LI, New York, USA
Joined Mar 2003
FOR THOSE WHO ARE NEW TO ARFS AND KITS
When setting up a new ARF or kit, these tools will save you time, help you be more accurate and avoid problems with your set-up. Buy them once and use them for years. Great Planes AccuThrow Deflection Meter http://www3.towerhobbies.com/cgi-bin...&I=LXK260&P=ML CG Machine http://www3.towerhobbies.com/cgi-bin...&I=LXK259&P=ML Always test our power set-up I use this wattmeter - Watts-up http://www3.towerhobbies.com/cgi-bin...&I=LXLMV0&P=ML |
![]() Mike |
A WattsUp style meter is an ABSOLUTE MUST for any electric flyer. The throw meter is also quite helpful although you can do the job with a ruler if you like. Personally I do not care for the CG machines. I always use my fingers to get the CG close enough and then I fly it and move the lipo until I get the plane to fly the way I like. You can check my blog for setup recommendations and steps to follow... |
Sounds about right...
You can use less expensive components too. Think of it this way. It is cheaper than a boat. It is cheaper than collecting classic cars. It is WAY cheaper than flying full scale. When you compare it to other full house gliders it isn't too bad but I get it. Mike |
Joined Aug 2012
Well, first off, thanks for the replies.
It just was a bit of a shock, but nothing insurmountable. I will spend quite a bit more time learning on my foamy sailplane before venturing into the $1,000 world, however. "Bring it home whole" would be my mantra then. But they are things of beauty and grace, and enable us, in a poor way, to emulate the soaring creatures whom we envy. It just bugs me that the soaring creatures do it all with a brain the size of a large marble, and probably have no appreciation for their own grace and beauty. |
Joined Apr 2012
One can also find very good electronics that cost less than the recommended items.
We also should not belittle the brains of our feathered, distant, relatives. Most birds use language, most can solve problems, and some can even use tools. Heck! Some crows actually make tools! It really isn't much of an insult to call someone a "bird brain". And they fly much, much, better than we can. Over the decades I've been flying I have shared thermals and slopes with many birds and I have only out climbed them on a few, maybe four, occasions. I suspect that's because they weren't trying. |
| Thread Tools | |
| For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components | Philscho | Aircraft - Electric - Airplanes (FS/W) | 4 | Aug 19, 2012 12:25 AM |
| Sold E-flite Habu 32 ARF with E-flite Motor/Fan/Retracts/ESC/lipo | ton2di | Aircraft - Electric - Jets (FS/W) | 3 | Aug 16, 2012 07:42 PM |
| Sold (2) E-flite Power 32's, (2) E-flite 60a ESC, all NIB | cybercrxt | Aircraft - Electric - Power Systems (FS/W) | 8 | May 17, 2012 01:53 PM |
| Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 | Philscho | Hot Online Deals | 1 | Mar 02, 2012 08:11 PM |
| Wanted WTB Art Hobby 2.5M or 2.9M e-glider | rrweather | Aircraft - Sailplanes (FS/W) | 0 | Sep 12, 2005 11:09 AM |
