Old Oct 11, 2012, 02:38 PM
R.M. Gellart is offline
Find More Posts by R.M. Gellart
R.M. Gellart's Avatar
Joined Nov 2005
SH44, I must admit, how can you determine if the product is inferior?
I have seen a Mystique fly, and it flies fine. It will be a heck of a step forward for anyone wanting to move on up and learn more about soaring and possibly ALES. The airfoil is a good all around section that can utilize camber changing very well and that can fly in the wind too.
It could lighter maybe, and I guess guys will make all kind of changes, like we all do with ARF's but it will be a fine vehicle for the advanced noobie to go on with. Pete Goldsmith knows his stuff and I believe it will work just fine.
Marc
R.M. Gellart is offline Find More Posts by R.M. Gellart
Old Oct 11, 2012, 02:41 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Multiplex didn't want to support an RTF type product. The RTF nature of the Radian, PLUS its excellent glide character, is what made it such a big hit. Heck, I have the RTF and I have two computer radios.
Hitec showed an RTF version of the Easy Glider a tthe WRAM show in February.
The Easy Star is being discountinued and the Hitec Sky Scout has replaced it. It is based on teh Easy Start with Hitec electronics and brushless motor. Ailerons optional.
http://www.hitecrcd.com/products/air...ky-scout-.html
http://www3.towerhobbies.com/cgi-bin...ARCH=Sky+scout
The Easy Glider version may be right behind it.
And the glider market will continue to expand.
aeajr is offline Find More Posts by aeajr
Old Oct 11, 2012, 02:44 PM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
Hitec showed a RTF version of the Easy Glider at the WRAM show in February that was supposed to be released in August but has yeat to come out. That should be huge!
Good points. Bringing out an RTF only now is a tad behind the curve ...
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Oct 11, 2012, 02:54 PM
ddruck is offline
Find More Posts by ddruck
ddruck's Avatar
Canada, ON, Pickering
Joined Nov 2006
I understand Hitec will be producing these in Asia to reduce the price to compete in North American market.
ddruck is offline Find More Posts by ddruck
Old Oct 11, 2012, 03:38 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
So, the Mystique will hopefully the raging success it should be as a step up glider for the foamy guys. And this should become a stepping stone to business for Esprit and other higher end traditional glider providers.
Old Oct 11, 2012, 04:42 PM
Craig Greening is offline
Find More Posts by Craig Greening
Horizon Hobby Employee
United States, IL, Mahomet
Joined Jun 2006
Because it's a very open question, about a very overused term and misunderstood subject.
The Mystique, like any other aircraft, will stall if flown too slowly or the critical AoA is exceeded. The moderate taper with washout provides appropriate stall progression for this type of model. Occasionally, depending on aircraft attitude and control surface input, you may stall one wing before the other. You will not experience random 'tip stalls' while casually flying.
Originally Posted by sinowace View Post
Well I guess no one has flown this bird yet because I haven't gotten any comments if it tip stalls.
Craig Greening is offline Find More Posts by Craig Greening
Old Oct 11, 2012, 06:03 PM
tclaridge is offline
Find More Posts by tclaridge
United States, VA, Clifton
Joined Nov 2005
I just got back from the LHS and opened a Mystique box. Wow is it nice! The quality is top notch. The transparent wings show awesome ribs and caps with perfect covering. The fiberglass fuse was nice. Hardware was also very good with metal clevis and point hinges. Control surfaces on the wings were perfectly hinged. I could not find a defect.
So if it flies as good as it looks, we are in for a treat!
First one with a pilot report wins a prize!
tclaridge is offline Find More Posts by tclaridge
Old Oct 11, 2012, 06:33 PM
Jeff_edge540 is offline
Find More Posts by Jeff_edge540
Mis-guided heli guy
Jeff_edge540's Avatar
Austin, TX USA
Joined Mar 2007
if you can figure out how to get the recommended throws, please let me know.
Jeff_edge540 is offline Find More Posts by Jeff_edge540
Old Oct 11, 2012, 06:44 PM
timography is offline
Find More Posts by timography
Electric Glider Nut
timography's Avatar
Australia, WA, Perth
Joined Feb 2012
A quick check of the manual reveals...
Use a ruler to adjust the throw of the elevator, ailerons and rudder.
Aileron:
Up: 20mm
Down: 12mm
Elevator:
Up: 23mm
Down: 20mm
Rudder:
Right: 50mm
Left: 50mm
Flaps:
Landing: 25 degrees
Camber Settings:
Speed: 1mm up both ailerons and flaps
Cruise: 1mm down both ailerons and flaps
Thermal: 3.5mm down both ailerons and flaps
I'm guessing that this is possibly not what you meant though...
timography is offline Find More Posts by timography
Old Oct 11, 2012, 10:01 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
What kind of problem are you having? Those don't seem to be extreme numbers for surface movement.
Old Oct 11, 2012, 10:40 PM
Mis-guided heli guy
Austin, TX USA
Joined Mar 2007
It is not possible to get 23mm up elevator because the carbon rod hits the top of the cutout. I get about 18mm up/down.
Also, cannot get 20mm of up aileron because the horn is too short and the clevis hits the wing. I'm thinking about cutting a notch to allow for more movement.
Old Oct 12, 2012, 01:03 AM
StarHopper44 is offline
Find More Posts by StarHopper44
United States, NC, Richlands
Joined Jun 2011
[Aside: Marking this point]
StarHopper44 is offline Find More Posts by StarHopper44
Old Oct 12, 2012, 10:04 AM
TeamHorizon is offline
Find More Posts by TeamHorizon
Joined Jan 2007
Jeff, I just checked my Mystique and the available throw on the elevator should be able to be achieved. I can get a total of 27mm up on mine from the Neutral position, Iím a little confused on that. Itís not super critical, 18mm will be fine if you canít get 23mm, you rarely use full travel when flying anyway, might mean slightly larger loops, .
Also Aileron throw is measured from the inboard position not the tip, that may be why you can't get the desired throw. Again, the throws are a starting point, most will adjust to suit their own personal feel.
Again, my apologies if there is any ambiguity in the manual.
Pete
TeamHorizon is offline Find More Posts by TeamHorizon
Site Sponsor
Old Oct 12, 2012, 11:11 AM
Mis-guided heli guy
Austin, TX USA
Joined Mar 2007
Thanks for the reply Pete.
From the photo below, you can see how close the aileron clevis is to the wing in the neutral position.
Description:
Old Oct 12, 2012, 11:16 AM
Mis-guided heli guy
Austin, TX USA
Joined Mar 2007
However, I did have to slightly bend the pushrod to get it connected to the servo and fed thru the opening. I may have bent it too much.
Also, Can you or anyone confirm the CG position? The manual states 120mm, which is almost 50% of cord.
For Sale New in the box E-Flite Taylorcraft ARF Kit plus High Performance E-Flite components Philscho Aircraft - Electric - Airplanes (FS/W) 4 Aug 19, 2012 12:25 AM
Sold E-flite Habu 32 ARF with E-flite Motor/Fan/Retracts/ESC/lipo ton2di Aircraft - Electric - Jets (FS/W) 3 Aug 16, 2012 07:42 PM
Sold (2) E-flite Power 32's, (2) E-flite 60a ESC, all NIB cybercrxt Aircraft - Electric - Power Systems (FS/W) 8 May 17, 2012 01:53 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 08:11 PM
Wanted WTB Art Hobby 2.5M or 2.9M e-glider rrweather Aircraft - Sailplanes (FS/W) 0 Sep 12, 2005 11:09 AM
