Old Oct 26, 2012, 07:53 AM
mertz is offline
Find More Posts by mertz
mertz's Avatar
United States, NM, Rio Rancho
Joined Sep 2010
My flap linkages are binding also. I am going to try rotating the servo arm more. The book calls for an offset from center, I am going to try one more tooth on the servo. If that doesn't work I will try plan B.
mertz is offline Find More Posts by mertz
Old Oct 26, 2012, 08:59 AM
Rickn816 is offline
Find More Posts by Rickn816
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Which way? Do you intend to move the arm toward the leading edge (increase the angle) or back (decrease the angle)? I set mine to the specified 20 degrees.
RickN
Rickn816 is offline Find More Posts by Rickn816
Old Oct 26, 2012, 10:53 AM
CarlMalone is offline
Find More Posts by CarlMalone
United States, TX, San Angelo
Joined Nov 2007
I spent some time making up a multiplex connector for my flap and aileron servos. Now i can't get them mixed up anymore!
CarlMalone is offline Find More Posts by CarlMalone
Old Oct 26, 2012, 11:14 AM
Joined Nov 2007
My aileron servos seem pretty happy but I do have some binding on my flaps. I think that the connector at the servo is hitting the post but its hard to tell. I may try moving the servo arm toward the trailing edge by one or two splines.
Old Oct 26, 2012, 11:22 AM
mertz is offline
mertz's Avatar
Joined Sep 2010
Not sure yet Rick. I just completed the build, now I am waiting for a cup of coffee and then I will sit down and take a look at the wings.
I was really impressed at how well a little glue stick holds the elevator sections on!
Old Oct 26, 2012, 01:10 PM
ekletke is offline
Find More Posts by ekletke
Winnipeg, Canada
Joined Jul 2006
Just starting to test fit some of the hardware. Yes the flap mechanics and linkage don't look like they will do the job. Plan B. I'm thinking my flap drive is going to be on the bottom of the wing as I'm sure I'll want 3 times the suggested flap travel of 25 degrees. Has anyone figured out the wing section? Mine measured about 9.25% thick with measurable undercamber. Does not seem like the thicker almost flat bottom S 3021, or is the SD3021 labled on the box something new?
EK
ekletke is offline Find More Posts by ekletke
Old Oct 26, 2012, 03:07 PM
PrimeFlyer is offline
Find More Posts by PrimeFlyer
United States, CA, Meadow Vista
Joined May 2010
Originally Posted by vhuang168 View Post
Are you guys having issues with the flap or aileron servos or both?
BOTH
Rick (2)
PrimeFlyer is offline Find More Posts by PrimeFlyer
Old Oct 26, 2012, 03:44 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Originally Posted by PrimeFlyer View Post
Question: The instructions say to use glue stick to secure the stabilizer rods to the stabilizer.
I'm wondering what is wrong with using EPOXY and NOT having the stabilizer removable. In the event of a damaging to the stab, just replace the stabilizer. The overall width of the stab is about 32 inches. I can live with that. I'm new to gliders and would appreciate your input.
Rick number 2
Plusses to removeable Stab -
Easy to store and transport
Much less likely to damage the stab getting it out of the house
Easy to fix or repair damaged parts
Negative to Removeable Stab
Makes some pilots nervous
aeajr is offline Find More Posts by aeajr
Old Oct 27, 2012, 08:56 AM
DeadstickDuck is offline
Find More Posts by DeadstickDuck
Electric
United States, OR, Hillsboro
Joined Oct 2009
Flap servo reversing
I am setting my Flap servos to use a Y-harness. All I need to do is mod one of the servos (HS-82MG) to run in reverse.
Here is the proceedure for Hitec servos I found.
http://www.rcsoaringdigest.com/OTW/o...oReversing.pdf
Now I will be able to adjust camber/flaps using the Aux1 channel and its 3-position switch and trim button. Skipping the need for an extra channel on the rx
DeadstickDuck is offline Find More Posts by DeadstickDuck
Old Oct 27, 2012, 12:16 PM
YellowJacketsRC is online now
Find More Posts by YellowJacketsRC
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
Pretty cool article.
QUESTION: I understand why they did not want to solder on the SMT, but why did they cut the wires to the motor? It looks like it would have been simpler to de-solder the connection of the wires right on top of the motor and then switch them. Is there some reason to not mess with that connection?
YellowJacketsRC is online now Find More Posts by YellowJacketsRC
Old Oct 27, 2012, 12:29 PM
vhuang168 is online now
Find More Posts by vhuang168
United States, CA, Sunnyvale
Joined Mar 2011
DX8? You are running the motor on the throttle stick?
vhuang168 is online now Find More Posts by vhuang168
Old Oct 27, 2012, 03:38 PM
Electric
Joined Oct 2009
DX7, and this is my first glider in 20 years. I'm used to the throttle stick for power.
Yes, I agree. I'd just solder them myself..... Guess there are people who do not trust their hands and molten lava!
Old Oct 27, 2012, 04:23 PM
Joined Mar 2011
The DX7 or 8 just doesn't have enough mixes for a powered full house glider. If I remember correctly from the radian pro thread, u have to give up a camber/reflex or crow.
Of the Spektrum radios only the DX10 and DX18 have dedicated sailplane type n mixing.
Old Oct 27, 2012, 04:40 PM
eagle1960 is online now
Find More Posts by eagle1960
United States, TN, Johnson City
Joined Jul 2011
Not so! I use a DX8 and have camber, reflex and crow.
eagle1960 is online now Find More Posts by eagle1960
Old Oct 27, 2012, 04:44 PM
Joined Mar 2011
Dbl post
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 12:25 AM
Sold E-flite Habu 32 ARF with E-flite Motor/Fan/Retracts/ESC/lipo ton2di Aircraft - Electric - Jets (FS/W) 3 Aug 16, 2012 07:42 PM
Sold (2) E-flite Power 32's, (2) E-flite 60a ESC, all NIB cybercrxt Aircraft - Electric - Power Systems (FS/W) 8 May 17, 2012 01:53 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 08:11 PM
Wanted WTB Art Hobby 2.5M or 2.9M e-glider rrweather Aircraft - Sailplanes (FS/W) 0 Sep 12, 2005 11:09 AM
