Old Aug 22, 2012, 04:02 PM
txg8gxp is offline
Find More Posts by txg8gxp
Joined Aug 2012
e flite says the power 25 averages 30-40a constant, I feel the 60a will be plenty plus the motor should only be used for several seconds at a time, not non stop like a 3d plane.
txg8gxp is offline Find More Posts by txg8gxp
Old Aug 22, 2012, 04:04 PM
txg8gxp is offline
Joined Aug 2012
ETA for horizonhobby is 9/20 according to there dealers page, I work at a hobbyshop so I was able to look it up. Now you know how that goes, it could be sooner or later. We will find out.
Old Aug 22, 2012, 04:18 PM
Darin Jordan is offline
Find More Posts by Darin Jordan
Team Horizon Hobby - Surface
Darin Jordan's Avatar
Renton
Joined Sep 2006
Great... thanks!
I just placed an order for the plane and all the "stuff" from Horizon... Looks like the A7030HV Wing servos are still not in stock. Hopefully Spektrum gets those in soon. I've been using the Digital UM servos in my smaller boats for some time now, and the larger 6020/6030 sized ones in all my larger boats. Great servos.
Darin Jordan is offline Find More Posts by Darin Jordan
Old Aug 22, 2012, 04:27 PM
txg8gxp is offline
Joined Aug 2012
Looks like the servos should be in stock around 8/30
Originally Posted by Darin Jordan View Post
Great... thanks!
Old Aug 22, 2012, 04:34 PM
Renton
Joined Sep 2006
Yeah...
I've been watching those small digital servo's ETA dates change for over a year now... I've had two A7020 on backorder since 10/28/2011...
Hopefully soon...
Old Aug 22, 2012, 04:41 PM
txg8gxp is offline
Joined Aug 2012
hahahaha well that sucks, don't you hate that.
Yeah...
Hopefully soon...
Old Aug 22, 2012, 04:44 PM
Renton
Joined Sep 2006
Well... yeah... it is what it is... I've gone through the same thing with ProBoat trying to get our boats released, so I know what these guys have to go through. Not always something they have direct control over.
Old Aug 22, 2012, 05:56 PM
Grazer is offline
Find More Posts by Grazer
Team Lumenier Pilot
Grazer's Avatar
Australia, WA, Perth
Joined Aug 2011
You can get them here, in stock. Mine are in transit now.
http://www.amainhobbies.com/product_...o-High-Voltage
7020 also in stock.
Grazer is offline Find More Posts by Grazer
Old Aug 22, 2012, 06:08 PM
Grazer is offline
Team Lumenier Pilot
Grazer's Avatar
Joined Aug 2011
The manual is now available. See post #3 in this thread for the link.
Also note some servo extensions have been added to the completion guide.
Old Aug 22, 2012, 06:26 PM
timography is offline
Find More Posts by timography
Electric Glider Nut
timography's Avatar
Joined Feb 2012
Originally Posted by Grazer View Post
Sounds promising! My LHS (although not local to me really) had no idea when, but they are going to let me know when they have information. That is MAS Hobbies in Westminster
Can't wait!
Yeah I called them too and got the same response as you. A bit strange seeing as they sell more E-Flite stuff than anyone else this side of the continent lol
Mine will be a little while before it gets in the air as I have a few other projects to finish off first.
Thought about using the e-flite outrunner but I'm using a MVVS outrunner in my TopModel CZ Avia and it's a superbly built and powerful motor - going to get another for the Mystique, to match the specs recommended by e-flite.
timography is offline Find More Posts by timography
Old Aug 22, 2012, 09:50 PM
TeamHorizon is offline
Find More Posts by TeamHorizon
Joined Jan 2007
Guys, 60AMP is plenty. In fact I did a lot of testing with a 40AMP. Climb on 3S is between 750 -800' in 30 seconds using the 14 x 8.
It's a balsa wing however many launches were performed on solid Hi start with no real problems. Obviously itís not a ďJĒ molded wing however more than acceptable on a winch as long as you donít go too crazy on the peddle.
Airfoil is very responsive to camber change and all the settings are in the manual. With 4mm of camber it hangs pretty good, in cruise at has a great LD and when in speed camber it moves out pretty nice.
Should be shipping is 3-4 weeks and servos will also be available in the same time frame.
Some pretty big players in the soaring community have flow it and love it, itís my hope you all enjoy it as much as we do,
Pete
TeamHorizon is offline Find More Posts by TeamHorizon
Site Sponsor
Old Aug 22, 2012, 09:59 PM
txg8gxp is offline
Joined Aug 2012
Great news...
Old Aug 23, 2012, 06:24 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
It's a balsa wing however many launches were performed on solid Hi start with no real problems. Obviously it’s not a “J” molded wing however more than acceptable on a winch as long as you don’t go too crazy on the peddle.
Some pretty big players in the soaring community have flow it and love it, it’s my hope you all enjoy it as much as we do,
Pete
OK, NOW you are talking MY language.
Any feel for what kind of hi-start was used? We talking weak weeney hi-start or somethign with some muscle? A 3M Hosemonster would be a good fit for this plane. About 19 pounds of pull at full stretch. My Pinnacle 3m goest to 24 pounds at full stretch.
Any carbon on the spar? If one were to strip the covering is there a way to get some carbon on the spar?
I am not trying to make a J glider, just to create a bit more reserve if one were to slightly over pedal it on the winch. I have launched Gentle Ladies on the winch but I hold my breath every time. A little carbon would give that extra safety margin.
As for e-gldier, I would look at this as an ALES contest ship. For that I need 200+ meter climb in 30 seconds, minimum. Better to do it in 20-25 seconds to give some ranging capability. So about 120 to 150 watts per pound would be my target using the lightest battery possible.
30 seconds of best climb then power off and thermal for 10 minutes then land on the spot. Heaven!
aeajr is offline Find More Posts by aeajr
Old Aug 23, 2012, 06:30 AM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
"Assembly Time: 10-15 Hours"
I'm not a glider guy, and I know space can be thight, but isn't this a bit long, just to install a motor/esc/rx and putting it together? Something else I should know? I believe the horns/servos are already installed?
RealGambler is offline Find More Posts by RealGambler
Old Aug 23, 2012, 06:34 AM
Grazer is offline
Team Lumenier Pilot
Grazer's Avatar
Joined Aug 2011
You have to install these. Have a flick through the manual. I posted a link in post # 3.
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 12:25 AM
Sold E-flite Habu 32 ARF with E-flite Motor/Fan/Retracts/ESC/lipo ton2di Aircraft - Electric - Jets (FS/W) 3 Aug 16, 2012 07:42 PM
Sold (2) E-flite Power 32's, (2) E-flite 60a ESC, all NIB cybercrxt Aircraft - Electric - Power Systems (FS/W) 8 May 17, 2012 01:53 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 08:11 PM
Wanted WTB Art Hobby 2.5M or 2.9M e-glider rrweather Aircraft - Sailplanes (FS/W) 0 Sep 12, 2005 11:09 AM
