Old Nov 17, 2012, 04:15 PM
LI, New York, USA
Joined Mar 2003
The spar is Balsa?
Well, if that is the case you won't see me trying to launch it on a winch. A medium hi-start will probably be OK.
aeajr is offline Find More Posts by aeajr
Old Nov 18, 2012, 03:36 PM
Electric
Joined Oct 2009
Thank you for the spar insight because I have been leaning towards 1000W of power, and the wings may rip off. So, instead of too much power, why not go light and just stick to @500w.
DeadstickDuck is offline Find More Posts by DeadstickDuck
Old Nov 18, 2012, 06:55 PM
Don McCullough's Avatar
San Jose, CA
Joined Jan 2004
I am not sure more power will increase climb much. My setup with a Hacker 30XL on four cells produces close to 600 watts. At half throttle there is not a huge difference in climb rate. For ALES, I get to 200 meters in about 15 seconds. When angled down to climb to 200 meters closer to 30 seconds cutoff, it is pretty far out. There is only so much power you can dump in -- very much a case of limited return. Weight seems to make more of a difference. I went from 2200 to 1300 mAh batteries. That 105 grams lighter was noticable. Plus, it was easier to not stall out when the motor cut out.
Don McCullough is offline Find More Posts by Don McCullough
Old Nov 19, 2012, 06:31 AM
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
I am using the recommended motor with 4S. It is faster than I can manage.In 40 seconds, it will be high enough so that I can't see it.
Rick
Rickn816 is offline Find More Posts by Rickn816
Old Nov 19, 2012, 10:39 PM
Joined Aug 2012
What size prop are you running with the 4s setup?
Rick
txg8gxp is offline Find More Posts by txg8gxp
Old Nov 19, 2012, 11:14 PM
Electric
Joined Oct 2009
http://www.hobby-lobby.com/40_size_b...33019_prd1.htm
and
APC 13x7 folding on 3s4500 lipo
Old Nov 20, 2012, 06:16 AM
N227CT's Avatar
Lubbock, TX
Joined Feb 2007
We've got a few flights on the plane and doing well. I'm mostly a jet/powered plane guy and have a question. When the prop is idle and I'm just carrying the plane around, the prop blades go WAY forward. When it's full power, I guess centrifugal force causes them to spin normally and they fold back just fine when flying. Is this normal? They just flop forward a lot more than my Radian so I was wondering. Thanks
N227CT is offline Find More Posts by N227CT
Old Nov 20, 2012, 07:12 AM
Don't ask me anything...
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
Originally Posted by N227CT View Post
Is this normal?
Yup !
Chris
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Nov 20, 2012, 10:08 AM
Peter ****smith
Joined Jan 2007
Originally Posted by aeajr View Post
The spar is Balsa?
Main Spar is Spruce, 10mm x 6mm in the center. 10mm x 6 tapering to 10mm x 3mm at the Tip.
Pete
TeamHorizon is offline Find More Posts by TeamHorizon
Old Nov 20, 2012, 12:17 PM
LI, New York, USA
Joined Mar 2003
Pete
Thanks. That makes a lot more sense. I presume it is not carbon capped or you would have mentioned that.
Old Nov 20, 2012, 01:01 PM
Peter ****smith
Joined Jan 2007
"No Carbon".
I did 20 or so Hi Start launches on the Hobby Lobby up to 3M rubber (Its the Red bungee rubber they sell).
Rubber length was 50', I then used some 135 mono (Some old “J” line I had lying around) 150' long so total un-stretched was 200'. Seemed to work great. I also winch launched my Mystique at the Soaring Masters on one of the LSF winches, seemed to launch ok as well.
If you look at the Horizon Video there is a shot of me launching on a Hi start in the video which was the setup described above.
Pete
Old Nov 20, 2012, 01:14 PM
LI, New York, USA
Joined Mar 2003
Peter,
Thanks so much for the additional info about the Spar, the HS and the winch. While I am sure most people will set this up as an electric there are a lot of us who love pure gliders and would rather winch than motor to height.
And, if anyone really wanted to beef up the wing It would probably be pretty easy to remove the wing covering, do a little sanding and add the carbon. But likely that would not be needed for sport flying.
Old Nov 21, 2012, 08:36 AM
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
TXG8 - I'm using the recommended "stock" prop.
Rick
Old Nov 21, 2012, 08:55 AM
Joined Aug 2012
You don't by chance have any amperage and wattage numbers do you? Just curious
Rick
Old Nov 22, 2012, 10:22 AM
Bremen/Germany
Joined Apr 2004
@ power
Hi,
my first flight in rather windy conditions was with a Aeronaut 10" x 6" CC on the recommended E-Flite 25 and a 4s 2500 mAh Lipo - altogether delivering some 400 W at the beginning. The plane went up vertically against the wind with an angle of attack of some 60°.
This is ample power for "normal" (thermal) flying and I would not use more. May be that ALES people would appreciate a little more "frosting" - but 1000 W is way off for me ...
Herbert
h.eberbach is offline Find More Posts by h.eberbach
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 12:25 AM
Sold E-flite Habu 32 ARF with E-flite Motor/Fan/Retracts/ESC/lipo ton2di Aircraft - Electric - Jets (FS/W) 3 Aug 16, 2012 07:42 PM
Sold (2) E-flite Power 32's, (2) E-flite 60a ESC, all NIB cybercrxt Aircraft - Electric - Power Systems (FS/W) 8 May 17, 2012 01:53 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 08:11 PM
Wanted WTB Art Hobby 2.5M or 2.9M e-glider rrweather Aircraft - Sailplanes (FS/W) 0 Sep 12, 2005 11:09 AM
