Old Oct 27, 2012, 04:51 PM
United States, CA, Sunnyvale
Joined Mar 2011
Originally Posted by eagle1960 View Post
Not so! I use a DX8 and have camber, reflex and crow.
Really? Would u mind sharing your programming? The radian pro owners have been lamenting not being able to get all the mixing done with the DX8.
vhuang168 is offline Find More Posts by vhuang168
Old Oct 27, 2012, 05:32 PM
United States, TN, Johnson City
Joined Jul 2011
I just used the programming available for the RP and DX8 from the HH or the Spektrum Community websites.
eagle1960 is online now Find More Posts by eagle1960
Old Oct 27, 2012, 05:35 PM
ddruck's Avatar
Canada, ON, Pickering
Joined Nov 2006
Man you must have been living in a cave last couple of years, I have DX7 with crow on gear, camber /reflex on 3 position switch, flaps on aux2, throttle on the throttle stick, aileron to rudder mix, turned on/off by the mix switch. Ok it is not as simple as flipping glider mode but it is doable. I fly my DLG with all controls and flaps on throttle stick. Just do a search and you will find the mixes out there, dx8 has asignable switches that make it easier, but no sliders, that makes DX8 suck. My next radio will be 9503 for my gliders, it has full set of glider mixes and was used by many wold champions for years ( 9303 then), if they gave it telemetry, it would be still the perfect glider radio at it's price range. Since DX8 failed and DX18 is way too out of line.
By the way, as mentioned above, Horizon itself published a doable instructions on how to use DX7 with Radian pro.
ddruck is offline Find More Posts by ddruck
Old Oct 27, 2012, 05:37 PM
Red Bluff CA
Joined Sep 2001
A member posted in the radio section a file for the DX8 and radion pro.
Camber, reflex, and crow and it also had a mix to have the
Flaps mixed to ailerons.
Randy
RTaylor is offline Find More Posts by RTaylor
Old Oct 27, 2012, 06:16 PM
Joined Mar 2011
Iirc it was to have throttle and flaps on the left stick. I believe there wasn't enough mixes to get that to work and you had to give up something.
I've always had flaps/crow on left stick switched with flight modes, camber/reflex and full span ailerons also with flight modes but controllable with left slider. Motor on switch only in launch mode. Always been a JR user but I just recently purchased my 1st Spektrum radio since switching away from DSM by jumping to a JR XG11 and DMSS. Still needed a spektrum compatible radio for my helis and UMXs.
Old Oct 27, 2012, 07:10 PM
Joined Jun 2010
Instead of sodering the servo to get one to be in reverse, you can buy a reverse Y harness. It will reverse one servo without having to break out the sodering gun.
NewRCer is offline Find More Posts by NewRCer
Old Oct 27, 2012, 08:41 PM
Electric
Joined Oct 2009
True, but my soldering iron is already paid for.
DeadstickDuck is offline Find More Posts by DeadstickDuck
Old Oct 28, 2012, 04:46 AM
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
But if it's gonna be a true $800 model, the $2 investment will help.
StarHopper44 is offline Find More Posts by StarHopper44
Old Oct 28, 2012, 09:45 AM
onewire's Avatar
United States, CA, San Diego
Joined Jul 2009
Same here. There are several SPM files for the RadPro that would work well on the Mystique. With proper tweaking, of course.
onewire is offline Find More Posts by onewire
Old Oct 28, 2012, 08:25 PM
United States, TN, Columbia
Joined Mar 2006
Subscibed.... very interested in this ship
sdstick is offline Find More Posts by sdstick
Old Oct 28, 2012, 09:27 PM
Electric
Joined Oct 2009
Rain and out of town for 4 days is really stretching out my build
Old Oct 29, 2012, 06:59 AM
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
We are feeling the storm here in Atlanta. 20+ winds today. No flying again today.
Rick
Rickn816 is offline Find More Posts by Rickn816
Old Oct 29, 2012, 11:43 AM
Boulder, CO USA
Joined Jul 2010
Were your reflex including Flaps up, or just Aileron? The Flaps' up movement seems to be limited by it's structure.
xiaoyu80305 is offline Find More Posts by xiaoyu80305
Old Oct 29, 2012, 11:46 AM
Joined Mar 2006
Anybody know the flight character differences in a MH32 and a SD3012?
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
If you look at the recommended throws, the "up" throw is one millimeter for both ailerons and flaps. The flaps can move up 1 mm easily.
RIck N
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 12:25 AM
Sold E-flite Habu 32 ARF with E-flite Motor/Fan/Retracts/ESC/lipo ton2di Aircraft - Electric - Jets (FS/W) 3 Aug 16, 2012 07:42 PM
Sold (2) E-flite Power 32's, (2) E-flite 60a ESC, all NIB cybercrxt Aircraft - Electric - Power Systems (FS/W) 8 May 17, 2012 01:53 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 08:11 PM
Wanted WTB Art Hobby 2.5M or 2.9M e-glider rrweather Aircraft - Sailplanes (FS/W) 0 Sep 12, 2005 11:09 AM
