Old Aug 21, 2012, 01:38 AM
pwg212 is offline
Find More Posts by pwg212
United States, MI, Middleville
Joined Mar 2012
speed control bec or external bec
I am using a 60A speed control rated for 3 to 6 s lipos. i am running 2 9gram servos for ail, 2 9g servos for flaps, and 2 9g servos for the rudder and elevator. will my speed control support all this on a 3s setup made in series to be 6s; I am not sure if i should use a separate reciever battery, could someone please help?
pwg212 is offline Find More Posts by pwg212
Old Aug 21, 2012, 04:19 AM
whitecrest is offline
Find More Posts by whitecrest
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
What are the specs for your speed control's BEC?
whitecrest is offline Find More Posts by whitecrest
Old Aug 21, 2012, 05:55 PM
pwg212 is offline
Joined Mar 2012
on 5s lipo it will run 2 standard micro servos in linear mode, switch mode it will do up to 4 micro servos on 6s. 80A burst current,
Old Aug 21, 2012, 05:58 PM
erikc641 is offline
Find More Posts by erikc641
United States, NM, Las Cruces
Joined Jul 2012
I am going to say that it will probably not do it. That is a lot of voltage that will be bled off as heat. Lean on the side of caution and install a UBEC. Most esc's will work on up to 3s with about 4 servos. It probably has a 2.5-3A BEC built in. Question is... Is it linear or switching? If it is linear, I would definitely switch it out, if it is a switching type, I would still prolly do it. I have a similar set up and my Rx voltage was getting dangerously low at times. CC BEC and problem solved
erikc641 is offline Find More Posts by erikc641
Old Aug 22, 2012, 01:00 AM
R Zielinski is offline
Find More Posts by R Zielinski
R Zielinski's Avatar
USA, NH, Madbury
Joined Dec 2007
Sounds like you answered your question. Even if the specs say it will work, I would not risk 6 servos on any ESC BEC, switch mode or not. I believe the servo capacity goes down as the battery voltage goes up, so a 6S setup is the riskiest of all. Stepping down the voltage causes heat in the BEC, which can then cause the ESC to reach thermal safety shut down. Digital servos and the ubiquitous "tower pro" 9gm servos are notorious power hogs. Move all 6 at once and you've got voltage drop trouble. Granted the flaps may not move much, but any binding will create amp draw from the "stationary" servo. Even riskier with 2.4 Ghz receivers, some of which are prone to low voltage brown outs and momentary loss control during re-arming. Why risk it? Get a separate BEC.
R Zielinski is offline Find More Posts by R Zielinski
Old Aug 22, 2012, 03:16 AM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
And you have 6 servos on a 6S battery. 6 is more than 4 so there's your answer.
Whether you use a separate RX battery or a standalone BEC is up to you but that ESC definitely won't hack it.
Steve
slipstick is online now Find More Posts by slipstick
Old Aug 22, 2012, 01:48 PM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
"UBEC" was a product name for an add-on switch mode BEC no longer made. You just want an add-on switch mode BEC (SBEC) rated for your application. Go to Dimension Engineering's website to read FAQ's and installation guides and capacities of their SBEC's. Good folks, will answer e-mail questions. DE has lots of other gadgets of interest to RC'ers and experimenters.
E-Challenged is offline Find More Posts by E-Challenged
Old Aug 22, 2012, 02:16 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
What is the speed control? Some already have switch mode BECs. Also need to know the current, whether you plan to deploy your flaps at full speed as a type of airbrake (not good in my opinion) or just use them to improve lift at slow speed (better approach).
7oneWo1f is offline Find More Posts by 7oneWo1f
Discussion 130X modified into an external electronic speed controller glybytony Electric Heli Talk 1 Jul 20, 2012 02:34 AM
Discussion Speed controller with a BEC vs. No BEC Greasetattoo Power Systems 2 Jul 15, 2012 10:13 AM
Question Do You Use An External BEC for 3S or More? Murocflyer Electric Plane Talk 20 Jul 14, 2012 09:15 PM
Discussion External BEC or Buffer Pack? whisperdancer Power Systems 8 Apr 23, 2012 03:08 PM
Discussion 2S Lipo Receiver battery pack without BEC or Speed Controller? Moparbob Batteries and Chargers 6 Mar 18, 2012 11:58 AM
