Old Oct 23, 2012, 09:22 AM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
Tho the conventional wisdom is intake = exhaust/2.
StarHopper44 is offline Find More Posts by StarHopper44
Old Oct 23, 2012, 02:44 PM
CarlMalone is offline
Find More Posts by CarlMalone
United States, TX, San Angelo
Joined Nov 2007
Would an air exit be good in the aft fusalage? I was thinking about putting one on the bottom under the horizontal stab?
CarlMalone is offline Find More Posts by CarlMalone
Old Oct 23, 2012, 02:47 PM
Rickn816 is offline
Find More Posts by Rickn816
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Originally Posted by DeadstickDuck View Post
Someone please tell me where the hot air exhaust is
The spinner and two side inlets give lots of cool incoming airflow, but where does the airflow escape?
I doubt that there will be any hot air. This is not a hotliner, and the hard motor runs should be less than a minute.
(1) servo lead ports in wings.
(2) around the canopy
(3) exit ports for rudder push rod.
(4) slots in fin for elevator control rod.
Rick
Rickn816 is offline Find More Posts by Rickn816
Old Oct 23, 2012, 03:11 PM
peterlngh is offline
Find More Posts by peterlngh
Joined Apr 2012
The simplest way to make an exit is to just drill a hole in the bottom of the fuse anywhere behind the rearmost bit of electronics and forward of the rear of the wing saddle. It's tough to drill into a pristine new fuse but anything up to 3/8" or a bit bigger will be an inconsequential strength reduction. One could reinforce the hole with glass tape to be sure.
peterlngh is offline Find More Posts by peterlngh
Old Oct 23, 2012, 03:54 PM
RTaylor is offline
Find More Posts by RTaylor
Red Bluff CA
Joined Sep 2001
I wonder, is anyone planning on using telemetry for altitude or airspeed.
Randy
RTaylor is offline Find More Posts by RTaylor
Old Oct 23, 2012, 04:54 PM
PrimeFlyer is offline
Find More Posts by PrimeFlyer
United States, CA, Meadow Vista
Joined May 2010
Question: The instructions say to use glue stick to secure the stabilizer rods to the stabilizer.
I'm wondering what is wrong with using EPOXY and NOT having the stabilizer removable. In the event of a damaging to the stab, just replace the stabilizer. The overall width of the stab is about 32 inches. I can live with that. I'm new to gliders and would appreciate your input.
Rick number 2
PrimeFlyer is offline Find More Posts by PrimeFlyer
Old Oct 23, 2012, 04:59 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Then you NEVER have the opportunity to separate the stab. No real reason not to leave that option - right?
Old Oct 23, 2012, 05:08 PM
Jeff_edge540 is offline
Find More Posts by Jeff_edge540
Mis-guided heli guy
Jeff_edge540's Avatar
Austin, TX USA
Joined Mar 2007
I was not comfortable with the stab potentially coming apart in flight. Mine is permanently glued. I also used polyurethane glue on my wing servos. I don't want those coming loose in flight either!
Jeff_edge540 is offline Find More Posts by Jeff_edge540
Old Oct 23, 2012, 05:12 PM
Joined Apr 2012
There's no reason for epoxy, Rick. You would be amazed at how little it takes to hold a stabilator together. I have an old Sagitta 600 that I flew for years without giving it a second thought. The only time it ever moved was if I caught high grass and cartwheeled it. Then, after a few years, it got a little worn and I ground very small dimples near the ends of the wire and added some rubber cement which I would freshen once or twice a season. I've done the same with other planes since and never had the slightest doubt about the stab coming loose in flight. Before then I would simply bend one wire about 1 degree to add more friction.
Old Oct 23, 2012, 05:14 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
Gang the flight loads keep the stab in place. The slight friction from the glue stick is a safe margin. I have never even done that.
I think that in my years I have had one stab come off about 3mm.
Rough landings can sometimes separate a bit more - but that provides protection!
Old Oct 23, 2012, 10:01 PM
timography is offline
Find More Posts by timography
Electric Glider Nut
timography's Avatar
Australia, WA, Perth
Joined Feb 2012
Randy
Sure am! All my e-Gliders have spektrum telemetry on board w/- altimeter, flight pack voltage and temp and Rx voltage. A couple of large scale vintage gliders also have airspeed sensors.
