Old Oct 29, 2012, 07:01 PM
johnagnew2978 is offline
Find More Posts by johnagnew2978
Joined Oct 2012
$369 is the street price. Back in the day of the obeechi-foam wing gliders, we paid about $400 for the Condor, Thermal Eagle, Falcon 880, Sapphire. There was some building to do and servos to buy and install. Especially allowing for inflation, the price looks reasonable to me and I'll probably get one.
johnagnew2978 is offline Find More Posts by johnagnew2978
Old Oct 30, 2012, 01:19 PM
xiaoyu80305 is offline
Find More Posts by xiaoyu80305
Boulder, CO USA
Joined Jul 2010
Originally Posted by Rickn816 View Post
If you look at the recommended throws, the "up" throw is one millimeter for both ailerons and flaps. The flaps can move up 1 mm easily.
RIck N
Do you mix Flaps with Aileron (full wings) when you make turn?
xiaoyu80305 is offline Find More Posts by xiaoyu80305
Old Oct 30, 2012, 03:50 PM
Boulder, CO USA
Joined Jul 2010
Enough length of the motor's axle?
I noticed the firewall of the fuselage is thicker than normal, which means the motor's axle needs to be longer. Did you have trouble for that?
Old Oct 30, 2012, 04:56 PM
Rickn816 is offline
Find More Posts by Rickn816
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
No. This plane needs to fly faster - it is not necessary. It does help if you mix rudder with aileron.
Rick N
Rickn816 is offline Find More Posts by Rickn816
Old Oct 30, 2012, 05:12 PM
RTaylor is offline
Find More Posts by RTaylor
Red Bluff CA
Joined Sep 2001
No it works out perfect that axle nut sits in the firewall.
RTaylor is offline Find More Posts by RTaylor
Old Oct 30, 2012, 05:21 PM
Boulder, CO USA
Joined Jul 2010
I probably use different motor and spinner. I like the spinner from Multiplex. What is the axle nut that you are talking about? Are you talking about the nut that holds the axle, which is a part of spinner?
Old Oct 30, 2012, 06:48 PM
R.M. Gellart is offline
Find More Posts by R.M. Gellart
R.M. Gellart's Avatar
Joined Nov 2005
Rick N
Rick/XIA-Mixing ail-flp is the norm on unlimited ships world wide except when you are in landing mode. Mixing the ail-flp has nothing to with the speed of the ship in any mode, full span camber changing has more control of that and you still have ail-flp mixing turned on in cruise, thermal and reflex modes.
I do use some minor ail-rud mixing, but learn to use that left hand and the rudder stick cause just using the mix can bite you in the arse when you need the ship to maintain a coordinated turn in a thermal.
Marc
R.M. Gellart is offline Find More Posts by R.M. Gellart
Old Oct 30, 2012, 09:43 PM
Boulder, CO USA
Joined Jul 2010
Marc
The hinge of the Flaps could only allow about 1mm up movement of the Flaps, so I guess the full span Aileron movement will not be possible for cruise.
Old Oct 30, 2012, 10:48 PM
RTaylor is offline
Red Bluff CA
Joined Sep 2001
K
When you move the shaft on the power 25 you move the wheel coller to the other side that wheel collar fits in that thick firewall.
I am in the middle of a move so I can't take a picture.
Randy
Old Oct 31, 2012, 12:20 AM
Boulder, CO USA
Joined Jul 2010
When you move the shaft on the power 25 you move the wheel collie to the other side that wheel collar fits in that thick firewall.
Randy
Do you mean other motor might have too short of axle?
Old Oct 31, 2012, 06:07 AM
Joined Nov 2005
Why not? When we were flying foam sheeted wing ships, we could not get alot of up flap to use with the mix, but we did it anyway. I would mix all you could, mix more in thermal mode, and maybe in reflex you can not use it. And if you wanted to make the ship better, uncover the flaps and sand in a more angled face and recover it. No big deal.
Marc
Old Oct 31, 2012, 11:27 AM
RTaylor is offline
Red Bluff CA
Joined Sep 2001
I will try tonight to measure length of motor shaft.
Old Oct 31, 2012, 09:18 PM
neale is offline
Find More Posts by neale
Australia, QLD, Beaudesert
Joined Jul 2008
Hi guys,
I will be getting a .Mystique in the new year, and I am wondering what sort of power you guys are useing.
I am putting an inrunner thru a gear box, into a warmliner on 4s at about 650-700 watts, wondering how the same set-up would be in the Mystique?
Neal
neale is offline Find More Posts by neale
Old Nov 01, 2012, 01:36 AM
DeadstickDuck is offline
Find More Posts by DeadstickDuck
Electric
United States, OR, Hillsboro
Joined Oct 2009
My set up is: 770w 3s and auw 76 oz. @160w/lb.
Motor: HobbyLobby eRC BL40 $49.99 5mm shaft
ESC: CC Ice.lite-75 $101.99
Prop: Aeronat 14x9.5 folder and 40mm turbo spinner $28
Battery: 3s 3300mA 60C $32
DeadstickDuck is offline Find More Posts by DeadstickDuck
Old Nov 01, 2012, 03:07 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
On a thermal glider, the goal of A to F mixing is not so much to get a faster roll but to get the roll you need with less aileron movement on the down stroke. By mixing in about 50% down flap to the down aileron movement you will need less down ailerom movement to achieve the same roll. This produces less adverse yaw and less drag.
1 mm of flap on the up aileron side is enough if that is all you can get. I get maybe 2 mm on my high end molded ships. That is plenty for reflex. And for a to f mixing.
Everything is a compromise. Servos have a limited range of travel. Priority for flap is max down travel for landing. Roll is a secondary use. To get more up you would have to give up some down travel. That would not be the best use of that surface.
aeajr is offline Find More Posts by aeajr
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 12:25 AM
Sold E-flite Habu 32 ARF with E-flite Motor/Fan/Retracts/ESC/lipo ton2di Aircraft - Electric - Jets (FS/W) 3 Aug 16, 2012 07:42 PM
Sold (2) E-flite Power 32's, (2) E-flite 60a ESC, all NIB cybercrxt Aircraft - Electric - Power Systems (FS/W) 8 May 17, 2012 01:53 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 08:11 PM
Wanted WTB Art Hobby 2.5M or 2.9M e-glider rrweather Aircraft - Sailplanes (FS/W) 0 Sep 12, 2005 11:09 AM
