This thread is privately moderated by RicksterRC, who may elect to delete unwanted replies.
Old Aug 20, 2012, 11:08 PM
RicksterRC is offline
Find More Posts by RicksterRC
Joined Sep 2007
More cool lighting
I found some more cool LEDs.
These are 10mm (fairly big). They are RGB (red/green/blue) all inside one lens with a chip that fades from color to color.
First it does the primaries, then it fades the rainbow, then repeats.
Very cool.
Put it inside one of the white canopies (red/white or blue/white) and the effect is mesmerizing.
They run directly off 4.2V battery.
20 for $7.95 http://www.ebay.com/itm/140804344168...84.m1497.l2649
I scraped some of the solder mask off the ground plane just to the left of the red battery lead. On my board, it was where the date is silkscreened.
Use a meter to make sure you have 4.2V across the red wire to the scraped spot.
Remove the battery.
Tin the bare copper. Bend the LED leads at right angles close to the LED.
Cut the longer one a little longer so you can keep track of it.
The longer lead goes to the red wire pad, the shorter to the scraped spot.
Tin the leads, then solder to the pads.
I couldn't get a good video of it (for some reason the cameras didn't like the brightness of the led and washed it out to white).
MOV007 (1 min 2 sec)
RicksterRC is offline Find More Posts by RicksterRC
Old Aug 25, 2012, 09:11 PM
kavic5150 is offline
Find More Posts by kavic5150
Unregistered night flyer
kavic5150's Avatar
Joined Jul 2009
Very cool. Thanks for posting.
kavic5150 is offline Find More Posts by kavic5150
Discussion Well 2012 Silverlit, More totally cool Shizz!!!! Machy2k Micro Ready-to-Fly 10 Jul 09, 2013 08:36 PM
Sold TX LPU: 57" FMS P-38 Lightning, like-new: Flaps/Retracts/Lights/more! Roswalt Aircraft - Electric - Airplanes (FS/W) 5 Jun 16, 2012 04:28 PM
Discussion What cool things can I add with more Tx channels? 10AE Electric Warbirds 5 Apr 04, 2012 01:52 PM
Spot light kit for night flying?! Strange or cool? Heli Mod Man Electric Heli Talk 54 Aug 07, 2005 09:10 PM
Alert Very inexpensive, VERY cool strobe lights monitor Parkflyers 15 Jun 08, 2005 11:10 AM
