LI, New York, USA
Joined Mar 2003
You still have to correct for cross winds in the usual fashion which might involve both alieron and rudder input. If you can't come directly into the wind then you might want to consider using rudder to "crab" the glider in just like the power guys do. You will lose some travel on the up aileron so take that into account. |
USA, CA, Chico
Joined Feb 2011
I know this is a bit off topic,,, but have you guys seen this BRAND new BIG scale sailplane
HH has just anounced??? Might have to sell my 4.3meter duo discus to get this one Sure looks PURDY!!!!!:-) http://www.horizonhobby.com/products...2m-arf-EFL4910 HH!! Your KILLING me!!!! This sure would be a BLAST on the slope. ;-) Watch the you tube video of it |
"Powered gliders up to 2.5 kgs - 3S, 14x9.5, 27-35 amps average, 45amp maximum for 30 seconds" I come under ALL of those recommendations so I think it will handle 14x9 just fine...
Canada, ON, Hamilton
Joined Nov 2012
Thanks |
Joined Nov 2012
USA, CA, Chico
Joined Feb 2011
Any of you expert sailplane pilots out there have any ideas about a good starting point for aileron to flap mix percentage and aileron to rudder mix percentage???
I have my butterfly/landing mode set so that I have 100% aileron to rudder mix to give me more turning authority with flaps all the way down,, and I also have 0 aileron to flap mix when in landing/ butterfly mode. Any thoughts, suggestions, or comments both negative or positive GREATLY appreciated!!!! :-) Right now I have greatest amount of aileron to flap mix in speed mode, least amount of aileron to flap mix in thermal mode, and in between mix percentage in normal . Thanks!!!!! Jerry in Chico |
LI, New York, USA
Joined Mar 2003
My usual starting point for A to R is about 25%. For some gliders that is enough. For some I have had it as high as 60%. I have it on a switch. When I am in a thermal I turn the mix off and fly the rudder myself.
Flap to elevator - I start around 30%. Test it around 100 feet. Get to a level glider, as if you were making a landing approach. Now ease it in, if you have it on a variable control. Or bring it on with a switch. When it is right the glider should continue to fly with only a momentary disturbance. It should not pitch up and stall, nor should it start to dive. |
USA, CA, Chico
Joined Feb 2011
USA, CA, Chico
Joined Feb 2011
Now what about aileron to flap mixing?? One thread I was reading suggests starting with about 33% aileron to flap mixing to increase roll authority and reduce drag,, and possibly increasing beyond that in thermal mode to decrease tip stall tendencies.. Any thoughts or opinions on this???
This is why I like full house sailplanes and a sailplane radio,,, you can do soooooo much more,,, and its fun to play around with different mixing ratios in different modes. For instance in both thermal and speed mode I have my right slider able to give me more camber from my starting point or give me more reflex in speed mode. Cool stuff. :-) |
LI, New York, USA
Joined Mar 2003
I have down aileron to flap set at about 40% on my Supras, based on my understanding of guidence provided by Dr. Mark Drela, MIT, who designed the Supra and the airfoils in use on the Supra. I use about 50% on my Graphite 3.4M glider which has a different airfoil.
My flaps don't allow much up so mostly they follow the down aileron, not the up. The goal is that you will need less down aileron, less stick movement, which means less drag and less adverse yaw on the down aileron side. The flap goes down 40 to 50% of the down aileron throw. There is a lot of aerodynamic testing and theroy that lead to that recommendation. Mark's comments suggest that the amount shoud be based on the relative size distribution between the flaps and the ailerons. I am using 40 to 50% and it seems to work well. You can read Dr. Drela's comments here: http://www.rcgroups.com/forums/showt...21#post1372711 If you want to test it, put the mix on a switch. Turn it off and fly the glider for a while. Then turn it on and fly the glider. See which you like better. I am not looking for faster response or better aerobatic rolls. I am looking at getting the roll I am looking for with the minimum surface deflection. The more we deflect the surface the more drag we produce which means faster sink. Smaller aileron deflections may also mean less adverse yaw so it may mean a lower aileron to rudder % which means less drag. It is all about reducing drag! If you want to read more on things like aileron differential and such, take a look at these threads. 100s of posts on this and related subjects by some pretty knowledgable guys. I don't pretend to understand it all but I have read it all. Guranteed to make your head hurt. ![]() Aileron to Flap Ratios – Aileron Differential http://www.rcgroups.com/forums/showt...t=aileron+flap http://www.rcgroups.com/forums/showt...t=aileron+flap http://www.rcgroups.com/forums/showp...26&postcount=4 Aileron Differential – yes or no? http://www.rcgroups.com/forums/showthread.php?t=1481705 aileron to flap mixing – benefits – note post by Dr. Mark Drela http://www.rcgroups.com/forums/showthread.php?t=158021 |
USA, CA, Chico
Joined Feb 2011
Basically the first five channels with DX are ALWAYS the typical Rudder, elevator,ailerons, throttle and gear PLUS anything beyond that like 2aileron channels each aileron on its own channel and no flaps would be 6ch, 2 ailerons and one flap channel ( flaps y harnessed ) 7ch, 2 ailerons and 2 flaps would be 8ch,, so you'd need corresponding number of receiver channels to accommodate each of those set ups. Hope this helps. :-) There's many different ways to set up a sailplane with DX8 to get close to full sailplane functionality For instance you can put throttle on Gear, flaps y harnessed together on throttle and separate aileron channels for flaparons, With this set up you'd only need a 6ch receiver,, many different ways to configure. I believe HH has some templates that are used on the radian pro that would work. Check their web site. I've found for maximum sailplane functionality with DX 8 you'll need a 8ch receiver in order to put each servo in the wing on its own channel. Maybe AEAJR has some ideas |
I'm by no means an authority on the matter though, head over to the DX7s/DX8 programming thread. [Freechip] is the admin over there and theres not a lot he doesn't know when it comes to the DX8...
| Thread Tools | |
| For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components | Philscho | Aircraft - Electric - Airplanes (FS/W) | 4 | Aug 19, 2012 12:25 AM |
| Sold E-flite Habu 32 ARF with E-flite Motor/Fan/Retracts/ESC/lipo | ton2di | Aircraft - Electric - Jets (FS/W) | 3 | Aug 16, 2012 07:42 PM |
| Sold (2) E-flite Power 32's, (2) E-flite 60a ESC, all NIB | cybercrxt | Aircraft - Electric - Power Systems (FS/W) | 8 | May 17, 2012 01:53 PM |
| Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 | Philscho | Hot Online Deals | 1 | Mar 02, 2012 08:11 PM |
| Wanted WTB Art Hobby 2.5M or 2.9M e-glider | rrweather | Aircraft - Sailplanes (FS/W) | 0 | Sep 12, 2005 11:09 AM |
