Old Oct 18, 2012, 10:26 AM
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Mentor? That is scary.
Tim, I used hemostats and needle nose pliers. I don't know if there is an easy way. I spent a long time trying to get the pushrods connected without breaking anything, and I think I succeeded. If I were building that wing from scratch, I would have put the pushrods and servos in before sheeting the wing.
Rick
Rickn816 is offline Find More Posts by Rickn816
Old Oct 18, 2012, 10:31 AM
Electric
Joined Oct 2009
Will (6) Hitec HS-82 servos work well?
I just got my Mystique from the LHS and looking for mid-line metal gear servos.
I have 4 HS-82 servos already in another fun fly plane that I can take out, as well as 2 HS-85s in the drawer......
Anyone know how good these MKS servos are from Esprit? Double the Hitec servos but, dual BB and metal case....
$43
http://www.espritmodel.com/mks-ds92m...tal-servo.aspx
$31
http://www.espritmodel.com/mks-ds450...tal-servo.aspx
-DsD
DeadstickDuck is offline Find More Posts by DeadstickDuck
Old Oct 18, 2012, 07:21 PM
USA, GA, Jesup
Joined Oct 2010
Servo Fastening
I've never assembled a sailplane more complex than a gentle lady, so I'm in front of my headlights here. I do have tons of builds with powered aircraft kits and foamies (Electro Jr. and Radian Pro).
The instructions call for the wing servos to be "glued to the cover using epoxy" It says they will pop loose if the flaps hit the ground and possibly prevent gear stripping.
OK, so is this a "little dab will do you" of epoxy, kinds like a spot in the middle of the servo case about the size of a pencil eraser, or is it more like smear epoxy all over the side of the case and wipe off the excess, or something in between?
Does anyone have suggestions on a more user friendly glue, such as Goop? How about double-sided servo tape? I'm worried that the servos may pop off at the worst possible time, and also that I may ruin some pricey servos by permanently encasing them in epoxy!
Thanks in advance for any help
Bob
bobinjesup is offline Find More Posts by bobinjesup
Old Oct 18, 2012, 07:44 PM
Electric
Joined Oct 2009
Servo glue....
My friend, use a hot glue gun. Make a small smile about the size of a dime and squeeze the servo to the cover tightly to get the hot glue to thin and spread out.
If you wish to remove the servo, just lightly warm up the cover with a covering iron and the hot glue will soften up, woot!
Should you need to adjust the servo a bit, just heat up the bond area and adjust the placement, then squeeze them together again a few seconds until the hot glue cools.
See, look at the
Or X marks the spot, whatever. Simple.
Last edited by DeadstickDuck; Oct 18, 2012 at 07:51 PM. Reason: Added the part where you just heat the parts to adjust them.
Old Oct 19, 2012, 12:21 AM
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
FWIW, I wrap the servo case with a piece of blue painter's tape, with the butt ends facing out when installed. Then a small pea-sized dob of hot glue in the center of the case, quickly pressed into the servo cavity & twisted around a bit to spread evenly, & hold in desired final position a few seconds 'til it sets. I also (while wrapping) fold over a couple mm of the overlapping tape end to help get a fingernail under it later.
When it comes time to change a servo, having the tape ends facing you makes it easy to peel the tape 'open' then just remove the servo, easily peel the remaining tape out of the cavity, clean up the dried hot glue & insert a new setup. Especially effective around foam, which doesn't get along well with heat guns.
StarHopper44 is offline Find More Posts by StarHopper44
Old Oct 19, 2012, 05:22 AM
R.M. Gellart's Avatar
Joined Nov 2005
IMHO, do not use tape, I use heat shrink and then glue in servos in moldies and that would work here.
Marc
R.M. Gellart is offline Find More Posts by R.M. Gellart
Old Oct 19, 2012, 07:33 AM
Play Dead!
Dead's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
Marc
How do you use hear shrink? Do you put it on from the bottom toward the top? Does that not leave the bottom plastic exposed?
Dead is offline Find More Posts by Dead
Old Oct 19, 2012, 08:20 AM
Full Scale Piper Cub Driver
Piper J3's Avatar
Hinckley, Ohio
Joined Nov 2008
Like this...
Piper J3 is offline Find More Posts by Piper J3
Old Oct 19, 2012, 11:42 AM
Quebec Aerotow Association
Charlescd's Avatar
Canada, QC, st-jean-sur-richelieu
Joined May 2010
For the glue gun, I use a 40 watt gun and not the small 10 watt guns.
For the best glue sticks use : Woodworking Hot Melt Adhesive. It really melts into the area you are working and the hold is super strong.
http://www.glu-stix.com/shop/page/pr...99a6d1902.html
Charlescd is offline Find More Posts by Charlescd
Old Oct 19, 2012, 03:39 PM
Mesa AZ, it's a dry heat!
USA, AZ, Mesa
Mystery of the Mystique
Has anyone flown one yet??????????????????
rev.iain is offline Find More Posts by rev.iain
Old Oct 19, 2012, 06:06 PM
mertz's Avatar
United States, NM, Rio Rancho
Joined Sep 2010
Originally Posted by Piper J3 View Post
Like this...
I was wondering the same thing.
Well Played!!
mertz is offline Find More Posts by mertz
Old Oct 19, 2012, 08:13 PM
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Post 414 right above. At least a few tosses.
Old Oct 19, 2012, 09:56 PM
USA, AZ, Mesa
I mean a real flight, with launch, flight, decent control and landing accessment.
Iain
Old Oct 20, 2012, 05:28 PM
Electric
Joined Oct 2009
But this would mean a chance of breaking it and it's brand new
Old Oct 20, 2012, 05:45 PM
Joined Nov 2005
Dead, J3 has a great pic of it, but he does it way better than I do. I shrink across the lugs, it is not real pretty, but like it much better than frames and when you do need to pull a servo, it is a snap. Just cut the shrink tubing, clean it up, down to the epoxy impression, and then shrink tube the new servo and repeat install.
And guys, do not use hot glue to install servos, that stuff is junk, even for plain hobby use. Use good epoxy, West or similar, and this makes a very nice impression of the servo and then when or if you have to replace, you have position and support for your new servo to be exactly where the old one was. Hot glue is one good bump away from being knocked loose and letting the servo be loose, or nearly loose, and then you can have bigger problems. See the pic below.
Marc
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 12:25 AM
Sold E-flite Habu 32 ARF with E-flite Motor/Fan/Retracts/ESC/lipo ton2di Aircraft - Electric - Jets (FS/W) 3 Aug 16, 2012 07:42 PM
Sold (2) E-flite Power 32's, (2) E-flite 60a ESC, all NIB cybercrxt Aircraft - Electric - Power Systems (FS/W) 8 May 17, 2012 01:53 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 08:11 PM
Wanted WTB Art Hobby 2.5M or 2.9M e-glider rrweather Aircraft - Sailplanes (FS/W) 0 Sep 12, 2005 11:09 AM