Why do I use them? Because they're cheap and in some cases vital information to know as you are flying around...
timography is offline Find More Posts by timography
Old Oct 24, 2012, 01:18 AM
DeadstickDuck is offline
Find More Posts by DeadstickDuck
Electric
United States, OR, Hillsboro
Joined Oct 2009
Exhaust hole
Well folks, I think the optional exhaust hole should go where the useless tow hook is located. There's already a pilot hole to sink a 0.50 inch drill bit. It just happens to be strengthened anyway, this way we kill two birds in one shot.
Getting rid of the weight of the tow hook nut and giving a clean, reenforced exhaust port.
Humm, image uploads not working....
DeadstickDuck is offline Find More Posts by DeadstickDuck
Old Oct 24, 2012, 11:12 AM
Joined May 2010
I completed assembly of my Mystique today. I experienced several problems in the following areas:
1. Aileron and flap linkage installation was very difficult. I think this will be an issue for many and E-flite needs to come up with a improved linkage. Perhaps a bent linkage?
2. The black pushrod keeper is junk. Before you start construction, go to the hobby shop and buy a quality keeper.
3. A very minor problem, the string used to pull the servo extension through the wing is easily lost. I had to fish a new string through the wing three different times. I used a piece of dental floss tied to a small nut to pull the string through the wing. A longer string from the factory wold correct this.
That's it! Not bad for an new product. The Mystique is VERY well constructed and represents a FANTASTIC value. The manual will improve with time as users find issues.
I think this is the case for any NEW product. Horizon will surely correct the quality of the pushrod keeper and I think some creative person will come up with a better flap linkage also.
All in all I am very satisfied. Now final trimming and a flight.... more to follow.
Rick (2)
Old Oct 24, 2012, 12:22 PM
Rickn816 is offline
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
I had the same observations.
Fix the manual, Horizon!
I set the stab as per manual - it was not neutral on my plane. Look at it carefully before you toss!
Old Oct 24, 2012, 04:57 PM
Earthbound Skyhound
Joined Jun 2011
Several posts ago I posted a 'reference mark'. This was to signify a more-or-less starting point (read the few posts just preceding that 'mark' where all the little 'nags' start showing up) -- and before it progresses beyond the point we're at now, I'll jump back in here with 'my point'.
We've seen nothing but glowing remarks made by those who've flown this new plane, with an apology here & there for something not characterized properly in the documentation etc. Everyone here is aware of the first announcements of the Mystique, and how long the time until they started shipping. It was a pretty good spell. Point is, seems there would've been plenty of time to check the documentation and fit of the components. After all, someone HAD to've assembled the planes the 'company' guys were flying before they were ever released, right? One has to kind've wonder who, & why the discrepancies weren't discovered, fixed and documentation revised before release. We've heard a lot of 'bragging' (for lack of a better word) about the quality & care that went into this bird.....but when it comes down to it, seems a bit all too typical considering all the preliminary hype about the plane & the praise heaped upon the issuer as a company.
Hype vs circumstantive ill fortune? Each can weigh and decide on his or her own -- but this plane I so wanted at first, much because of all the fine things I was hearing about it (notably, from those who were selling it).....wel-l-l-l-lll, let's just say this cherry has soured a bit at this point. Glad now I took 'wait & see' over 'pre-order'.
Bracing for the blast.
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 12:25 AM
Sold E-flite Habu 32 ARF with E-flite Motor/Fan/Retracts/ESC/lipo ton2di Aircraft - Electric - Jets (FS/W) 3 Aug 16, 2012 07:42 PM
Sold (2) E-flite Power 32's, (2) E-flite 60a ESC, all NIB cybercrxt Aircraft - Electric - Power Systems (FS/W) 8 May 17, 2012 01:53 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 08:11 PM
Wanted WTB Art Hobby 2.5M or 2.9M e-glider rrweather Aircraft - Sailplanes (FS/W) 0 Sep 12, 2005 11:09 AM
