerons are going smooth up and down, but flap give resistance even at zero degrees
deployment, at least on my left wing. Have to see how the right wing will go.
Pat
PAT-T is offline Find More Posts by PAT-T
Old Feb 10, 2013, 03:47 AM
PAT-T is offline
PAT-T's Avatar
Canada, AB, Edson
Joined Dec 2006
Nice set of gliders, lovely runway too, will take some months before I can maiden
my Mistique.
Pat
Old Feb 10, 2013, 07:30 AM
Airman74 is offline
Find More Posts by Airman74
E sailplane thermal hack
USA, CA, Chico
Joined Feb 2011
Looks good Timography,, I'm jealous of your field ,, glad to hear MVVS motor worked well,, if my E Flite BL 25 doesn't work out too well, ill prob get that ( MVVS) or the Hacker 30xl. So how does the mystique fly compared to the AVIA??
Oh,,, and where exactly did you end up trimming horz stab for first test handlaunch flight??
Airman74 is offline Find More Posts by Airman74
Old Feb 10, 2013, 07:35 AM
Airman74 is offline
USA, CA, Chico
Joined Feb 2011
I found that if I mounted the servos ( both ailerons & Flaps ) to the top of the wing and NOT the bottom as suggested in manual, that I got a easier install and a little better angle,, on ailerons I put a curve in pushrod so that it looked like a Banana ,, and flaps I only used an ever so slight curve. Am getting about 55deg travel on flaps, and reccomended throw on ailerons. That's how it worked for me at least. :-)
Old Feb 10, 2013, 07:45 AM
Airman74 is offline
USA, CA, Chico
Joined Feb 2011
Got my mystique ALMOST ready,, just got to do final checks and trims, install fuse servo extensions , range check and I'm DONE!! Yeah!! Should be able to maiden at local middle school this afternoon. I'm gona have an audience,,, nothing like a little pressure huh. :-O
Old Feb 10, 2013, 11:23 AM
Jovanx is offline
Find More Posts by Jovanx
Tossing planes into the snow
Canada, BC, Smithers
Joined Nov 2011
my Mistique.
Pat
Don't let winter stop you. People regularly fly during the winter in Edmonton, PG, and Smithers. The skies are uncrowded and the landings are soft. If it's any warmer than -20C, and the wind is calm and the sun is shining, it's all good.
Jovanx is offline Find More Posts by Jovanx
Old Feb 10, 2013, 11:45 AM
aeajr is offline
LI, New York, USA
Joined Mar 2003
Some of my longest thermal flights have been below freezing on Long Island, in NY. I won't use a hi-start at that temperature for fear of damaging the rubber, but I fly electrics in cold weather all the time.
And, for me, slope soaring is only a winter time activity. I even have a full radio glove so the radio and my hands are warm inside. Works great at 5 degrees F in 15 mph wings on the slope.
I have found that winter golf gloves are outstanding for their feel on the sticks. When it is real cold I put a "hot hands" heat pack in the palm of each glove.
Winter, just another flying season for me.
Old Feb 10, 2013, 01:39 PM
PAT-T is offline
PAT-T's Avatar
Canada, AB, Edson
Joined Dec 2006
As soon I get it ready, I will fly it anyway. But right now the access road to the field is not cleared and covered with +2 feet of snow, to high for my truck.
I fly most of my smaller planes all winter long if not lower then -20C.
Lipo's are not very happy then.
Pat
Old Feb 10, 2013, 04:11 PM
Airman74 is offline
USA, CA, Chico
Joined Feb 2011
Headin out to the field for the maiden,, puuuurfect weather !! 69deg very light to non existant wind. :-) wish me luck!! Stay tuned
Jerry in Chico
Old Feb 10, 2013, 05:31 PM
Electric Glider Nut
timography's Avatar
Joined Feb 2012
Well my maiden went well, ended up moving the CG a little further forward as I wasn’t happy where it was. Ran thru two 2200maH battery packs; as I expected they were good for 3x 30 second power climbs each. Telemetry was recording that each climb was getting me to 720-770ft, which is perfect for me. No problems with the MVVS and 14x9 prop combo.
A couple of observations. This is a slippery airframe with a bit of weight [inertia] behind it. I let it get away from me in a dive a couple of times and boy it speeds up quickly. Lesson learned – pop the flaps before putting the nose down. This is contrary to how my Avia behaves, but that’s to be expected as the Avia's airframe is only a bit smaller but half the overall weight of the Mystique. It handles wind quite nicely, which is the main reason I got the Mystique; it penetrates really well. With camber applied it will turn quite slowly [and tightly] in a thermal and I ended up flying it mostly with the rudder and using ailerons to keep the bank angle in check. Again, this is contrary to how the Avia likes to be flown. Keep your speed up on approach. I have crow braking set to give about 45 degrees flap and only about 10 degrees up aileron. Plenty of control and aileron authority with those settings, for me anyway.
Overall, I’m really happy with the way it flies. Looks awesome in the air. Definitely different to any of my other e-gliders but again, that’s to be expected.
@Jerry – I followed Peter's recommendation and just set the trim on the horizontal stab so it was centered as best as I could get it. That's it!
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 12:25 AM
Sold E-flite Habu 32 ARF with E-flite Motor/Fan/Retracts/ESC/lipo ton2di Aircraft - Electric - Jets (FS/W) 3 Aug 16, 2012 07:42 PM
Sold (2) E-flite Power 32's, (2) E-flite 60a ESC, all NIB cybercrxt Aircraft - Electric - Power Systems (FS/W) 8 May 17, 2012 01:53 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 08:11 PM
Wanted WTB Art Hobby 2.5M or 2.9M e-glider rrweather Aircraft - Sailplanes (FS/W) 0 Sep 12, 2005 11:09 AM
