Old Aug 28, 2012, 06:02 PM
Grazer is offline
Find More Posts by Grazer
Team Lumenier Pilot
Grazer's Avatar
Australia, WA, Perth
Joined Aug 2011
That should be PLENTY. No need for separate BEC.
Yes that's the one I bought. Thanks for that. Sticking with all the suggested completion items for it.
Grazer is offline Find More Posts by Grazer
Old Aug 28, 2012, 07:48 PM
Michael Heer is offline
Michael Heer's Avatar
Stockton, Ca. USA
Joined Apr 2001
I have extensively tested the BEC in testing and reviewing the recommended ESC and it should have no problem with the recommended servos and receiver when using the recommended battery or a battery with a higher C. Just don't go with an old battery pack or one with a lower C. Mike H
Old Aug 28, 2012, 09:16 PM
Grazer is offline
Team Lumenier Pilot
Grazer's Avatar
Joined Aug 2011
That's excellent. Thanks.
Old Aug 29, 2012, 08:30 AM
AJT is offline
AJT
Find More Posts by AJT
AJT
Joined Oct 2007
This model will probably be my first E/sailplane. I was about to order the Albatros 3/s with suggested equipment when I noticed this thread. I'll just wait for a flight review before I decide.
AJT is offline Find More Posts by AJT
Old Aug 29, 2012, 09:42 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
I would suspect the Albatros, with its carbon spar and carbon reinforced wing strucutre will be much stronger, but that comes at a $170 price difference. Can't compare the MH32 vs S3021 airfoils as I have never flown an S3021 glider. Both seem to be about the same weight and wing loading.
aeajr is offline Find More Posts by aeajr
Old Aug 29, 2012, 05:16 PM
AJT is offline
AJT
AJT
Joined Oct 2007
Yes I realize there is a price difference between the two but I truly want a 3/m E/sailplane of quality that I can enjoy. I also agree that the Albatros would be stronger. Thank You for the info.
Old Aug 30, 2012, 02:13 PM
tulz43 is offline
Find More Posts by tulz43
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
Which albatros kit are you guys talking about?
tulz43 is offline Find More Posts by tulz43
Old Aug 30, 2012, 04:51 PM
hhrnd40 is offline
Find More Posts by hhrnd40
Horizon Hobby Employee
United States, IL, Monticello
Joined Mar 2007
Maiden flights today prepping the Mystique 2.9 for the the mini contest Horizon is sponsoring at the LSF Soaring Masters next month. CG is a bit back right now so I'll move it forward a bit to be closer to the 118mm number.
Since I'm the JR guy mine is outfitted with JR DS368BB servos in the fuse and DS398's on the ailerons and flaps. The DS398 servos are slightly larger so I set up the linkages opposite of what the manual shows. That's why the there's a cutout on the flap servo cover. I'm using the XG11 for guidance with an RG831B receiver. Here's a few pics of the install.
Enjoy,
JD
hhrnd40 is offline Find More Posts by hhrnd40
Old Aug 30, 2012, 05:34 PM
AJT is offline
AJT
AJT
Joined Oct 2007
Albatros 3E/ ARF.
Old Aug 30, 2012, 06:46 PM
timography is online now
Find More Posts by timography
Electric Glider Nut
timography's Avatar
Joined Feb 2012
wow JD - that looks awesome! Can't wait to get my hands on one when they finally arrive in Australia...
timography is online now Find More Posts by timography
Old Aug 30, 2012, 09:28 PM
Reef_rc is offline
Find More Posts by Reef_rc
Reef_rc's Avatar
Joined May 2011
I realized the price is a tad high and it's not an apple to apple comparison but compare that to my Wilco F5B Hotliner, seems compareable...I am in...almost .
I am in no rush to pre-order mine as I doubt there's a high demand at this price range or for this type of plane. Given so similarity between EF Mystique and Albatros 2.4s - 3S...touch decisions will have to be made . Not only that, it seems all makes and models from both brands are scheduled to arrive at similar time frame. Probable from the same factory, in the same shipping container with slight variation to make one stand out from the other. Higher availability in both parts and complete ARF and a slightly lower price point and an option to us the extra difference to purchase a really nice motor will sway many to EF (nothing wrong there). I am in but I really like the optional to choose different colors and size with the Albatros.
Reef_rc is offline Find More Posts by Reef_rc
Old Aug 31, 2012, 08:03 AM
aeajr is offline
LI, New York, USA
Joined Mar 2003
I don't think the Albatross price is high. For that type of plane and construction, it is quite competitive and, with the carbon capped spars and ribs, the wing should be pretty strong. Should do well on the winch too.
The Mystique looks like it was built to be an elelctric glider. Not as beefed up in the wing, but has accomodation for a tow hook too. Probably do fine on a hi-start, but might have to be very gentle on the winch.
Both look like good values.
Old Sep 03, 2012, 06:53 PM
motoman97 is offline
Find More Posts by motoman97
Fly low and slow ?
motoman97's Avatar
Canada, AB, Calgary
Joined Oct 2007
Albatros 3E/ ARF.
OK so who is selling the Albatross? google search shows crap results
motoman97 is offline Find More Posts by motoman97
Old Sep 03, 2012, 06:54 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
http://www.espritmodel.com/
Old Sep 03, 2012, 06:56 PM
peterlngh is offline
Find More Posts by peterlngh
Joined Apr 2012
Hi, motoman.
The Albatross is built by TopModelcz in the Czech Republic and is marketed in the states by Esprit Models. It's a modern take on the Bird of Time.
http://www.espritmodel.com/f5j-alesl...ailplanes.aspx
peterlngh is offline Find More Posts by peterlngh
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 12:25 AM
Sold E-flite Habu 32 ARF with E-flite Motor/Fan/Retracts/ESC/lipo ton2di Aircraft - Electric - Jets (FS/W) 3 Aug 16, 2012 07:42 PM
Sold (2) E-flite Power 32's, (2) E-flite 60a ESC, all NIB cybercrxt Aircraft - Electric - Power Systems (FS/W) 8 May 17, 2012 01:53 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 08:11 PM
Wanted WTB Art Hobby 2.5M or 2.9M e-glider rrweather Aircraft - Sailplanes (FS/W) 0 Sep 12, 2005 11:09 AM
