Old Nov 23, 2012, 07:06 AM
Rickn816 is offline
Find More Posts by Rickn816
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Originally Posted by txg8gxp View Post
You don't by chance have any amperage and wattage numbers do you? Just curious
I'm still setting trim, so the data are still a work in process.
I'm running full throttle sparingly - only a few seconds at a time.
Last time, the max was about 50 amps and 700 watts. Way more than necessary, but nice to have the extra power to pull away from that big oak tree.
Rick
Rickn816 is offline Find More Posts by Rickn816
Old Nov 25, 2012, 02:55 PM
tclaridge is offline
Find More Posts by tclaridge
United States, VA, Clifton
Joined Nov 2005
Build Help Questions
I am just finishing the wing, and noticed that the flap servo cover is slotted, but the aileron cover is not. Is this slot really needed, or can it be covered? Also, I see that plastic covers are provided to streamline the control clevis on the flaps and ailerons, but what are the two other plastic "bumps" for?
tclaridge is offline Find More Posts by tclaridge
Old Nov 25, 2012, 07:51 PM
TeamHorizon is offline
Find More Posts by TeamHorizon
Joined Jan 2007
Page 7 of this thread has good explanation of your questions,
Pete
TeamHorizon is offline Find More Posts by TeamHorizon
Site Sponsor
Old Nov 25, 2012, 09:13 PM
DeadstickDuck is offline
Find More Posts by DeadstickDuck
Electric
United States, OR, Hillsboro
Joined Oct 2009
I like the page 7 linkage setup.
DeadstickDuck is offline Find More Posts by DeadstickDuck
Old Nov 26, 2012, 08:44 AM
txg8gxp is offline
Find More Posts by txg8gxp
Joined Aug 2012
Ok, so I picked up everything yesterday to start my build. The one question I'm curious about is what does everyone like to use to glue the wing servos in, epoxy, welders, etc?
txg8gxp is offline Find More Posts by txg8gxp
Old Nov 26, 2012, 10:06 AM
Piper J3 is offline
Find More Posts by Piper J3
Full Scale Piper Cub Driver
Piper J3's Avatar
Hinckley, Ohio
Joined Nov 2008
See http://www.rcgroups.com/forums/showp...ostcount=11813 and http://www.rcgroups.com/forums/showp...ostcount=11814
Piper J3 is offline Find More Posts by Piper J3
Old Nov 26, 2012, 11:21 AM
Rickn816 is offline
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
I used Epoxy per the manual. The idea was that they could pop free if there is a hard crash.
Old Nov 26, 2012, 09:14 PM
txg8gxp is offline
Joined Aug 2012
Has anyone found any nice wing bags/carry bags that will fit the mystique?
Old Nov 26, 2012, 09:23 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
THE JACK PAK SAILPLANE CARRY BAGS
http://www.ne-aero.com/jackpak.html.
71 x 17 x 3 size will work with sailplanes up to 3.5 M.
And, no, I don't work for the company or have any financial interest in the product. But it should be a perfect fit.
aeajr is offline Find More Posts by aeajr
Old Nov 28, 2012, 04:44 PM
dangerdan is offline
Find More Posts by dangerdan
dangerdan's Avatar
Canada, ON, Hamilton
Joined Nov 2012
Newbie Question
Its been a slow process but I'm slowly getting there.
I deternined that @ CG 120 mm, I need about 45 grams of weight. The battery is as far as it will go. Is this resonable amount of weight ??
dangerdan is offline Find More Posts by dangerdan
Old Nov 28, 2012, 07:26 PM
Don McCullough is offline
Find More Posts by Don McCullough
SBSS, SVSS, SCCMAS, EBRC
Don McCullough's Avatar
United States, CA, San Jose
Joined Jan 2004
Most are nose heavy, so needing weight is usually not needed. If you are trying to get weight aft, then a lighter battery and/or ESC helps a lot. Mine is perfectly ballanced with both a 4S 1350 65C near the motor and a 2200 35C battery (same weight as the stock 3S) near the servos. I did use a CC Ice 50 Lite which is much lighter than the recommended E-Flite 60-Amp ESC.
Don McCullough is offline Find More Posts by Don McCullough
Old Nov 28, 2012, 07:27 PM
timography is online now
Find More Posts by timography
Electric Glider Nut
timography's Avatar
Australia, WA, Perth
Joined Feb 2012
do you need to add weight in the tail or nose (you didnt mention if the battery is forward or aft as far as it will go)? what battery are you using?
timography is online now Find More Posts by timography
Old Nov 28, 2012, 07:37 PM
dangerdan's Avatar
Joined Nov 2012
I need it up front.
I just had a thought.
Most 3s 3300mah 45c batteries weigh about 300-320 grams.. I am using a Thunder Power G6 Pro 3s 3300mah 45c battery which weighs 268 grams. Thats about 49 grams differance and I am 45 grams short. MMMM??
Old Nov 28, 2012, 08:07 PM
peterlngh is online now
Find More Posts by peterlngh
Joined Apr 2012
It's generally preferred to add weight with batteries or even a heavier motor but, on a 3 meter glider, 45-50 grams won't be much of a hindrance.
peterlngh is online now Find More Posts by peterlngh
Old Nov 28, 2012, 08:12 PM
dangerdan's Avatar
Joined Nov 2012
Its tail heavy and I thought that was a bad thing..
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 12:25 AM
Sold E-flite Habu 32 ARF with E-flite Motor/Fan/Retracts/ESC/lipo ton2di Aircraft - Electric - Jets (FS/W) 3 Aug 16, 2012 07:42 PM
Sold (2) E-flite Power 32's, (2) E-flite 60a ESC, all NIB cybercrxt Aircraft - Electric - Power Systems (FS/W) 8 May 17, 2012 01:53 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 08:11 PM
Wanted WTB Art Hobby 2.5M or 2.9M e-glider rrweather Aircraft - Sailplanes (FS/W) 0 Sep 12, 2005 11:09 AM
